Brake Service Dealership or Non Dealership
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sguerra923, Nov 17, 2017.
  1. sguerra923
    sguerra923 Junior Member
    48
    San Diego
    Hi everyone! Quick question, I'm about due for a brake change pads etc. I was curious should I take it to the dealership or a regular shop? I believe the dealership quoted me around $300 for new pads etc. But I also need to do my brake fluid.. How much cheaper would it be at a regular shop? And worth it to take it to a regular shop and them using good pads etc? Also, does anyone know an estimate on how much the dealership charges for brake fluid service? Thanks in advance!
  2. Prodigyplace
    12,709
    11,847
    Central Virginia
    @Mendel Leisk , what do you think? You know the brake details.
    sguerra923 likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The official way to bleed the brakes uses the techstream software, it is one of the few repairs I would recommend the dealer do.
  4. sguerra923
    48
    San Diego
    Do you know how much the dealership charges for bleeding by chance?
  5. Mendel Leisk
    42,219
    There is an official way to change the brake fluid, without techstream; I'll post an attachment from the Repair Manual, plus the brake inspection, pad change. It might be if you're doing something like master cylinder replacement or overhaul, then you must have Techstream, not sure.
    For regular brake fluid replacement, @NutzAboutBolts video (in maintenance sub-forum, pinned at top) on brake fluid change, it's invaluable. It's not that hard, within scope of DIY. You just have to be careful to put the car in "invalid mode" at the outset. My wife and I bumbled through it, in maybe an hour. The only comments I'd add:
    1. The bleed sequence in Repair Manual (per attachment) is front/right, front/left, rear/left and rear/right. They do it a bit different in the video, all works out the same.
    2. They use motorized suction in the video, but it's not mandatory: a syringe with thin tube extension is all you need for basting fluid out of the reservoir, and for the caliper bleed bolts you just need to run tubing to some catch jar. It IS handy to have the correct attachment for pushing the hose onto the bleed bolt, to make it stay on there.
    3. You'll need about 2 pints of DOT 3 (Toyota has some, likely your best bet for 100% compatibity). Use up about one pint on the front, between basting out the reservoir and refilling, and bleeding the front two calipers. Then use most of the second pint on the rears, which are easier, due to motorized pump. Try to end up with a little in reserve, for top up a day or two later.
    4. Note fluid level in the reservoir at the outset. The level will sometimes drop, from before you open drivers door, to after (opening driver's door activates a pump, drops level a bit). Note both levels, and aim to finish up with the level per the lower level, when you're done. Again, hold a little in reserve, for fine tuning as needed, a day or two later. If you still have some left, I would recycle it with some waste engine oil: once the bottle is open, you don't want to store it for long, and kind of pointless.
    5. Pay special attention to the technique for bleeding the front brakes, in the video. It's old-school, and tricky. Better to close the bleed bolt too soon than too late. Just repeat a bunch of times, quick open/close.
    When doing brake pad change the fronts are pretty much conventional. On the rear, you have to pay a little attention: ensure the piston orientation is per the attachment, and is well seated in that orientation before parking brake is applied. Also, it's safest to disconnect 12 volt neg cable at the outset, leave it off until done.
    An independent mechanic could do all this, if he/she is conscientious, reads through the attachments, watches that video. If it's someone who brushes over your concerns, says they know better, I'd have second thoughts though.
    #5 Mendel Leisk, Nov 17, 2017
  6. Mendel Leisk
    42,219
    So is the dealership charging $300 for just the parts, and is that front and rear, or front only? And what's "etc", is that rotors (which likely aren't needed). Or is that parts and labour? And what is "believe": you have a vague recollection, you do remember, you have something in writing? Ok, I'll shut up on that, lol. Do clarify: what they've quoted, and for what specifically.
    Regarding "good pads etc", likely the kosher Toyota pads are your best bet.
    sguerra923 and Prodigyplace like this.
  7. sguerra923
    48
    San Diego
    I apologize for being vague but I attached the estimate. Seems like it's just front with machine.
  8. bisco
    52,740
    how many miles on her?
  9. Mendel Leisk
    42,219
    Unless you're feeling pulsation, I would waive the machining (of rotors). It's not needed, costing you, and just thinning the rotor.
    $200 would be reasonable, to just install new pads/shims, and lube the caliper pins. The parts, pads and shims, are about $100. You could waive the replacement shims too, if the current ones are in good shape.
    And I need to apologize, for being snippy. :oops:
  10. sguerra923
    48
    San Diego
    She's has close to 90k.. This will be her 1st time getting her new shoes
  11. sguerra923
    48
    San Diego
    Oh no worries, no need to apologize you're right definitely more details would help especially when it comes to cars. Lesson learned on my side and I didn't take your response in any negative way
    Sorry for the newbie question but is thinning the rotors bad in the long run or is it ok for its 1st time getting machined?
  12. Mendel Leisk
    42,219
    Well, the less they're machined the better. The Repair Manual, and old-school, would be to check rotor against spec's with a dial indicator and micrometer. You can DIY that very easily, with an outlay of $40~50. You get a dial indicator with magnetic base, mount it on the shock column, finagle the arms and elbows so the dial gauge presses on the rotor, then rotate the rotor, watch how much deflection there is, compare to spec. With the micrometer you just take spot measurements of thickness, around the circumference, compare with spec, both for being above min thickness and not having variation more than spec.
    Doing that occasionally, I've NEVER seen a rotor out of spec. And yet: the dealerships try to sell you on machining, with every visit. I'd suspect because it's quicker than checking.
    Bottom line, if you're not noticing any odd pulsation when braking, there's no need to do anything to the rotors. The thinner the rotor is, the more prone it is to crack, and the more it'll heat up, less mass.
    sguerra923 and Raytheeagle like this.
  13. Mendel Leisk
    42,219
    The other reason for machining, I think: it's impressive, looks like something significant was accomplished, worth paying extra.
  14. bisco
    52,740
    at 90k, maybe just replace the discs. what the price diff?
  15. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    You can turn the rotors if it’s the first time. There’s a minimum thickness spec stamped on the rotor. You can use a micrometer gauge to check the thickness of the rotors. Like @Mendel Leisk said, a dial indicator can measure the run out for the rotor to make sure if it needs to turn or not. Usually if you do it at the dealership, they recommend it. I would also recommend it since I’ve replaced only pads before and then had to turn the rotors later on because it was pulsating when I step on the brakes.
    As for the brake flush, I recommend you doing it yourself if you’re mechanically capable. It’s not hard and require not a lot of tools. You can check our YouTube video for tutorial on it. GL :)
    frodoz737 and sguerra923 like this.
  16. sguerra923
    48
    San Diego
    Dang that would be cool if you lived near the San Diego area.. I would pay you for the bleeding lol.. Unfortunately I don't have the tools to do it..
  17. NutzAboutBolts
    1,756
    1,784
    Bay Area
    for the amount that they charge you to do the flush, you could buy your own tools and do it yourself and save $. All you need are jack & jack stands, 8 and 10mm wrench, and 2 bottles of Dot 3 brake fluid.
    Here's the video to help you if you need :)
  18. Mendel Leisk
    42,219
    You would be ok if you have basic tools, a concrete slab, floor jack and four safety stands. With that and a bit of tubing and a syringe of some sort, and some sort of catch bottle (Kirkland mayo jar, in my case), you're set:
    @NutzAboutBolts gave me the pep talk, I went for it, worked out fine. Watched the video a number of times, really helps you see how it goes, hands on, that it's doable. (y)
    Raytheeagle and NutzAboutBolts like this.
  19. Mendel Leisk
    42,219
    One of these is really handy, really the only brake bleed specific item, something you can get at automotive stores. I borrowed mine from my Mighty-Vac kit, which I didn't need, lol:
  20. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    So, any competent mechanic can get the parts and tools needed, competent.
    The chances of the Toyota mechanic being competent are 50-50, if you have someone you know is competent, great, lucky you, you pays yer monies, your takes yer chances.
    The Toyota dealership will stand behind the work, chances are the mechanic will have done a hundred of them already, an independent will be doing it for the first time, it’s not a 67 Chevy, it’s a walking talking computer.
