What company actually makes the radio units in the Prius lineup?
Discussion in 'Gen 4 Prius Audio and Electronics' started by ETP, Oct 29, 2017.
  1. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    What company atually makes the radio units in the 2016 Prius lineup? Searching online was a waist of time. I did find hints at JBL and Pioneer for some models.
    I see Panasonic at the FW update site.
    #1 ETP, Oct 29, 2017
  2. ETP
    2,806
    1,170
    Auburdale FL
    Also i see no FW updates for the 2016 Prius online.
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
    Here is where you can check.
    Toyota Downloads
  4. ETP
    2,806
    1,170
    Auburdale FL
    Yep, shows no update for the 2016 Prius with Navigation.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I thought I read that it's JBL - there are JBL markings on the speakers.
  6. Elektroingenieur
    2,515
    3,288
    Three Touring
    In the U.S., it’s Panasonic. For other markets, it may be different; I posted a list a few months ago.
    I don’t know why, but that site is no longer a reliable source.
    There are definitely software updates for the head units, as announced most recently in bulletin T-SB-0279-17, “Entune Audio Head Unit Software Update (Panasonic),” published on September 8, 2017, which supersedes all revisions of the older bulletin T-SB-0103-16. The bulletin and update files are available by subscription to techinfo.toyota.com; at this writing, I’m not aware of a free source. To download the update files, you’ll need a Professional Diagnostic subscription (from $55).
    For Entune Audio (ID 510028), the latest version is 010148, and for Entune Premium Audio (ID 510053 or ID 510054), the latest version is 01018D. (The ID number is printed on the lower right corner of the faceplate.)
    RCO likes this.
  7. alanclarkeau
    7,045
    7,593
    I just went and had a look - mine says JBL:
    I knew the speakers were - the logo reflects in the windscreen
    Elektroingenieur likes this.
  8. Elektroingenieur
    2,515
    3,288
    Three Touring
    JBL may have made the speakers and the amplifier, but the Electronic Parts Catalog says the head unit for the Australia-specification Prius (ZVW50R-AHXEBQ) is made by FUJITSU TEN:
    86804-47350
    RECEIVER ASSY, NAVIGATION
    ZVW50..ARL FUJITSU TEN,ID100396,AUDIO-AUSTRALIA SPEC & AVN & *BT & USB & JBL
    86140-47260
    RECEIVER ASSY, RADIO & DISPLAY
    ZVW50..ARL FUJITSU TEN,ID100395
    Since your car has the JBL system, I expect the head unit is marked with the ID number 100396 in the lower-right corner of the faceplate.
    RCO and alanclarkeau like this.
  9. alanclarkeau
    7,045
    7,593
    Close - maybe there was an item change.:
  10. ETP
    2,806
    1,170
    Auburdale FL
    I will check with the dealer as this is now a dealer will do for me if needed.
    Thanks,
  11. ETP
    2,806
    1,170
    Auburdale FL
    Probably not a great idea to flash the FW if it is not a Panasonic. Maybe!
    BTW! The whole reason for the question is that most companies stopped making HD radios except in the high end models. I was looking for a Home use conversion with a power supply for the house. Maybe a junk yard Toyota unit will work?????
  12. LSeanS
    LSeanS Junior Member
    New York
    Checked the removed OEM head unit from my 2017 Four, non-JBL standard, and it is Panasonic.
