Prime Aftermarket Subwoofer & Amp
Discussion in 'Prime Audio, Electronics, and Infotainment' started by mhye01, Oct 5, 2017.
  1. mhye01
    mhye01 Member
    57
    Woodland Hills
    Anybody install an aftermarket sub and amp to their prime? I spend way too much time on the road and the sound system...sucks? Sorry, I couldn't find a better way to describe it. But none the less I want to add a aftermarket sub and and amp to the car and was wondering if anyone has done so and would be kind enough to share some of their experiences...but before you start to share, I'm only looking for people who have done so in a Prime...I've had a sub and amp put into plenty of other vehicles so I'm looking for specific feedback regarding the prime. Thank!
    teamHoffman likes this.
  2. INFINIT tony
    INFINIT tony Member
    60
    97
    SGV
    i added a pioneer gm-d8601 mono amp and a pioneer ts-swx3002 12" loaded shallow sub along with a audiocontrol lc2i to the stock navi tesla looking screen
    Mark57 likes this.
  3. Mark57
    2,945
    2,735
    OK
    Love to see a couple of pics of your setup and locations.
  4. mhye01
    mhye01 Member
    57
    Woodland Hills
    I was actually looking at the same sub but the 10" version. Is the lc2i needed, can't i just use a traditional hi to low converter?
  5. INFINIT tony
    INFINIT tony Member
    60
    97
    SGV
    i dont see why not? i just wanted a hi quality converter with adjustments. ive had my fair share of traditional hi lo converters, once i used an lc2i.. i never looked back
  6. INFINIT tony
    INFINIT tony Member
    60
    97
    SGV
    all my sounds are hidden under the air suspension stuff
  7. dongkeykong
    dongkeykong Junior Member
    How difficult is it to access the wiring behind the screen? I haven't found any quality installers in my area and considering tackling this myself but I'm afraid of causing damage.
  8. mhye01
    mhye01 Member
    57
    Woodland Hills
    I actually just got my sub amp and LC2i installed last week. The installer i used didn't have to get behind the screen, they tapped into my front door speaker wire which was accessible via the kick panel. If you do want to have them tap in behind the screen theres a video on youtube by BeatSonic that shows how to remove the screen fairly easily.
    dongkeykong likes this.
  9. INFINIT tony
    INFINIT tony Member
    60
    97
    SGV
    the beatsonic video is of my car when they installed the video in motion box for us to play videos while in motion
    CyberDyneSystems likes this.
  10. muleman
    muleman Junior Member
    56
    48
    rochester ny
    Any one have a good location and color of the wires to tap into? I want to install a bazooka rs10 sub in the truck. It has a built in amp and crossover. Just need to run power,ground and signal. thank you
  11. Bri-n-TX
    Bri-n-TX Junior Member
    San Antonio, TX
    I just had an 8" Powered Bazooka Sub installed in mine. If my memory serves they tapped into power by the drivers side door floor/trim area. The installer was quite happy that they didn't have to remove any of the dash panels. Seemed easy from how he described it, but then again he does that for a living. The 8" sub fits perfectly underneath the cover in the back, and sounds amazing. I'm so glad I had it installed. It connects with a Molex connector so I can take it out whenever I need to. Couldn't be happier with how it turned out.
  12. Gianni I
    Gianni I Member
    58
    35
    Long Island
    Thinking of adding an amp and sub to my prime as well that I have laying around the house. Would have someone professionally do it of course. Anyone have experience with it draining the battery quicker due to pulling power? Is EV range impacted at all?
  13. muleman
    56
    48
    rochester ny
    When the weather gets a little better I am going to install my 10" rs bazooka tube(rs is 250w) my brother gave me. Its a little over kill and large. I think the 8" would be perfect. But I will take some pics on the install and what wires I use. My tube has a auto remote switch so I Don't have to run a remote wire. Just power/ speaker input and ground.
  14. Gianni I
    Gianni I Member
    58
    35
    Long Island
    Can you share a picture? With the bazooka tube in and what it looks like when taken out?
    muleman likes this.
  15. Bri-n-TX
    San Antonio, TX
    So sorry for the delay. I never got a notification that there was a reply on this thread, and I haven't checked this forum in a few days. Here are some pics. I didn't disconnect it but got some that show the backside of the woofer and the connections.
    AlamedaPrius, Sezy and Mark57 like this.
  16. Gianni I
    Gianni I Member
    58
    35
    Long Island
    That’s exactly the look I want. Be able to have the cover closed and still add the lunch of a sub. I have a 600watt Sony amp from years ago I was thinking of using. My install place said they may be able to get it mounted to that little compartment where the charging cable was stored. I like the idea of an all in one solution tho. Is it easy to connect and disconnect if needed? I would probably have to do it quite often so having just the sub to remove is easier than having the “amp” to remove
  17. Mark57
    2,945
    2,735
    OK
    I love the custom "door stop" anti-roll solution. Cheap and effective! ;)
  18. Bri-n-TX
    San Antonio, TX
    LOL. Thanks. I put a couple of small "Slits" in the floor cover to feed the straps through, but even doing that, when I turned the sub would roll over some and then roll back. The sub is heaver than that rubber mat so the mat loses. The doorstop just kinda fell into my lap. I think it was my wifes idea. Not gonna tell her though. LOL.
    Mark57 likes this.
  19. Gianni I
    Gianni I Member
    58
    35
    Long Island
    Is it a pain to disconnect the sub or no? I know a regular sub just has the 2 terminals for speaker wire. Is disconnecting and reconnecting more annoying?
  20. muleman
    56
    48
    rochester ny
    Nice set up. I am pretty much doing the same set up but with a 10". I have a ton of speakers and amps. But i just want to keep it simple with a bazooka tube with built in amp.
