smart key module location?
Discussion in 'Newbie Forum' started by sherrydb, Nov 19, 2017.
  1. sherrydb
    sherrydb New Member
    arkansas
    i have 2005 prius smart key, door lock/ unlock inop. only starts with fob in dash slot. dealer trouble shot some and said it might be the smart key module. quoted about a grand to repair. i found a used smart key module with key fob online supposedly out of a working system.what i cant figure out is where the smart key module is on the vehicle to attempt to replace it.anyone have any insight?
  2. JC91006
    JC91006 Senior Member
    16,759
    8,562
    Did you check the switch/button under the steering wheel? Make sure it's clicked on. Did the fob batteries get checked?
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Welcome to Prius Chat, Sherrydb. No doubt there'll be a few song to answer your question soon, but @elktroingeneur may be the guy to guide you along with this. :)(y)
  4. Prodigyplace
    12,516
    11,739
    Central Virginia
    I think you meant @Elektroingenieur
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    My 2009 Gen II started exhibiting problems with SKS system, which replacing fob batteries didn't fix. Solution was replacing bad 12V AuxBattery! (it usually is!) ;)
    Bluegrassman and Prodigyplace like this.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,415
    3,286
    Madison, Wisconsin
    Smart key module is in the hatch area.
    Driver side near the hybrid battery.
    Take out the rear storage tray.
    You'll see it on the left.
    RCO likes this.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Thanks, you're right but I was (and still am) unable to edit my initial reply. The was nothing displayed as an option for Elektroingenieur so I went from memory hoping to correct it later. Now if his handle was Electroman I'd be able to remember the spelling effortlessly. :rolleyes:
    Prodigyplace likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Oh yeah, it should have read... a few along to answer your question... :whistle:
  9. Prodigyplace
    12,516
    11,739
    Central Virginia
    I thought you took up singing. :eek: ;)
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Only when interrogated by the wife, then I'm singing like a choirboy! :ROFLMAO::ROFLMAO:
    #10 RCO, Nov 20, 2017
    pilotgrrl and Prodigyplace like this.
  11. Elektroingenieur
    2,515
    3,282
    Three Touring
    I wonder if @sherrydb and @ericbecky may be referring to different parts.
    Toyota’s Electronic Parts Catalog for the 2005 Prius shows, in Figure 84-20 (Wireless Door Lock), that the Smart Key Computer Assembly (PNC 89990A) is in the left side of the instrument panel. The Repair Manual and Electrical Wiring Diagram call this part the “Smart Key ECU,” and there are many previous PriusChat threads about its replacement and programming. The Door Control Receiver (PNC 89741) is in the rear of the car, as is the Luggage Electrical Key Oscillator (PNC 89993). Figure 84-24 (Anti-Theft Device) shows that the Transponder Key Computer Assembly (PNC 89780) is in the right side of the instrument panel.
    Without further diagnosis, I couldn’t say which of these parts, if any, might be defective. It could also be a wiring or connector problem—or just a faulty key fob or key fob battery, especially if there is only one key fob, though I’d hope that the dealer would have checked these basics before recommending an expensive repair.
    If reading through the PriusChat threads doesn’t provide enough information, I suggest spending $15 for a subscription to techinfo.toyota.com, where you’ll find not only the Repair Manual and Electrical Wiring Diagram, but also, in the technical training section, Smart Key System: Course T973B Handbook, with an entire section (20 pages) dedicated to the 2004–2009 Prius.
    (And just for the record: Elektroingenieur is easier to type than 電気エンジニア, isn’t it?)
  12. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Personally, I'd vote for 電気えんじにあ.
  13. Free PNG
    Free PNG New Member
    United States
  14. HarvBD
    HarvBD New Member
    Surrey
    08 Prius (w/o smart key). Took out the storage tray. Don't see any modules. Based on diagrams, it's above the gas filler tube?? How do you access door control receiver? Only have one FOB. It stopped all remote functions. New batteries. Lights flash with any button pushed. 12v batt is strong. No error codes anywhere via Techstream. Doors lock/unlock normally from inside or manually with key.
  15. Prodigyplace
    12,516
    11,739
    Central Virginia
    @HarvBD
    We do not play guessing games here.
    Are you in Jamaica, Canada, Indiana, or North Dakota?
    Surrey (disambiguation) - Wikipedia
  16. ericbecky
    4,415
    3,286
    Madison, Wisconsin
    Is the Smart Key button near the drivers knee in the dash pressed Out.
    Or is it pressed in.
    It is unlikely that the module in the back has gone bad. Possible. But unlikely.
  17. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    He can't be that sexy in this forum. He keeps it down here out of respect for our family friendly atmosphere.
  18. kenmce
    1,544
    515
    NY
    Normally that is a sign of a weak fob battery. First thing, try all the easy stuff. New fob battery, check the SKS on/off button, check all the things people suggest up thread. My local dealer would not hesitate to sell me a thousand dollars worth of unneeded parts when all I needed was a ten dollar fob battery. Try whatever you can do yourself first.
    Oh, and PNG , your situation is different enough that you may want to start a new thread.
    #18 kenmce, Oct 13, 2020
