Tire and Traction Question
Discussion in 'Gen 4 Prius Technical Discussion' started by IndyMelissa, Nov 19, 2017.
  1. IndyMelissa
    IndyMelissa Junior Member
    Basic question -
    Ran over a wicked pothole and lost the front passenger tire last night. The tires have just under 15k miles on them. Do I get one or two? Since it's still under warranty, should I go to the dealer or can I go to any tire store that has a match? (I still need to look to see what tire brand I have.)
    Speaking of brand, would that affect my traction? My car is quick to turn on the ABS - run over a pothole or manhole cover and it'll turn on. Is this normal? It makes me nervous going into a Midwest winter. My first gen didn't act that way, but that was a very different car. (I thought I had seen previous posts about ABS so feel free to link me to previous discussions.)
    (I've been consulting PriusChat for many years, but I am especially grateful for it now to be able to ask basic questions after losing my father this summer. Thanks for being a great bunch of Prius lovers! :) )
  2. JC91006
    JC91006 Senior Member
    16,736
    8,549
    If the car has under 15k miles, you probably can get away with buying 1 new tire.
    Most cities will pay for pot hole damages, you can submit a claim to them for payment (if your rim is damaged too)
  3. booke02
    booke02 Active Member
    391
    415
    Israel
    Assuming that you have a full-size spare, I would use it to replace the damaged tyre. Alternatively, just buy a matching tyre. 15K is almost new, so I wouldn't worry about mixing completely-new with almost-new.
    RCO and krmcg like this.
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    If you just buy 1 make sure you get the same tire as the rest.
    RCO likes this.
  5. IndyMelissa
    Not a full size spare unfortunately.
    So I don't need to go to the dealer to get it replaced? Unless that's the only way to get a match?
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    Beginning with the Gen 2 Prius, the ABS has been twitchy when running over bumps, etc. The bouncing causes weight to come off the tires simulating loss of traction. So your experience sounds normal. I recommend testing the traction/ABS on snow/ice under safe conditions just to convince yourself it will work when needed. Regarding replacing your busted tire, you should always match (manufacturer/model) the tires on a single axle. So fronts should match, as well as rears. Sizes need to match front to rear also. A tire shop will measure the tread depth and recommend if you need to replace both fronts or just one, keeping the "good" one with 15K miles. As far as "warranty" from Toyota. They don't warranty tires ever. Tire are only warranted from the manufacturer. And unless you had road hazard coverage (unlikely on a new car) you won't get any coverage even from the tire manufacturer.
    RCO likes this.
  7. JC91006
    16,736
    8,549
    A dealer may not have that tire. It's probably better going to a national tire chain, they will have it or will be able to order it.
    padroo likes this.
  8. Mendel Leisk
    40,974
    What's the tire? If it's Bridgestone Ecopia EP422 Plus, the ones that came with the car very like are made in Japan, and have a moderately different tread pattern (and wear index) than the US and Mex version. The latter two are different than each other as well. If this is your case I'd try to stick to the made in Japan version.
    And a :p to Bridgestone for this mess.
    RCO likes this.
  9. fuzzy1
    10,337
    The tires are generally not covered by the car warranty, but are separate.
    And factory tire warranties generally do not cover road hazards. BTDT.
  10. Mendel Leisk
    40,974
    No, any tire shop is good. Ensure they check the rim too, if it's bent then it's back to the dealership parts department. As fuzzy noted: road hazard isn't warrantied. Maybe the city though.
    RCO and Prodigyplace like this.
  11. esfishdoc
    esfishdoc Junior Member
    26
    45
    ESVA
    You might find the cost of one rim at a dealer is close to the cost of 2 rims and 2 tires at a national shop.
    RCO and Mendel Leisk like this.
  12. Mendel Leisk
    40,974
    A while back I purchased 4 gently used PIP rims for $400 (US) (including shipping, from Southern California to BC). Earlier, I'd checked with a local dealership parts department, their best price: $495 (Canadian) apiece.
    I kind of miss the old days, when stamped steel rims were silver painted, had a chromed centre cap and looked half-decent, and expectations were lower: they're just wheels afterall. They're cheaper/easier to make, comparable in weight.
    RCO likes this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The ring of MagAlloy bling! ;). Aluminium is costly to mine, to recover and ultimately to purchase as a wheel. Sure, they will have advantages over steel, but at such a high cost! Meh!
    Adam1a and Mendel Leisk like this.
