12V battery group size
Discussion in 'Gen 4 Prius Main Forum' started by christiandflores, Nov 9, 2017.
  1. christiandflores
    christiandflores Junior Member
    26
    San Diego
    Yes
    iPhone ?
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Sorry, I edited after you replied.
    Using the diagram in post 35, which post is positive?
    I am trying to match up with the group link I posted earlier.
  3. christiandflores
    26
    San Diego
    Not necessarily. I could raise the voltage cut off number but then would have less recording time. Hence the need for a larger capacity battery
  4. Prodigyplace
    11,696
    11,317
    Central Virginia
    Group 21 or 21R look close.
    Height is measured to the top of the terminal.
    christiandflores and Since2002 like this.
  5. Since2002
    Since2002 Senior Lurker
    936
    1,097
    Duluth, GA
    Meaning that after the 12V has drained down to a certain level it's supposed to shut off the dash cam. Meaning you still regularly drain the 12V down to a critical level. If you think that's proper, to each his own and best of luck. And I don't mean that sarcastically, you probably will incur more 12V replacement costs over the life of the car, as well as a risk of having a dead battery, but if you accept this as as trade off that is certainly your prerogative.
    pilotgrrl, RCO and Prodigyplace like this.
  6. Mendel Leisk
    38,239
    Use your dash camera in a mode that it only activates when the car is jarred. Or get one that can do this. Or discontinue use of park mode.
    Looking for a battery that can handle relentless drain is a fools mission.
  7. christiandflores
    26
    San Diego
    It’s a thinkware f800 Pro. I’m pretty sure it’d be hard to find a better one
    iPhone ?
  8. christiandflores
    26
    San Diego
    That’s fine, but when my car gets hit at least I’ll have evidence of a hit and run. It will more then offset battery replacements, not to mention a lowered insurance rate. Most people are good drivers and leave notes behind right?
  9. Since2002
    936
    1,097
    Duluth, GA
    However then you miss the "preliminaries" such as the person approaching your car just before they smash a side window, or the view of the license plate of the car that is backing towards your car just before hitting it Those could be critical moments needed for identification.
    Absolutely. The question is whether it is necessary to put the burden on the 12V or if it's better to shift the load onto a second battery dedicated to running the dash cam. Maybe we're old fashioned around here, but because of the critical function of the 12V in operating the car many of us treat it with kid gloves and utmost respect.
    RCO and GT4Prius like this.
  10. christiandflores
    26
    San Diego
    the dashcam is hardwired directly into the fusebox, and has a voltage cutoff feature to prevent flats. I only need to find a higher capacity preferably closer
    it's just a battery, not some diety. Toyota parts are cheap anyways.
  11. Since2002
    936
    1,097
    Duluth, GA
    No, it's a critical component in the vehicle. Feel free however to treat it as just a battery. Again, to each his own.
    #51 Since2002, Nov 10, 2017
    RCO, GT4Prius and Prodigyplace like this.
  12. Prodigyplace
    11,696
    11,317
    Central Virginia
    I followed your ENJ-LN1 link through Google Translate. Here is what they say about the ENJ part of the model.
    EN is an acronym for European Norm. In other words, it is a battery conforming to the European Unified Standards.
    The EN battery originating from EU which is located far north of Hokkaido is the specification originally adapted to the cold district, mainly the CCA value (Cold Cranking Amperes) superiority or lower, that is, the startability of the engine under low temperature, the determinant of the battery performance It was.
    There are apparently 3 models - LN0 LN1 & LN2.
    For the OP, apparently LN2 has higher specs but charging current is higher.
    Here are the specs.
    Translated Link: Google Translate
    RCO likes this.
  13. christiandflores
    26
    San Diego
    that's what i figured too at a quick glance.
    So this morning I actually took out the battery and measured it with my fancy ruler
    Height 7 3/4, width 6 3/4, length 8, inches. The posts are still 5/8". One thing to remember is that the height isn't as important because the cables are flexible. So the closest is battery group 26 at
    8 3/16, 6 13/16, 7 3/4
    #54 christiandflores, Nov 10, 2017
  14. Since2002
    936
    1,097
    Duluth, GA
    The press release implies that a special battery is needed for the Toyota HV vehicles
    "Model list
    ENJ-LN0 Sienta HV
    ENJ-LN1 PRIUS (W50)
    ENJ-LN2 NOAH HV, VOXY HV, Esquire HVALPHARD HV (H30), VELLFIRE HV (H30)"
    Leaving open the question of whether you can go down to your nearest auto parts store and buy an off the shelf replacement battery for the Gen 4 like you can with other cars. Seems like you should be able to, but it would be nice to know for sure.
    #55 Since2002, Nov 10, 2017
    RCO likes this.
  15. Prodigyplace
    11,696
    11,317
    Central Virginia
    Perhaps @Tideland Prius has some hidden information or contacts that could assist.
    @Prius Team (Toyota US Marketing team for Prius) could get the information, but they are not here much.
  16. Mendel Leisk
    38,239
    There was some mention of that here recently, someone using battery of the sort you get with battery powered drills?
  17. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    You seem very sure of what you want to do, but without necessarily having checked whether it's achievable.
    Have you done this, or not?
    "Calculate how long a fully charged 45 ah battery should keep the dashcam running. If this is significantly more than the run time I was getting in practice, I would get the battery checked by an Auto Electrician. Batteries can be damaged by being allowed to go flat. If battery shows ok, I would get the car checked for a fault that may be causing a current draw while the car is not in use.
    3. Calculate what size battery I would need in order to run the dashcam for the length of time I require,and check whether such a battery will fit physically in the car. N.B. Unless you do this, you risk fitting a larger battery that still does not meet your requirements!"
  18. Prodigyplace
    11,696
    11,317
    Central Virginia
    The battery needs to power the dashcam + "Prius readiness" systems such as SKS. Some of these can be disabled for less power draw, but reduced vehicle functionality.
  19. bisco
    48,969
    i wish we still had the popcorn eating guy emoji.:whistle:
