Is P1121 coolant valve related to the inverter water flow?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lioninstreet, Nov 12, 2017.
  1. Lioninstreet
    Lioninstreet Junior Member
    Hello, new owner and member. I recently purchased a high mileage G2 and after roughly 30 miles of use the check engine light came on. Codes are P1121, P1116, and P0420. So I've ended up with a few questions.
    First, P0420. It seemed reasonable to leave dealing with this code until after the other two are dealt with and I could verify it was unrelated.
    So after watching a few videos and reading about P1121, the first thing I checked the coolant reservoir level. and it was near full. I've checked for open recalls on Toyota's site and there are none. So I'm pretty much convinced it's time to replace the coolant control valve.
    I also happened across a few videos relating to the inverter coolant flow and while under the hood I checked the Inverter water reservoir for that wave movement. The inverter water is still.
    What I am wondering is could the faulty coolant control valve related to the P1121/P1116 be related to the still water in the inverter coolant reservoir? Or is the coolant control valve part of the engine cooling system as opposed to the inverter coolant system?
  2. JC91006
    JC91006 Senior Member
    16,759
    8,562
    You have at least 2 problems.
    Check engine light would apply to all 3 codes. The 3 way coolant valve and a catalytic converter
  3. Lioninstreet
    Thanks for the reply JC,
    Would the defective 3 way valve cause the inverter coolant flow to stop?
  4. jdenenberg
    jdenenberg EE Professor
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    No, The valve is in the engine coolant loop.
    JeffD
  5. Lioninstreet
    I've put about 130k miles on two separate G1 insight over the last 8 1/2, years but I'm a newby to Prius. So I appreciate the replies on this. The more I look into these codes and the inverter system the more I end up with questions.
    Priuschat threads seem to show the P1121 3 way valve issue is unrelated to the P1116 code. Would it be best to address these two codes simultaneously or one at a time, the 3 way valve first?
    Second,
    I did drive the car for 3-4 minutes before finding there was no inverter coolant movement with the motor on and idling. It seems odd that the inverter's coolant system is not throwing a code or a dash warning light but there is no coolant movement in the overflow can.
    Does the inverter cooling system maybe have a thermostat that could be stuck closed?
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,416
    3,289
    Madison, Wisconsin
    You should be able to feel the pump to see if it is running.
  7. Lioninstreet
    Hi Eric,
    I've seen some of your posts over on ICN, very informative. Thanks for the reply.
    When I check to feel if the inverter pump is running, do I also need the IC motor to be on and running or just have the ignition fully on?
  8. jdenenberg
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Ignition in "ready" mode will turn on the inverter coolant pump.
    JeffD
  9. Lioninstreet
    I reached down and felt the inverter coolant pump as suggested, it's dead. Good thing I checked. Thanks for all the input. Once it's all in I'll have the P0420 code reset and see if anything comes back.
  10. JC91006
    16,759
    8,562
    If your coolant is over 100k miles old, it's best to drain everything at the same time.
  11. jdenenberg
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    50k miles is the number for replacing coolant after the first replacement. The OP said this was a high mileage Prius when he purchased it.
    JeffD
  12. JC91006
    16,759
    8,562
    OK, probably time to drain....LOL
  13. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    If you aren't seeing any turnulance, and even the vibration if the inverter puno as you touched it, the pump is dead, and you should replace it. In some cases we've seen, sometimes, you don't get even a CEL, when that inverter pump fails.
    You were lucky, you hadn't any overheating issues though.
    Please, do post your findings here for us to learn too.wounded
  14. Lioninstreet
    Carfax shows a water pump replacement at 125k. even so, coolant is due. Oil is clean, Deciding now if I'll do plugs and trans fluid while I'm in there.
    probably wont have this one more than 6 months as I'm kinda watching Manhim for a decent '16 to come up in Florida.
    Will post more as I go
  15. jdenenberg
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Careful, there are two water pumps. You are talking about the electric water pump that circulates the "inverter" coolant. There is also the mechanical water pump for the ICE coolant which needs to be refreshed on the same cycle. Both of these pumps tend to fail at 150-200k miles so I made it a point to replace both at 150k miles at the same time I refreshhed both coolant loops.
    Note that there are two additional pumps in a Gen2 Prius, one to fill and empty the "Thermo Tank" (preserves heat energy at short stops - eliminated in Gen3) and a pump to do passenger heating.
    JeffD
  16. Lioninstreet
    No telling which of the two water pumps was changed out but 125-150k is a pretty good life for any water pump... The carfax detail is sparse. I'm gambling it was the ICE pump that was changed.
    probably gonna swap out the plugs too.
