New Owner 2017v4. What's this noise??
Discussion in 'Prius v Technical Discussion' started by Agusto2017, Nov 17, 2017.
  1. Agusto2017
    Agusto2017 Junior Member
    42
    Waterville, Ohio
    2017 Prius v wagon
    Car has been in garage for 4 hours. Temp outside 54 degrees.
    I've had Hazel for 2 weeks. 400 miles on her.
    Husband yells, what's that noise?
    See recording:
    It's coming from under the rear left side...I'm guessing
    I decided to take it for a ride. I went inside to get the key. As soon as I got near the car, with the key, the noise stopped.
    Your thoughts....
    I'm a new owner to the Prius world. Any help is appreciated!
    52,391
    congrats and welcome!
    emissions evap check. nothing to see here. or, it could be christine.:sneaky:
  3. Agusto2017
    42
    Waterville, Ohio
    2017 Prius v wagon
    Thanks for the reply Boston Bisco.
    I've never heard this before, and it stopped right as a brought the key out.
    Just a coincidence?
  4. bisco
    52,391
    that i'm not sure of, since i've never brought the key out when it's happening. it is possible, i suppose, that when it detected the key, it shut down, in case you were going to start it.
  5. Agusto2017
    42
    Waterville, Ohio
    2017 Prius v wagon
    Thanks again. I have SO much to learn. I hope this old dog can learn new tricks.
  6. bisco
    52,391
    you will, it takes time with these high tech machines. all the best!(y)
    Agusto2017 likes this.
