Urgent help please. 2009 not starting.
Discussion in 'Gen 2 Prius Main Forum' started by PriusPaddler, Nov 13, 2017.
  1. PriusPaddler
    PriusPaddler Member
    119
    22
    Twin Cities, MN
    Thank you to this community! I lurked here a lot while I was shopping. When I tried to start the car and everything went haywire I could not believe how powerless I felt, pun intended. After a lifetime of diagnosing car problems based on sounds and the way the key turned Etc, it was really strange to have literally no idea how to figure out what was wrong. If I hadn't been in such a hurry, I might have been calmer and more able to research. But being 40 miles from home and due at school was too much stress. Glad i could come here!!
  2. PriusPaddler
    PriusPaddler Member
    119
    22
    Twin Cities, MN
    Detached. One thing to be grateful for.
  3. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    A GOOD battery charger would cost about $55 in MSP, a friendly neighbor probably has one you can borrow, especially since you cannot "jump" start a Prius with lots of amps that might scare off some people.
    All you need to do is slow charge the 12v battery over night, there is a "jump link" under the hood and a decent ground on the strut tower nut nearby so you don't have to have the hatch or door open to access the 12v.
  4. PriusPaddler
    PriusPaddler Member
    119
    22
    Twin Cities, MN
    That will go on my Christmas list. I do have a gigantic charger that I usually use for marine batteries, but it's been acting up lately and I don't dare use it on this car. Will keep my eyes out for a Black Friday deal or see if Santa can bring one. Good idea!
  5. JC91006
    JC91006 Senior Member
    16,498
    8,408
    You'll want a battery charger that charges agm batteries at 4 amps to 10 amps. Nothing higher
    SFO likes this.
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    On the bright side, welcome to PriusChat! You should know that the Prius makes a good emergency power source, too: it cycles on and off as needed to keep the battery properly charged.
  7. PriusPaddler
    PriusPaddler Member
    119
    22
    Twin Cities, MN
    Thank you. Will search forums for recommendations.
  8. PriusPaddler
    PriusPaddler Member
    119
    22
    Twin Cities, MN
    FYI - I left the car in "ready" mode in the (detached) garage for 12 hours after I got home. If I ever have to do that again, I will remember to turn off the cabin heat!! I had a window down all the way, and it is Minnesota, so it wasn't too warm in there... but it could have been under different circumstances.
    Now - that really screwed up my mpg!! Oh well, lesson learned and hopefully no permanent harm done!
    Thank you all!
    bisco and Prodigyplace like this.
  9. JC91006
    16,498
    8,408
    At least all the little critters that sleep in your car were nice and warm.
    Raytheeagle and Prodigyplace like this.
  10. PriusPaddler
    PriusPaddler Member
    119
    22
    Twin Cities, MN
    PLEASE tell me you are joking! Prius replaced a Corolla and there WERE critters in that car regularly. I spent a weekend trying to add screening over every possible entry point and they still got in. Finally learned to leave the car in RECYCLE air just before I parked. That closed a plastic cover over an air vent behind the glove compartment and seemed to prevent them from getting in... as long as I remembered to do that.
    I hope like heck the Prius has a better design and that I will NOT find "evidence" of critters!
  11. JC91006
    16,498
    8,408
    I'm just joking. I've never had a critter in mine
  12. PriusPaddler
    PriusPaddler Member
    119
    22
    Twin Cities, MN
    Whew! Good to know... my detached garage is full of mice and chipmunks. We have a truce declared but for the car cabins!!
  13. dolj
    dolj Senior Member
    7,789
    3,942
    Wellington, New Zealand
    JC maybe joking, but it can be a problem. @cyberpriusII can tell you all about what she'e done to thwart critters setting up home in her Prius.
  14. RedUgPri
    RedUgPri Junior Member
    17
    NY
    Also make sure that the doors are always closed tight. I killed my battery the first week I owned the car by not closing the hatch back all the way.
  15. 05PreeUs
    1,097
    563
    MSP
    I would check for an aftermarket starting system or alarm, they are notorious for having high drain with the key off!
  16. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Maintenance required light comes on, only when the car is due for an oil change.
    Other problems could be what's causing the issue.
    The maintenance required light could be a coincide with what she's experiencing now
  17. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Leaving the car for 8hours with READY to charge? I'd suggest she gets a small aux battery charger.
  18. 05PreeUs
    1,097
    563
    MSP
    See post #23 ;)
  19. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Seen!:D
    05PreeUs likes this.
  20. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,139
    1,601
    Iowa
    I hate meeces to pieces. If you need more, ask. I am going out in the next 20 minutes to set four traps...
