AC only blows cold when temp is set to "LO"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Oct 29, 2017.
  1. Mendel Leisk
    41,907
    Per the title, H/V system set to "Auto", with AC on, if temp is set to "LO", the fan speed climbs dramatically, and air blows nice and cold. if I tick the temperature up the least amount, fan speed subside, and no more cold air.
    I first check the ambient air sensor resistance, and it is within spec. Then searching a bit, on thread on a Toyota 4Runner forum suggested it was disconnected "room temperature sensor", the sensor that monitors cabin air temp.
    I dug down to that, and it was no small feat, no kudos to Toyota for the grief that involved:
    And of course, it was just fine as well: resistance readings within spec.
    So kind of stumped. I'm thinking if I had Techstream, it might help. Still thinking it has something to do with room temperature sensor, as in the sensor is fine, but the connection to it, or somewhere along the way, the info it's transmitting is getting lost.
    Anyone have this before? I seem to recall a similar thread.
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    I don't think I've ever used the "auto" function. I never thought it was accurate. It would always start at a really high speed and I normally don't require that amount of air. I normally only set mine using the manual setting, fan speeds from lowest level 1 to around the middle area.
    I'll have to try the Auto setting on my car and let you know if it's different
  3. Mendel Leisk
    41,907
    Yeah it's like AC goes AWOL, if the temp is set to anything but "LO". And it didn't used to be this way, to best of my recollection. Normally running AC, we'd have temp around 24C (something like 72F?), AC button depressed, and on Auto. Air would be coming out semi-cool.
    Guess I'm going to go back out and put my car together... :rolleyes:
    Raytheeagle likes this.
  4. JC91006
    16,827
    8,600
    Just tested my 2015 on Auto.....outside temperature was 76 degrees, auto setting at 70. Air was coming full blast and was cold. Set the temperature to LO and it was still full speed, still cold....no change.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I run our 2010 most of the time on Auto and it works and changes speed.
    On a Jeep Cherokee my old man has (as well as on a Chevy Prism), had a similar issues you are describing. Ended up being a bad resistor and once changed, everything returned to normal. Both models were known for this failure.
    Do you have a wiring diagram for the circuit? Being the resident librarian, I assume you do, but thought I would ask ;).
    Something’s telling the AC to only run in Low setting. The fan is working and kicking on when requested?
    Good luck (y).
    Mendel Leisk and JC91006 like this.
  6. JC91006
    16,827
    8,600
    Yes I've watched some youtube videos about this resistor problem on cars.......
  7. bisco
    52,393
    what a great excuse to buy a 2015!:)
    Mendel Leisk and Raytheeagle like this.
  8. JC91006
    16,827
    8,600
    Canada doesn't really need AC
  9. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Just a guess here... I had to look up the weather for Vancouver BC - High 62 Low 42
    I just went out to my 2010 & powered it up. When I bring down the temp reading it goes 66-65-Low.
    Perhaps if ambient is <65 strange (ie different than expected) things happen?
  10. bisco
    52,393
    you'd think, but mendel has hot hands.;)
    amos, Mendel Leisk and Raytheeagle like this.
  11. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Or maybe a used PIP with some of the nice rims procured earlier in the year:whistle:.
  12. bisco
    52,393
    no spare = no way.:cool:
  13. Tideland Prius
    16,621
    What was the outside air temperature? (and was it humid in the garage or where you tested it?)
    Now might not be a good time to test it (unless you drive it to California or some place warm).
  14. Mendel Leisk
    41,907
    There's a non-Techstream chicken-dance outlined in the Repair Manual: push start twice without foot on brake, while holding Auto and Recirc buttons. I tried this and it indicated 00, no issues.
  15. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    52° outside this morning so I can test this.
    Prius in "Ready", press :"Auto" climate control button, temperature setting to "Low", press "AC" button - fan ramps up to maximum & fan blows cold air.
    When I raise the temp setting from "Low" to 65° the fan immediately stops. The fan does not "ramp" down slowly but just stops.
    If I move the temperature setting from 65° back down to "Low" the fan quickly ramps up to maximum speed.
  16. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    If the outside temp is close to the set temp (+or- a few degrees) operation of the "auto" A/C system is erratic. It warns of this in the owners manual. Pearl S is erratic in those conditions. A little note for all - A/C Auto means heating and cooling is automatic. It doesn't mean the cooling system only.
    Best to try "low" versus perhaps 24C.
    I often get heat with the system off but just the fan turned on if the set temp is higher than ambient. I reasoned you can't really turn off the heater unless you use the set temp.
  17. Mendel Leisk
    41,907
    This all came to light last Saturday, it was unseasonably warm and sunny here. My wife was trying to drive with windows up, just set a comfortable temp, but the car was becoming a stuffy greenhouse. Yeah good thoughts about the lower ambient temps, but I suspect something is off. Think I'm going to have to invest in a check up at our dealership, see what turns up. I'll try to describe symptoms careful, make sure they're clear on it.
  18. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I keep mine in Auto all of the time. I rarely adjust anything except temp setting and mode, mostly in fall and spring when temp can change between heat in morning and AC in afternoon.
    If I lower mine to LO or HI it goes to to full blast as indicated. To me it always controls as expected.
    Of course I live in a relatively mild environment.
  19. Mendel Leisk
    41,907
    Here's the diagnostic check you can do without Techstream. Again, I'm not sure I did this right, but apparently everything reported as ok, it was showing "00" for me.
    Jayw13702 and StarCaller like this.
  20. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Mr. Check the Obvious here.
    You are in Canada and it is November.
    Might that have something to do with the behavior you are seeing ??
    Edit: OK I see that has mostly been covered. Just one more comment: You might need to pick the right day to take it in for a diagnostic.........because you might not be able to "hold their feet to the fire" if it is cold and cloudy when they look at it.
