12V battery group size
Discussion in 'Gen 4 Prius Main Forum' started by christiandflores, Nov 9, 2017.
  1. christiandflores
    christiandflores Junior Member
    26
    San Diego
    Does anyone know the group size for the battery on the Gen 4 Prius? I've had to jumpstart mine a couple times now.
    I know the warranty is still good, but I run a dashcam while parked. So I'd rather get an upgraded battery then sticking with OEM again.
    2020XLEAWD likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The 12 volt battery is constantly charged by the HV battery and should not require a top up unless the car has been left for more than a few weeks without running the engine. This begs the question, how are you using your car, or how far do you drive each day/week?
  3. bisco
    52,386
    you should be able to find the right size by going to the make of your choice, and plugging in the car info, unless the prime is too new.
  4. Prodigyplace
    12,677
    11,830
    Central Virginia
    This is a Gen 4 thread.
    I would search for a 2016 Prius. I quickly searched a few and came up empty :(
    The Toyota part number appears to be 0054421171325 for about $200.
    pilotgrrl and bisco like this.
  5. bisco
    52,386
    whoops!:oops:
    Prodigyplace likes this.
  6. bisco
    52,386
    i suppose it is in the service manual for 15 bucks. try calling a parts department.
  7. Mendel Leisk
    41,900
    Running an accessory when the car is parked, is asking for trouble.
    pilotgrrl, Prodigyplace and RCO like this.
  8. Prodigyplace
    12,677
    11,830
    Central Virginia
    When not in READY, I agree.
    Leaving the car in READY when unattended is asking for trouble not covered by insurance. :eek:
    Mendel Leisk and pilotgrrl like this.
  9. christiandflores
    26
    San Diego
    So does anybody actually know the size? Lol
    iPhone ?
    m.wynn likes this.
  10. Prodigyplace
    12,677
    11,830
    Central Virginia
    Not without raising the hood & measuring. I have not seen it mentioned in Toyota's description.
    I just checked an old photo. The battery says 20HR 45Ah CCA 295A(EN)
    It looks to be 45 Amp-hours and 295 Cold Cranking Amps, if I read that correctly.
    Physical size and battery terminal size & placement are part of the battery group specification.
    Battery-Web.com - BCI Group Numbers, Dimensional Specifications, Polarity and Terminals
    #10 Prodigyplace, Nov 9, 2017
    christiandflores and RCO like this.
  11. Mendel Leisk
    41,900
  12. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Most "find your car battery" sites don't list the Prius battery. I found a "DIN 44L" on a British site.
  13. Mendel Leisk
    41,900
    3rd gen yes, but 4th gen still early days? (n)
  14. Prodigyplace
    12,677
    11,830
    Central Virginia
  15. bisco
    52,386
    i would call optima and have a discussion. even though they don't list the battery, they do list the prime. maybe they can help.
  16. Prodigyplace
    12,677
    11,830
    Central Virginia
    I would not be surprised if the Prime used the same 12V battery.
  17. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    The important part if that question was answered in his original post.
    Getting a battery with a higher capacity will likely only help a little bit. He really needs to find a different source of power for his camera.......or change his camera habits.
  18. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    If you do this regularly, you maybe could install a secondary battery. I did that when I had a VW Kombi and used it camping. I had an isolator for the fridge so it ran off the secondary battery, and meant I could always start the car, and once the car was running, it re-charged the fridge battery.
    You might even be able to use a Li-ION auxilary Phone battery (or 2 or 3) - they're getting bigger and cheaper?
    kithmo and RCO like this.
  19. christiandflores
    26
    San Diego
    I’m only interested in getting a larger battery. That’s the proper solution. Let’s keep the simplicity down. As I’ve read, the 12v factory battery on the Prius is on the wimpy side. I haven’t had any issues with my other cars while parked, so I’m not going to unhardwire it. The only difference is the battery capacity. Hence the interest in battery group
    iPhone ?
  20. Prodigyplace
    12,677
    11,830
    Central Virginia
    When you are sitting in the car parked just leave it in READY mode. The 12V battery is then kept charged by the large HV battery.
    RCO likes this.
