Metal screen in front of radiator
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MPGesus, Oct 31, 2017.
  1. MPGesus
    MPGesus Junior Member
    17
    Midwest USA
    2022 Prius
    What is this piece of metal in front of the radiator? Wife was rear ended and it caused her to hit the car in front of her as well, bending this metal piece pictured. Thanks! IMG_3696.JPG IMG_3695.JPG
    iPhone ?
  2. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    AC condenser
    MPGesus likes this.
  3. MPGesus
    17
    Midwest USA
    2022 Prius
    Thanks! I’m guessing that is not supposed to be curved, so I’ll make sure the adjuster notes it.
    iPhone ?
  4. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Are you pointing out the bent metal piece? If so that’s not a ac condenser
    iPhone ? Pro
    MPGesus likes this.
  5. riceroni87
    360
    598
    Oxnard, CA
  6. riceroni87
    360
    598
    Oxnard, CA
    Hopefully that helps. It’s suppose to curve the other way. There’s foam in front of it that should also be replaced.
    iPhone ? Pro
    MPGesus likes this.
  7. Mendel Leisk
    41,896
    Is this the piece in question:
    The aduster should note that without your intervention. To miss it would be dereliction of responsibility. A hit hard enough to bend that likely has other ramifications, and either the adjuster will find them at the outset, or the bodyshop fill discover as they disassemble things, and there will be some back-and-forth between them and the adjuster.
    MPGesus likes this.
  8. MPGesus
    17
    Midwest USA
    2022 Prius
    Thanks for all the help everyone! The bent piece I was asking about is the bumper reinforcement. I suspect that our Prius was pushed into a the trailer hitch of the car in front of us (our license plate looks like someone tried to hammer it into a bowl shape). Unfortunately that car immediately left the scene of the accident, but at least the truck which rear ended our Prius did stay on the scene (and has insurance).
    iPhone ?
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Grrrrr! :mad: Hope your wife is OK. Down here, rear ending people is a passion. Most of the people in our office have been hit from behind in the past 2-3 years.
  10. Mendel Leisk
    41,896
    Every time I look at the thread title, I keep thinking it's something to do with installing a mesh of some sort in behind the intake grilles, to protect the AC compressor and inverter coolant radiator from rock damage, btw.
    SFO and jerrymildred like this.
