2010 Prius C 2 won't go into gear
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TWHansen, Nov 10, 2017.
  1. TWHansen
    TWHansen Junior Member
    Milwaukee, WI
    Tried to no avail to find something about this specifically related to the Prius C 2 with the regular gated shifter. Customer of ours bought a 2010 Prius C 2; twice now it has had an issue where it will start and run, but we get no "ready" light and while we can move the gear selector to any gear, it does not shift out of park. Any ideas?
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    If will not shift into gear because it is not in READY mode.
    If you have no trouble lights, is the brake light switch good? If it is bad, it will not sense the foot on the brake when turning the car on.
    If the yellow triangle is lit, there are trouble coeds that can be read by a dealer to troubleshoot further.
    If you post those codes, we can advise further.
  3. bisco
    49,386
    dead 12 volt battery?
  4. TWHansen
    Milwaukee, WI
    Gets weirder - we have the "ready" light, but no action at all from the gear selector. 12V battery is new. The last time it did this we replaced the 12v and it went back to normal. This time, I've disconnected the 12v for 15 minutes, reconnected, and still have the issue. Towing it into the shop tomorrow.
  5. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    There's no such thing as a 2010 Prius C, the first model year was 2012. Are you talking about a regular Prius, or a later-model Prius C?
  6. bisco
    49,386
    bad connection at the battery, or negative ground?
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    The "gated shifter" doesn't do what you think, probably.
    It is ONLY a switch that signals the computers.
    There are no "gears" and the shifter does not connect to the transmission physically.
  8. TWHansen
    Milwaukee, WI
    It's a 2012. Brain fart. On the Prius C 1 and C 2, it still has a physical shifter with a cable, and in this case, the cable broke. I'm ordering another one.
    Prodigyplace likes this.
