Possible Monthly install meets. Bay Area-Fremont
Discussion in 'Local Prius Club Main Forum' started by Priusmpg, Jul 1, 2014.
  1. PriusFan06
    PriusFan06 Member
    60
    33
    SF Bay Area
    Hey all, sorry been MIA. Last time I posted has been a few months and then been busy with a newborn. I'm having more time now. I'm from the south bay ( san jose). If the meet is closer to the bay then I would be interested. Thanks. FRED
    SFO, Xterra72 and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    San Jose to Lafayette isn’t too bad.
    Would you just be in for the social aspects or some maintenance you’d like to do?
    Stop on by(y).
    SFO and PriusFan06 like this.
  3. PriusFan06
    PriusFan06 Member
    60
    33
    SF Bay Area
    Just social aspect for now since I sold my 06 and picked up a 2016 Prius Two. I use to work on my 06 myself. Now my current car is under warranty so no need for me to do anything for 2 years.
    SFO and Raytheeagle like this.
  4. Prodigyplace
    12,627
    11,808
    Central Virginia
    I would expect it is more like unplug and play. :D :LOL:
  5. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    It’ll be nice to have a Gen4 in attendance:).
    Typically we have at least one: Gen2, Gen3 and PIP.
    Hope Lafayette works for you (y).
  6. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I bought an oil catch can and (hopefully) all of the necessary installation paraphernalia. We don’t need to install it but we could if there’s time.
  7. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Good to hear from you again (it’s been awhile).
    We can put you in the list:).
    Good forward to seeing you at the next meet up (y).
  8. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    1. @Raytheeagle : oil change (but can defer as needed)
    2. @grid Oil change, ATF change & tire rotation (last item doesn't have to happen)
    3. ?
    4. ?
    SFO, Pedal Logic and Raytheeagle like this.
  9. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Plug and pray, that everything works as normal after re-assembling.
    Prodigyplace likes this.
  10. Pedal Logic
    Pedal Logic Active Member
    163
    175
    Okay, it's a plan.
    I agree. I'll use it as an opportunity to watch and learn before taking the plunge. :)
    I'm at 80K. I think I heard somewhere/somewhen (it may have from you, actually) that 100K is the recommended change out. Is that the right number? I hope so, because plenty of time to get to it. For this round, I'll just do oil change and some air filters.
  11. mike45
    mike45 Junior Member
    San Leandro, California
    hi all, I plan to attend. Few month ago I bought a 2012 Prius V with 90k miles.
    So far I've done:
    1. transmission and brake fluid flush
    2. both air filters replacement
    3. picking up new battery today
    I would be interested to hear your opinion on few things that slightly bother me and would like to do brake sliding pins lubing.
    Also, would like to hear more about that oil catch can and why do people install it.
    Since I'm new here, is there an entrance fee to attend the meetup or is there anything I should bring?
    SFO, Raytheeagle and Grit like this.
  12. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Knowledge sharing and helpful hands are free:).
    The only thing I would suggest bringing is material for completing the work you want to do on your Prius ;). So if you want to do an oil change, just bring the oil and filter and we’ll take care of the rest;). For brake pin lube, I have the grease so I’ll bring it.
    If you wanted to bring grilling supplies, I’m sure @Pedal Logic would put it on the grill :).
    We can discuss the OCC on the 11th in Lafayette (y).
    SFO and Pedal Logic like this.
  13. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Hoping to see this get done there, plan to drive my own prius into the ground and want to do this also but later.
  14. mike45
    ok, great, I'm planning to come :)
  15. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    (y)I am in for an oil catch can install on that day, and to meet up and socialize a bit.
    I have read somewhere I just need to remove air snorkel and lower air intake tube and I have enough space for connecting the hoses, don't know if that's true and correct. Let's give this a try on the 11th.
    3. @RMB Oil catch can install. Manifold cleaning can wait, correct?
    4. ?
  16. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    I am interested in this meetup
    Raytheeagle and I did one of my slide pins on my 2010
    I have three to go
  17. freedom1725
    freedom1725 Member
    74
    146
    Palo Alto, CA
    I think I can join u guys on the 11th. Where in Lafayette and when r we meeting? lol
    It could be my very first meetup with all these cool Prii-s lmao
  18. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Those that commit I will send a pm to ;).
    You just in for the social aspects or got something you want to do?
    Let us know(y).
    SFO likes this.
  19. freedom1725
    freedom1725 Member
    74
    146
    Palo Alto, CA
    Most likely just social aspects. I'm still 2k away from my next oil change. By the way, I changed it every 8k. Is that too much? lol
  20. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Some say to change it every 5k. The important thing is to keep an eye on the level and top up as needed;).
    Will have the address in a pm soon(y).
    SFO likes this.
