My turn for a 2010 head gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HomeyClown, Nov 5, 2017.
  1. HomeyClown
    HomeyClown Junior Member
    31
    Austin
    I
    I am getting to enjoy my first Toyota engine head gasket. I have a question that I am hoping someone will be able to steer me in the right direction. The manual says
    (d) Apply approximately 150 kPa (1.5 kgf/cm2, 22 psi) of air pressure to the hole pricked in procedure A to release the lock pin.
    Where is this lock pin and how do I know its released? It looks like I could just remove the tensioner, remove the left sprocket and that would give enough slop in the chain for the right but this pin thing has me kind of puzzled. Thanks!
    m.wynn and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    @leeb18c is going through a head gasket replacement currently.
    Here’s a link to his thread:
    Another blown head gasket.
    Good luck and post some pics(y).
    m.wynn likes this.
  3. danlatu
    danlatu Senior Member
    533
    1,348
    maryland
    Remove the engine mount pulley and the entire timing chain cover first. The timing chain tensioner is attached to the timing chain cover. This engine is nothing like a honda engine. When the cover is off, you will have enough play to remove the timing chain and then head will come off.
    #3 danlatu, Nov 5, 2017
    Prodigyplace and m.wynn like this.
  4. HomeyClown
    31
    Austin
    I
    Well I am sorry to say the engine has to come out. Im kind of slow and trying to do this in the car isn't gonna work out for me.
    I have the crank pulley off and have located and removed 8 bolts that separates the engine from the ecvt. Its kind of hard to see around the engine. I have looked around for pictures to get a count of how many bolts there are holding them together without luck.
    can anyone point me to a picture or provide a count of bolts holding the two together and if there is anything else secret to getting the engine off the transmission so I can get it popped apart?
    I will provide pictures when I have something interesting.
    Raytheeagle likes this.
  5. danlatu
    533
    1,348
    maryland
    This will help. Here is the ----> manual
  6. HomeyClown
    31
    Austin
    I
    I have it thanks, just finding information like how many bolts are used to connect the engine to the transmission in 7500 pages of crap is challenging. Plus I say vibration dampner they say crank pulley so its all one great adventure.
    if you would answer these two questions it would be appreciated! :)
    I mean in a regular car you have the torque converter to get the bolts out of, does the spline just pull out of this engine or are there any bolts inside I need to worry about.
  7. ChapmanF
    15,644
    When my dad was teaching me to swim, he said I shouldn't worry how deep the water is because the idea was to swim on the top. :) Likewise the manual may be however many pages it is, but the contents links and hyperlinks are usually the way to swim around in it.
    But another resource that's often valuable can be the parts diagrams at parts.toyota.com. Like this one:
    Does that help?
    -Chap
    danlatu likes this.
  8. danlatu
    533
    1,348
    maryland
    8 bolts + or - Sorry don't remember. Spline pulls straight out like a manual. You will still need to look through the manual for all the torque specs. It is impossible for me to remember. I have personally owned 22+ cars.
    mjoo likes this.
  9. HomeyClown
    31
    Austin
    I
    [QUOTE=" Spline pulls straight out like a manual..[/QUOTE]
    That's what I wanted to hear thanks! These little toy engines and my pry bar can break something quick so I rather ask to keep me safe
    mjoo likes this.
  10. HomeyClown
    31
    Austin
    I
    Thanks for the picture chapman. site appears to be acting up this morning.
    Prodigyplace likes this.
  11. HomeyClown
    31
    Austin
    I
    Tree.jpg A true shade tree mechanic!
  12. Mendel Leisk
    38,729
    A long way from the Japanese assembly plant, lol.
    m.wynn likes this.
  13. HomeyClown
    31
    Austin
    I
    Looks like cylinder 1 and two were leaking. But no bent rod yea!!! piston 1.jpg piston2.jpg
    leeb18c, m.wynn, kc410 and 2 others like this.
  14. Mendel Leisk
    38,729
    Number one at right end?
  15. danlatu
    533
    1,348
    maryland
    Cylinder 4. Closest to the transmission/drivers side.
  16. HomeyClown
    31
    Austin
    I
    The head appears to be clogged with crystals from the coolant. I would guess that would come into the cause. It has 200k on it. It looks pretty good otherwise. I was going to work the head myself but if the machine shop can get it cleaned out and right before thanksgiving it would give me some time to finish the battery on my gen 2. pack.jpg
    Its repair has suddenly become a priority since my son modified his civic last week
    No injuries, his fault, hope he learned something from it. Shame about the car cause it was mint, and I had reworked the head with studs, would have lasted another 100k but now he will get a prius and get better gas mileage.
    #16 HomeyClown, Nov 19, 2017
    Raytheeagle and m.wynn like this.
  17. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Your water leak into piston has prominent marks and looks like water injection really cleanup those two pistons from deposits. On my engine blocks I don't see such marks.
