Brake Actuator and Bleed Brake System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kamocasg, Nov 7, 2017.
  1. kamocasg
    kamocasg New Member
    North Hills
    I have a 2015 Prius, 46291 miles. I took it for oil change on Saturday to a Toyota dealer. I told them that I was hearing a weird noise when braking hard. After they were done they told me that the brake actuator needs to be replaced. Looking into the paperwork that they provided it says: "REC BRAKE ACTUATOR ASSY AND BLEED BRAKE SYSTEM. ESTIMATED 3600 PLUS TAX". I was told that they were going to talk to the DSPM to see if they are willing to provide assistance but the DSPM said no.
    My question is. What does the brake actuator and bleed brake system does? How does it impact the car? If I don't replace it, will any other system in the car be impacted? I was told is not dangerous, but is it dangerous if I don't change it?
    This is a brand new car so I am leaning towards getting rid of the car, but I'd like to understand better what does it mean so I can make an informed decision. At Toyota they did not give me much information.
    Thanks,
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    get a second opinion and i would still drive it
  3. JC91006
    JC91006 Senior Member
    16,815
    8,596
    Is the weird noise like a barking noise? You can't hear it when you brake lightly correct? Do you let you car sit for extended periods?
  4. HomeyClown
    HomeyClown Junior Member
    31
    Austin
    I
    I bought a 2010 prius that was diagnosed from the dealer needing the master cylinder and both front wheel bearings for the super discount of 4500 dollars. I bought a master cylinder off ebay for 102 dollars and that was all she wrote for that problem. The deal is, the master cylinder for the front tires works like a normal master cylinder. You push the pedal and it pushes the pads against the rotor. So you are not going to get in some emergency situation where you cant stop your car unless the pedal gets spongy. Warning lights light up and buzzers beep but you can stop the car on the front brakes. The back are electric. and there is one more thing..a tube on it to make it feel like your pushing the brake when it regenerates. I used that tech software to bleed the master cylinder. It was much easier to do than the egr cleaning. Match the number off yours for your replacement. Candy from a baby. Yell with questions. Don't give up the car for a little issue like this. Really any mechanic could swap this part out and the replacement will work as good as the one you had. You just had a unlucky part.
    #4 HomeyClown, Nov 7, 2017
  5. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Yikes.
  6. HomeyClown
    31
    Austin
    I
    here is what the number looks like. Its hard to see but match it up and you will be good.
  7. Mendel Leisk
    41,826
    They will be replacing the "brake actuator", and then bleeding the brake system.
    It's part #1 (aka Brake Booster Pump Assembly) here I think:
    Hydraulic System for 2015 Toyota Prius | Toyota Parts
    Online price $696.98.
    The attachment outlines complete removal/install of the system, of the which the brake actuator is a part. Normal brake bleeding can be done without Techstream software, but in this case it is mandatory.
    #7 Mendel Leisk, Nov 8, 2017
    caverluna and Raytheeagle like this.
  8. Mendel Leisk
    41,826
    For me the elephant in the room is the $3600 estimate: to replace a part you can buy for $696.98, and bleed the brakes. How many hours is 3 grand labour? :confused:
  9. JC91006
    16,815
    8,596
    There goes the gas savings, after 46000 miles
  10. ChapmanF
    18,458
    No, be careful: the actuator is not the accumulator. In Gen 2 they were combined into one assembly, but in Gen 1 and Gen 3 they are separate. The OP's car is a Gen 3.
    For even more confusion, the parts catalog calls the accumulator pump the "booster pump" (though it's part of the accumulator assembly or "booster pump assembly"), and that is entirely different from the thing called the "booster", which is not the accumulator (but rather an integral part of the master cylinder, in Gen 1 and Gen 3, and not present at all in Gen 2).
    Gen 1 had the accumulator, actuator, and master-cylinder/booster separate (and the ECU inside the cabin). Gen 3 has the accumulator separate, but the actuator, master cylinder, booster, and ECU are combined into a single "brake booster assembly, with master cylinder", list price $2522 (though online dealers will sell discounted, $1652 here).
    Note that there are different order numbers depending on whether you have the 17 inch wheels or not (or, just match the "mark" engraved on the unit, which you will notice is a five-digit-dash-five-digit thing just like an order number, but is not the same as the order number; it is shown as MARK in the descriptive text in the catalog for the different order numbers available).
    -Chap
    #10 ChapmanF, Nov 8, 2017
  11. Mendel Leisk
    41,826
    Did you look at my link? It's for 2015 Prius, and item one is called "actuator assembly"? Or am I missing something? I've no knowledge about it, just plugged in the year, fwiw.
    Down the bottom of the page in your second link, it says "customers also bought" and shows "actuator assembly" for six something.
  12. HomeyClown
    31
    Austin
    I
    One more try to get everyone to consider used parts. On a wrecked car, the brakes are rarely affected and the system stays filled with brake fluid till someone opens the system. This unit does have a big electronic card in it because there is a big plug on it. I looked and there were multiple listings on ebay. You just need to get the number off yours and buy the same number. They usually give a warranty so if it doesn't work they will swap it out.
    I replaced the master cylinder and filled it up with fluid.
    bled the front wheels like you normally do with a regular car.
    Hooked up tech stream software and bled the rear. You just open the valve since its electric.
    then you bleed the cylinder on the master cylinder.
    Jumper the odb2 connector to clear the code and check for errors. I haven't seen an error since, drove the car to work today. perfect!
    Take advantage of the parts off the people who have wrecked their cars. Sure it could fail again same as the brand new one could fail again and the dealer will only cover that part for a certain amount of time and then its tough luck. If mine fails again, I really don't care cause it was so easy to swap out. Autozones new parts crap out all the time, in fact I had a Honda master cylinder fail twice. No big deal.
  13. ChapmanF
    18,458
    That seems to be a mislabeling in the McGeorge Toyota catalog that you linked to. I guess I can't fault you for that. :)
    Compare the diagram in your link to the one on the third page of the "removal" Repair Manual excerpt that you also posted. You can see that the item in the McGeorge link is the same as the one at the bottom of the Repair Manual diagram, only the Repair Manual calls it "brake booster pump assembly with bracket", and the McGeorge link calls it, incorrectly, "actuator assembly".
    Here is the same thing at parts.toyota.com, where it is correctly called "pump assembly, brake booster", same as in the manual.
    How it gets mislabeled as the actuator is kind of a two-step mistake. The first step is that "booster pump assembly" truly is synonymous with "accumulator assembly" (it's the thing that stores pressure), and the second step is that confusion of the word accumulator with the word actuator is super common among people talking about Prius brakes.
    Make no mistake: look back at that Repair Manual diagram, the item shown at the top of that diagram, as "brake booster with master cylinder assembly", is the big omnibus part that combines the master cylinder, booster, ECU, and actuator, all for the low, low price of $2522 (and, if you order now, with a free roll of shop towels for sopping up spilled brake fluid).
    If the OP's dealer really meant 'actuator', that top item is the one that's needed. (If the OP's dealer said 'actuator' by mistake, meaning 'accumulator' just like the mistake in McGeorge's catalog, then it's possible the bottom item is what's needed, but in that case it would be hard to explain the high quoted price.)
    Because there is so much confusion about nomenclature with the Prius brake system (and changes between generations), it does strike me as a really good idea to post and double check the codes retrieved and the technician's reasoning process, before being sure what part needs to be ordered.
    -Chap
    leeb18c and Mendel Leisk like this.
  14. Mendel Leisk
    41,826
    Chap, unlike me, you seem to know what you're talking about, lol.
    Maybe @kamocasg can get a part number from the dealership.
  15. HomeyClown
    31
    Austin
    I
    Deciding who is right is pretty easy. one is saying master cylinder the other is saying booster. Booster makes power brakes and has no electronics thus no error codes. But no booster means no power brakes. I think someone would notice not having power brakes, and I don't think the dealer would have said it was safe to drive. The price of the part and installation tells you we are talking about a master cylinder. Just as a side note, the booster is located right below the master cylinder and has a red brake line running up to the master cylinder. It just has a motor to generate pressure. It would be easer to replace than the master cylinder as its held down with 3 bolts and one power connector. And I bet I could get it less than 100 bucks too :)
  16. ChapmanF
    18,458
    I know you mean well, but you're perpetuating one of the nomenclature problems here. In a Prius brake system, the "booster" and the "booster pump assembly" are two completely different things, in two completely different places. What you're talking about here is the "booster pump assembly", which is also safely called the "accumulator assembly" (avoiding any confusion with plain "booster").
    The thing that's called plain "booster" is an integral part of the master cylinder assembly in Gen 1 and Gen 3. You can't get it separately, and it doesn't have any diagnostic codes of its own. It is not present at all in Gen 2. (For Gen 4, I haven't looked it up.)
    The thing you're talking about here, the "booster pump assembly" or "accumulator assembly", is intensively monitored six ways from Sunday and does indeed have a bevy of related diagnostic codes.
    -Chap
  17. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    surprised this is still happening on a 2015, sounds like the same "extended warrantee" issue with the gen 2's my fix was also over three grand and it was covered by Toyota.. when I asked the trade in value of my 08 they said much less then the repair..
  18. sam25
    sam25 New Member
    florida
    Four Touring
    I have done a brake fluid flush on a 08 Prius , I made a mistake somewhere with cause the fluid valve to block and now no bleeding on or fluid coming out on brake, all light up and beeping ... any idea how to reset the valve to fix the issue .. much appreciated
