Red Triangle, P0a80 (2005 Gen 2, 110k miles)
Discussion in 'Gen 2 Prius Main Forum' started by Metrolens, Nov 11, 2017.
  1. Metrolens
    Metrolens Member
    190
    35
    Interesting! I doubt they would open the case for me, that sounds like more work/time for them. But I could ask them to do it, I suppose. My hunch is, Chris is honest and is not trying to misrepresent the quality of batteries he's got. They have a vested interest in the batteries performing as advertised; otherwise they will be losing a lot of time and money fulfilling warranty claims, shipping batteries on their dime, (which sounds like the vast bulk of their business). I didn't get the impression at all that this is how they operate. Are these naive assumptions?
    And 2500 for a brand new factory battery installed (by you?) is pretty sweet. Interesting.... Of course there would only be a 1 year warranty on that, right?
    I think the junkyard option is compelling, but probably not for me.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Will a Gen 3 battery fit as a direct replacement in the Gen 2 or do the modules need to be swapped?
  3. SpaceCityHybrids
    52
    Houston
    Need to swap modules, but they are the same specification.
    Prodigyplace likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    You'll need to transplant the modules to the Gen 2 case and ECU.
  5. Prodigyplace
    11,696
    11,318
    Central Virginia
    I mention that because the OP wanted the battery installed.
    jerrymildred and Metrolens like this.
  6. JC91006
    JC91006 Senior Member
    16,482
    8,400
    To open up the case before installation, it is only held together by a few 10mm bolts/nuts. Won't take more than 2 minutes.
    As for the new battery for $2500, it'll come with the standard 1 year warranty from Toyota. It'll come with a Toyota receipt.
  7. Metrolens
    Metrolens Member
    190
    35
    Ok. So, Electron will indeed show the Serial Numbers of their modules, no problem whatsoever.
    However Chris said that seeing the dates on the modules can be somewhat misleading; a 2016 module that has been driven 200,000 miles or whatever is likely going to be worse than a 2010 module driven 50,000 miles (I made these numbers up for illustration - these numbers did not come from Chris). He added, that what is as (or maybe more) important is the state the batterys were kept in through their life, and their health as measured through the extensive testing they do in the shop. So, while the module SN date is certainly a good indication, and new modules will tend to be better, their age is far from a complete indicator of the quality of the module.
    His answer makes perfect sense to me - any thoughts here?
    #47 Metrolens, Nov 13, 2017
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    I don't understand what the heck the dealership is talking about.
    Would need to really speak with them to make sense of it.
    A new hybrid battery installed by dealer is 3 year warranty: end of story.
    Not sure what they mean by Remanufactured with new cells?
    I guess it is a moot point since you want be choosing them.
  9. Metrolens
    Metrolens Member
    190
    35
    No sir I will not.
  10. JC91006
    16,482
    8,400
    Based on this logic, you should just repair your 2005 battery with 111k miles.
    SFO likes this.
  11. Metrolens
    Metrolens Member
    190
    35
    Not sure I agree. My battery failed because of years, I would think, not because it has too many miles. There is no getting around that all 28 of my modules are 12+ years old. Years obviously DO count, and I will def look for recent SN years... but they are not the only factor.
  12. JC91006
    16,482
    8,400
    There are many factors to a failing hybrid battery. You probably don't drive you car enough that's why the battery failed from going out of balance. Toyota made some of the best modules from 2004-2005 model years. After reconditioning, those modules tend to last a long time, especially low mileage modules.
  13. ericbecky
    4,371
    3,220
    Madison, Wisconsin
    Unless I *needed* to buy used batteries, I guess I wouldn't bother buying used batteries.
    There is no way it takes Avi several days to do a battery swap. It's more likely that he is just booked out that far.
    $2,900 for new Toyota pack seems about right.
  14. JC91006
    16,482
    8,400
    He probably doesn't stock the batteries and he's taking into account the days it would take for Toyota to order one and get it to him.
  15. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    Warranty info is incorrect, it is 3 years if dealer installed.
    We have seen one verified instance of where a PriusChat member was told the same thing, but when he checked the serial numbers of the modules inside the case which showed the modules were old recycled modules. This is consistent with other info that has come to light about the CA Toyota/3rd party collaboration to remanufacture HV batteries.
    If it were me, I would take new over rebuilt any day of the week, so, my advice is to go with either JC's offer or even Avi's quote. Even at $900 extra for new that is not even a premium as far as I am concerned. There is no way where you can compare old to new.
    Hope that helps.
  16. Metrolens
    Metrolens Member
    190
    35
    Thanks again JC, Ericbecky, dolj and all others.
    Let me see if I can explain the logic as to why, in my case, I'm still leaning toward the Electron solution.
    Again my car is a 2005, meaning, as has been pointed out, other systems are likely to start failing, possibly. Maybe. Probably.
    It's a12+ year old car, so the smaller the investment required now, the better. I would much rather make smaller, incremental investments than a larger one now - given the actual money value of the car, and given that some other non-hybrid-battery problem might suddenly pop up and cause me to rethink investing any more money in this car.
    I am just not really seeing the downside to the Electron battery route. Yes, clearly a new batt is better. But it's also 33% more expensive, and has a 1 year warranty. (JC your offer is dope but I'm going to want to stay within shops - someone else should probably hit up JC though as that is a pretty unbeatable situation). I know not to worry as much about the warranty here, because a brand new batt will usually (if not always) last 10+ years. But the fact that the Electron battery does have a no-nonsense 6 year warranty is even better, since it also promises to be a very high quality refurb battery that should last upwards of 6 years... even up to 8 or 10 years is possible according to Chris.
    So, should the Electron battery fail during warranty, I can ask Electron to send someone to LA, and they'll swap it with another refurb battery in around an hour. So really my car would have minimal downtime in the event of a failure. This is IF Electron's battery falls far short, and again, having spoken to Chris twice now, I simply do not, at all, get the impression that he wants to misrepresent, or piss people off, with batteries that fall short of their promise.
    Another way of thinking of it: for sake of mathematical ease, if the new battery can be counted on to last 9 years, at $2900, the Electron battery would have to last around 6 years at $2000 for me to get the exact same dollar value out of it. The Electron warranty has that duration covered (and again, I am banking on this not requiring fifty swap-outs during that six year period - and Electron hopes the same because I would be mightily pissed if that were to happen).
    Finally, looking further into the future, if I need to put a THIRD battery in my car, after the Electron one finally dies (i.e. no fewer than 6 years from now)... 2k1Toaster, for one, will hopefully by then have a time-tested solution that would make this a whole different discussion (it's annoying that my battery went right now, right when 2k1Toaster's modules were just freshly released and before there's enough historical data to show for my tastes). Furthermore, in this scenario, my willingness to spend any more on this 2005 (by then an 18+ year old car!) will be informed by six further years of operation; if the car is falling apart in other ways by then, I may very likely just decide to move on to a newer car.
    If I'm missing something or my logic is flawed, please feel free to talk me off the ledge. It's great talking with such an enthusiastic and brilliant community - hope this conversation is as edifying for you all as it is for me.
    #56 Metrolens, Nov 14, 2017
  17. bisco
    49,481
    you can only hope that electron will live up to the high degree of praise you've allowed them.
  18. Kenrico
    Kenrico Member
    82
    52
    Was talking to EricBecky a few days ago on a unrelated matter ..but it reminds me that this discussion is happening because the Toyota cells were mfg and managed in the car for longevity . So used cells are still viable ..and recycled into more service .
    If your car is more loaded than a typical Pri II with the low mileage it may be worth kicking the extra dough now for the new toy batt solution as it may add to the resale at the end if sold within 3 years . If you are going to ride it out for 7 years plus you may want to also go with the new toy batt solution as well . Your original, matching new cells sold with the car did outlast the warranty by 4 or 5 years (13 or 12 minus 8yrs) . My point is that the EV shop may carry a longer warranty but in almost every case the dealer solution is the least likely to use it.
    One other thing is the dealer had a new sku of 'cells only' that were only a couple of hundred dollars less ..but did not include a new batt enclosure, buss bars or wiring. A reman batt will reuse the components as well . Also FYI - the 2k1 new cylindrical cells are shipping with new cell wiring and buss bars too..
    Kenny
  19. Metrolens
    Metrolens Member
    190
    35
    This is true.
    Good points. Though my battery outlasted the warranty by 2 years - it's 10 years/150,000 miles in Cali.
  20. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Good luck with the battery :)
    Metrolens likes this.
