EV Switch and MFD on 06 Prius
Discussion in 'Gen 2 Prius Main Forum' started by savaged, Jun 14, 2006.
  1. savaged
    savaged New Member
    Since installing my Coastal EV switch I observed, as noted on Priuschat before, that the MFD will give you a message when it can not engage EV mode. Today, I noticed that when EV is activated the four simulated wheels/tires on the MFD briefly stop and turn backwards. It occurs when the car is at rest or moving (under 34MPH). I thought initially that it was my imagination, but I have since replicated it every time I activate EV mode. Has this been mentioned before? On the factory installed systems is this the MFD signal that EV mode has activated? It's really handy to have the confirmation that the EV mode is on.
    Thought I'd pass the info on.
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I'll have to check that out in the morning.
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I'm not seeing that with my car. Could it be that the cruse control is causing that?
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I take back what I said. I paid more attention to it this time and the wheels do stop but they don't turn backwards. They just stop and then keep on going.
  5. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    Racine, Wisconsin
    I just ordered my Coastal EV mod. Hope it gets here soon.
    Thanks for the tip.
    Does anyone have a copy of the instructions for installing the Coastal EV mod? Would be nice to read it over before getting it.
    Cheers
  6. mosskm
    mosskm New Member
    Good Question and I'm looking forward to a reply on the instructions for installing the Coastal EV mod on an 06. Also, can someone supply the website where I can order the 06 EV mod?
    I just bought my second Prius today. :)
    Regards -- Kevin
  7. K5VMI
    K5VMI New Member
    Baton Rouge, LA
    I have an '06 (without Nav) and have never had any displayed indication concerning the status of the Coastal EV mode. It will switch from the consumption screen to the energy screen when activated. Sometimes EV will change status without any beeps. I'll look for the wheel motion tomorrow.
  8. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    <div class='quotetop'>QUOTE(Three60guy @ Jun 26 2006, 09:58 AM) [snapback]276852[/snapback]</div>
    I suggest you read through this thread
    Coastal EV
    It has some great insights and helpful tips.
    website is
    Coastal webpage
    <div class='quotetop'>QUOTE(theforce @ Jun 26 2006, 09:14 AM) [snapback]276833[/snapback]</div>
    I think we are just seeing the screen refresh...hence the appearance of the wheel hesitating.
  9. Dithermaster
    Dithermaster New Member
    And the "moving backwards" is an illusion. Same thing happens if you stay for the credits at a movie, watching them scroll up the screen, and then final bit with the logos and copyrights stops. For a whiile, it actually appears to be moving down, even though it's stationary. So, if you MFD Energy screen wheels are rolling forward and then instantly stop, you might perceive them as backing up when they are really just stationary.
    ///d@
  10. Three60guy
    918
    Racine, Wisconsin
    <div class='quotetop'>QUOTE(mssmith95 @ Jul 8 2006, 01:51 AM) [snapback]282917[/snapback]</div>
    Thanks mssmith95 for the links.....
    I actually remember that thread now. I had asked a number of questions at the time. Guess I forgot about it. In anycase I finally did get the Coastal EV mod. It works great. The fears I had about the battery (which I had expressed in that thread) went away when I understood that the battery is never made to go out of a range of 40 to 80 state of charge. No way then can the battery loose battery life just by using the EV mode modification. I made the mod and now enjoy using it.
  11. HiTony53
    HiTony53 New Member
    New York
    EV Switch and Warranty
    Has anyone had any Warranty issues with Toyota if you install the EV mode switch and then require warranty work done to your Prius? I heard that Toyota will void your warranty if it finds an EV Mode switch installed.
    Any Comments are welcome. Thanks
  12. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Re: EV Switch and Warranty
    There is at least one report here of Toyota initially denying a warranty claim. See this for more.
  13. daniel
    14,487
    1,519
    Spokane, WA
    One of the advantages of the Coastal EV switch is that it is not immediately obvious that it's there. They'd have to be looking behind that cluster of pins, and then notice the do-hicky that's the Coastal mechanism, and then recognize that's what it is. Or else they'd have to suspect it and try the c/c stalk to see.
