Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Oct 13, 2017.
  1. Mendel Leisk
    41,821
    Maybe also: if customer doesn't want the old cells, what then?
  2. Prodigyplace
    12,626
    11,808
    Central Virginia
    You mean if they do not want to keep the old battery? That's what recycling centers are for.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    And eBay. :)
    William Redoubt and Prodigyplace like this.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Screenshot_20171109-093418.png Now have over 1,000 miles on the pack.
    No issues to report.
    Last 100 miles was at interstate speed. 65 to 70mph. Pack performed as it should.
    30 to 35 degrees Fahrenheit. 2 additional packs stored in the rear plus a customer's spare tire/rim.
    I don't plan on any regular reporting after this. Not sure whether I will be keeping it in the car or not. Probably for a while simply because I don't want to take time to remove it. We'll see.
    My previous battery did not have any issues. This pack was purchased and installed as an initial test.
    If someone local wants to come purchase it from me, feel free to give me a call.
    If it stays in the car longer I'll occasionally report in but not on any specific schedule.
    m.wynn, mjoo, Raytheeagle and 2 others like this.
  5. Prodigyplace
    12,626
    11,808
    Central Virginia
    I almost mentioned Craigslist
  6. Prodigyplace
    12,626
    11,808
    Central Virginia
    I see you're in Pontiac Michigan. Perhaps this Pontiac Firebrid convertible will need a battery in 200K miles.. :D
    From Firebrid: The Prius v Powered Hybrid Convertible | PriusChat
    (It is a Prius v chassis & drivetrain with only 4500 miles) Due to be on the road next year.
  7. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    I'm guessing that most people who do this kit don't plan on ever getting a Toyota or rebuilt battery in the future. So selling the modules may make sense.
    But one word of caution, if you choose to sell your modules remember that there is a good chance your battery will not be accepted as a core without them.
    Might be a good idea to have a full set of junk modules just in case.
    Also retain the extra cabling, etc that was not used in building the cylindrical kit. That way you can put the pack back to stock configuration to turn in as a core.
    Or keep your eyes out for a low priced junk core to keep as a backup.
  8. Kenrico
    Kenrico Member
    82
    52
    I wish I had a core ..it would be ideal to jump in on this ..
    Have almost enough loose cells to stack a dealer core at this time .
    Kenny
  9. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Please, PLEASE keep it in and report every month or two. Your honesty and independence is greatly valued.
    m.wynn and Raytheeagle like this.
  10. JK919
    JK919 Member
    49
    33
    Cary, NC
    Yeah please keep this thing going. If these packs prove reliable, it could finally be a viable alternative to new Toyota packs.
    m.wynn and Prodigyplace like this.
  11. bisco
    52,274
    how long should we wait to find out?
  12. SpaceCityHybrids
    52
    Houston
    Looking forward to getting these
  13. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    I see four paths for the old OEM pack....
    1) Offer for sale as an assembled core, that should fetch as much as $1400 (dealer's core charge)
    2) Remove the good modules and sell them with "core exchange" for $30/module, which could net you ~$800 easy and fast
    3) Test the pack, replace any bad modules and sell for $750-$900 with a 90 day no-fault replacement agreement
    4) Same as #2, but take the "core" modules you get back and then sell the completely dead HV pack as an inexpensive core, say $600
    and you could net $1400, but it's more work.
  14. Mendel Leisk
    41,821
    Best scenario: you practically break even.
  15. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Maybe I am misunderstanding what you are getting at regarding the old pack.
    If you do this kit you will use the original case to build the new pack.
    This will leaves you with a loose pile of scavenged parts and no case: modules, buss bars, wire looms, etc.
    The original case gets installed in the car. The original case contains the new modules.
    1) No. You will not have an assembled core to sell.
    2) OK. You might be able to sell them. How will you know they are good unless you spend time testing them? You'd have to buy some equipment and spend a bunch of time to truthfully make the claim that they are good. Unless you do the work to test them it would be more truthful to sell them as cheap untested modules.
    3) No. Again, you just have a loose pile of parts. No case.
    4) No. You no longer have a case. Just a loose pile of parts.
    #135 ericbecky, Nov 11, 2017
  16. bisco
    52,274
    what do you do with the leftover parts?
  17. Mendel Leisk
    41,821
    Drop in the battery recyling bin at Best Buy? :whistle:
  18. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Im considering this, but i have an extra complete case. So I wouldn't lose anything.
    Prodigyplace likes this.
  19. 05PreeUs
    1,097
    565
    MSP
    Apparently my coffee intake was lacking when I thought of that.... LOL!
    Mendel Leisk and Prodigyplace like this.
  20. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    As I read it I thought maybe *I* hadn't had enough coffee.
    I read it over several times thinking for sure I was missing something. :)
