Where to find a gen II chassis stiffener?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Aj__ninja, Nov 12, 2017.
  1. Aj__ninja
    Aj__ninja New Member
    Venice, ca
    does anyone know where I can still buy one of these I’ve looked on-line and couldn’t find any? Thanks in advance
  2. Max Finch
    Max Finch Active Member
    135
    131
    Medford Oregon
    Priuszilla.com though you might be better off purchasing a new front and rear roll bar. Somewhere around 20mm-24mm I think was the sweet spot for most users here. All Prii’s except the Touring had 19mm, the Touring has 20mm.
    I’ll be grabbing a 24mm TRD rear and a 24mm whiteline sometime next year for my Touring
  3. Aj__ninja
    Venice, ca
    why are people getting roll bars instead of chassis stiffeners? What’s the diff?
  4. Max Finch
    135
    131
    Medford Oregon
    A roll bar connects to your suspension. When your suspension compresses in a turn the roll bar literally twists to keep the car from leaning over too much. Hence “roll bar” or “anti rollover bar”. The larger in diameter the bar the less the car leans but if you go too large you’ll suffer from poorer handling. IMO that’s the first upgrade you want to do when it comes to chassis stiffening. Other things like strut braces and under braces won’t have nearly the same effect.
  5. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    If you want better handling, your order of operations in improvement versus cost on the Prius is:
    1. Better tires, wider tires (I have 205/55R16s Michelin Premiers and can attest to much better handling versus Yokohama 185/65R15s).
    2. Front and rear swaybar upgrades, most do an aftermarket 24mm in the rear and a 24mm (IIRC) in the front from a junkyard corolla/matrix. This is a planned upgrade for me.
    3. Coilovers/struts and shocks, Front strut bar, mid chassis stiffener plate, (exactly which one will improve handling will depend on exact circumstances - debatable. Coilovers can improve handling the most but are also the most expensive).
    4. Other stiffening bars
    So I would recommend looking into upgrading #1 and #2 first.
    Max Finch likes this.
  6. Max Finch
    135
    131
    Medford Oregon
    I think when it comes to chassis stiffeners your best logical bet for the Prius is a front strut bar. Other than that I’ve seen mixed reviews about other forms.
    You definitely want roll bars and suspension. Not sure what model you have but my Touring already has the tire size Kevin is talking about. I might add that checking alignment will help in case your toe, caster and camber isn’t where it’s supposed to be.
    I’ve heard negative camber is better for drivers that like to turn harder and faster. But it will increase tire wear and isn’t the best for straight line acceleration.
