LED Bulbs
Discussion in 'Gen 3 Prius Audio and Electronics' started by ShihFa, Oct 29, 2017.
Tags:
  1. ShihFa
    ShihFa Junior Member
    43
    Corona, CA
    Hello,
    I want to upgrade all my bulbs from filament to LED. Is there anything I should be concerned with? Is there anything i need to upgrade to make it work?
  2. Dreamerzcc
    Dreamerzcc Member
    67
    82
    Hoover
    I just purchased and installed. Got mine from XenonHIDs.com
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Interior bulbs? There are kits, or you can buy piecemeal.
    If replacing exterior bulbs, you might have problems with hyper flashing due to the low resistance of LED bulbs compared to the stock incandescent bulbs.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    AND......there really is no "good" reason to do that in the first place.
  5. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    I'm with you there. Most people here who does aftermarket DIY led / hid conversion don't know how to set the cutoff / reaim and blinds whoever driving the opposite direction.
  6. Dreamerzcc
    Dreamerzcc Member
    67
    82
    Hoover
    I have always changed out my interior bulbs when I get a new vehicle. In my case, I order my interior/exterior bulbs from Diode Dynamics. My headlights this time I went with XenonHIDS. I have not swapped the bulbs for blinkers to LED because I just never have wanted to. I have made the LED brake lights on my G37 be the blinkers and not used the filament bulb with a kit. I do and have always ensured that I am not blinding people with my headlight conversions but not everyone does that.
  7. Sam Spade
    2,036
    1,023
    2017 Prius c
    Since headlights were not specifically mentioned, I assumed he is talking about the OTHER light bulbs.
    Guess we need a clarification.
  8. ShihFa
    43
    Corona, CA
    Hello, I asked this a long time ago, but I thought I would revive this thread to see if anybody has any updates? To answer one poster’s question, I am specifically asking about upgrading the headlights and marker lights on the front.
