Programming the garage door opener ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LarryRacies, May 5, 2006.
  1. LarryRacies
    LarryRacies New Member
    33
    I followed the instructions in the Owners Manual, or at least I think I did, but the opener on the rear view mirror in the 2006 won't open my garage door. Any suggestions, constructive or otherwise? Thanks. Larry
  2. qbee42
    3,079
    Does your garage door opener have a rolling code? Many of the new ones do. If so, the instructions are somewhat more complex. If not, it may be that you didn't hold the button long enough when programming. I had that problem the first couple of times I tried. Also, you have to hold the button for a second or two when opening; just tapping the button won't work.
  3. LarryRacies
    33
    <div class='quotetop'>QUOTE(qbee42 @ May 5 2006, 12:37 PM) [snapback]250271[/snapback]</div>
    Thanks for the tips, Tom.
    No, my opener is an old one and it doesn't have a rolling code.
    I tried to program each of the 3 openers on the mirror, all without success.
    The manual said to hold down the buttons until the red led stops flashing fast.
    The red led on my mirror didn't ever flash fast, it remained steady for about
    30 seconds and then flashed slowly. That's when I thought I had programmed it.
    Was that correct?
    Larry
  4. qbee42
    3,079
    <div class='quotetop'>QUOTE(LarryRacies @ May 5 2006, 01:01 PM) [snapback]250292[/snapback]</div>
    No, you have to keep going. I had the same trouble. I thought I had it when it flashed slowly, but if you keep going it will flash fast and then stop. It takes a little time.
    ReDave likes this.
  5. Kross
    Kross New Member
    88
    Pittsbugh, PA
    (In addition to what Tom said above) With my garage door, I have to hold the HL (HomeLink) button on the Prius rearview mirror for a second before the garage door responds... just pushing it and letting go doesn't work.
    ALSO, my garage door opener has a button in the back called "Learn". All I had to do, to program my Prius Homelink, was hit that button (at which point an LED on the garage door unit flashed) then run to the Prius and hold in the HL button on the rearview mirror. After about 3 seconds my garage door light bulb flashed a couple of times to let me know that it had picked up the Prius signal and the programing was complete.
  6. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    In addition to what the others have said, try changing the batteries in the garage door opener then try programming the Homelink again.
    My dealer programmed the Homelink for me, but with me sitting right there. From what I recall, he held the garage door opener a couple inches from the Homelink/mirror (aimed the opener's LED directly at it), then pressed the first Homelink button in and held it there while simultaneously pressing down on the garage door opener button, until the red light on the Homelink/mirror flashed. It worked well, but I do have to hold in the Homelink button for a couple of seconds for it to open the garage door.
  7. Miss_Taz
    Miss_Taz New Member
    153
    Pittsburgh, PA
    HAHA
    We just did this last night for our 3 garage doors!
    My house was built in 2000, so it is the new rolling code type.
    Had to:
    Press & hold remote & homelink button about 2 inches apart until homelink light flashed slowly and THEN quickly.
    Press LEARN button on garage door opener itself.
    Press homelink button again 3 times (holding it each time for about 1-2 seconds). The 3rd press actually opens (or closes) the door.
    Voila!
    Now all 3 buttons in my car work! :)
  8. LarryRacies
    33
    <div class='quotetop'>QUOTE(qbee42 @ May 5 2006, 01:29 PM) [snapback]250315[/snapback]</div>
    Tom:
    I tried again with all 3 openers.
    I was able to get one of them to the quick flashing stage, but not the other two.
    I kept pressing my remote and the mirror opener until my fingers started to hurt but the quick flashes
    never came on. In fact, after a while the LED just went out. I wonder if my mirror opener is defective?
  9. fyellin
    fyellin New Member
    I've also been completely unable to program the garage door opener. I assumed it has something to do with the fact that our garage door opener is about 25 years old, but still working perfectly.
    Anyone know if there's such a thing as "too ancient" for home link to support?
  10. walt
    walt New Member
    195
    Bel Air, MD, USA -=- Blair, Merlin, Merka
    <div class='quotetop'>QUOTE(fyellin @ May 6 2006, 09:23 AM) [snapback]250710[/snapback]</div>
    look here
    http://www.homelink.com/home/faq.tml
  11. walt
    walt New Member
    195
    <div class='quotetop'>QUOTE(LarryRacies @ May 5 2006, 12:12 PM) [snapback]250260[/snapback]</div>
    I had similar issues - 2006 Prius, built in 11/05. Followed the book, word for word. Finally gave up, and used the garage door opener from my '99 Dodge Caravan. Had a brilliant idea - went to my garage door opener's web site (I have Chamberlain opener) and downloaded the user's manual for that particular opener.
    LO AND BEHOLD! There were - TWO - SLIGHT - differences between what the Prius manual said and what the user's manual said. I followed the user's manual - and it worked!
    As several others have noted, you MUST hold the button on the rear view mirror for two full seconds (one thousand one, one thousand two) to open and close the garage door. I had to retrain myself, since the original opener requires only a tap of the button to activate.
    Hope this helps.
  12. DMontster
    DMontster New Member
    17
    I was able to get mine programmed but only by pressing the button on the opener itself, not using the remote. It is nice to have because now I can give the remote to my son so he can get in the house when I am out driving around in the "Little Red Montster". "Eating up the road but not the gas"
  13. quadling
    quadling New Member
    SHORT HOMELINK DISTANCE.
    I've just programmed my HomeLink but find that the range is only 6-feet whcih is clearly not useable. I've tried orienting the garage door opener's antenna both horizontally and vertically, and even tried extending it, but to no avail.
    Has anyone else had this problem? Could it be a problem with the Prius' HL transmitter?
    Thakns. :unsure:
  14. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(walt @ May 6 2006, 03:24 PM) [snapback]250862[/snapback]</div>
    Same here. It was easy for my home, but not at my parent's. When I read the garage door opener's instructions it said there was TWO ways to learn. The second one worked fine.
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(Quadling @ May 19 2006, 10:55 AM) [snapback]258151[/snapback]</div>
    Mine works from about 250 feet away, at least that is how long my drive way is and I can start opening from the road. You might have someone look at it when you are next at the dealer. You do have to hold the button down for a few seconds unlike the tap that I used on the regular remote.
  16. Kross
    Kross New Member
    88
    Pittsbugh, PA
    <div class='quotetop'>QUOTE(Quadling @ May 19 2006, 01:55 PM) [snapback]258151[/snapback]</div>
    Nope, mine works from over 200 feet away (like someone else mentioned earlier).
  17. NoVaSnow
    NoVaSnow Member
    152
    Centreville, VA
    <div class='quotetop'>QUOTE(Kross @ May 19 2006, 03:43 PM) [snapback]258205[/snapback]</div>
    Mine works from at least 300 feet. In fact, the range seems to be farther than the range on the actual remote.
    I followed the instructions in the manual, and it worked the first time. I did not replace the battery in the remote (as they suggest).
    My garage door openers are less than 3 years old. Genie, with rolling code.
  18. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I'm using a LiftMaster garage door opener with rolling codes and an '06 pkg. #8 Prius. After spending a few frustrating minutes and combining the instructions from the Prius, my dad's '02 Escalade EXT with homelink and the PriusChat forums (inluding the very helpful above link to HomeLink FAQ)...
    1) Turn on the "Lock" feature on the garage door opener wired to the wall (if available) so the door will not be going up and down.
    2) Have your normal garage door opener transmitter in hand.
    3) Press and hold the desired HomeLink transmitter button on the Prius for about 30 seconds and the red light will go from solid to slowly blinking.
    4) Now hold your transmitter close to the mirror, press and hold the button that corresponds to the opener you are trying to program to until the red light on the mirror blinks faster, then release all buttons. To see if it worked, press the same HomeLink button and hold it for a few seconds. If it was successfully programmed to a rolling code transmitter it will blink fast for two seconds then go solid.
    5) Next, Have someone climb up a ladder to the garage door opener unit and have them locate the "Learn" button and an LED near it.
    6) Have them watch the LED while you press and hold the HomeLink button in the Prius. When the LED on the garage door opener unit begins to flash, press and release the "Learn" button and the lights flash on and off, then you can release the button in the Prius. It should work from there!
  19. rocco
    rocco Member
    146
    FL
    you absolutely must have FRESH brand new batteries. Even 1 day old won't work (sometimes) - my prius one works way better than the old handheld. From the end of the drivewway
  20. ronlprius
    ronlprius New Member
    I had to go through the 'press and release every 2 seconds' routine with my rolling-code Genie. It did not work with the 'hold down and wait' method. Once the button was programmed, I put my wife in the car and me on a ladder to program the receiver to recognize the remote. Before I started I used the lock switch on the opener wall switch to keep the door from obeying my every command.
    Ron
