Dimensions of washer/gasket on transaxle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by NatJS, Nov 6, 2017.
  1. NatJS
    NatJS Junior Member
    17
    UK
    I'm about to replace the ATF in the transaxle but I haven't been able to find a source of OEM washer/gaskets for the drain and fill plugs (aside from Toyota, who are not cheap in the UK). Could someone post the dimensions so I can pick up a couple of generic ones?
    Thanks!
    Nat
  2. Mendel Leisk
    41,824
    Second gen has 2 sizes? You know, consider this is something you do only once or twice, unless the price is really crazy, I would stick to the dealership. Or even just reused existing. As opposed to using some sketchy washers: too much $'s at stake. Are you buying Toyota ATF WS through the dealership?
  3. NatJS
    NatJS Junior Member
    17
    UK
    I'm using Mannol WS ATF (branded Toyota).
    edthefox5 likes this.
  4. bobodaclown
    bobodaclown Member
    216
    72
    24 x 18 x 2 mm part numbers
    90430A0003 3050012031; 3050016100; 3050017011; 3090048052; 3090048063; 3090048090; 3090075040; 3310114030; 3310320120; 3311035620; 3311035670; 3311035680; 3311035711; 3311112170; 3311116052; 3311116061; 3311116062; 3311116070; 3311116080; 3510401011; 3510410021; 3510412061; 3510412063; 3510412101; 3510417011; 3610135020; 3610135030; 9034018008; 9043018007; 9043018008; 90430T0021; 90430W0001
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Replaced my trans fluid 3 times already used the same washer.
