Carista pro no longer $20
Discussion in 'Gen 4 Prius Main Forum' started by Junepak, Jul 14, 2016.
  1. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    What plug-in are you using? Odd that the seat belt chime didn't take...was it not an option?
  2. GREEN BAE
    GREEN BAE Member
    61
    49
    Winter Garden, Florida
    2024 Prius Prime
    XSE
    carista I enabled and disabled several times to no avail. will try a different app as long as it doesn't cost me another $10 bucks.
  3. ssdesigner
    304
    241
    california
    2013 Aqua
    You need to pay at least the $20 pro fee for certain options on Carista. Once you do that, it all comes down to the plug that you're putting into your Toyota. No reason that it shouldn't work...but, all are different.
  4. GREEN BAE
    GREEN BAE Member
    61
    49
    2024 Prius Prime
    XSE
  5. mrbillz
    mrbillz Junior Member
    ... So all of you entrepreneurs who plan to cheat the system and think you're somehow going to get even with Carista by "subletting" your paid app will likely just screw the rest of the folks who paid for the lifetime use when Carista just revokes everyone' lifetime subscription, or severely hobbles it. C'mon people! Carista is within rights to change their business model as they see fit- Even at $10 for a week, it is still a bargain - unless you're just greedy.
    It is apparent that Carista does monitor the stats on the usage of the device, and the software license almost certainly prohibits sharing functionality. Maybe the best option would be for Carista to just lock out YOUR device for violating terms when the see that the device is being used on multiple VIN's. Why not just be glad you got a device / service when it was a bargain and be content that YOU can use it for your lifetime, and not screw the rest of us who still might be considering this device. For me, $10 to change all the settings I want for a week is still a bargain.
    pjm877 and kithmo like this.
  6. krmcg
    2,592
    2,392
    Whittier, CA
    I'll let you be in charge of you.
    ssdesigner likes this.
  7. ssdesigner
    304
    241
    california
    2013 Aqua
    If they lock me out, they lock me out.
    And if they do, I'll be sure to come here and let you know so you feel better.
  8. HobbsNick
    HobbsNick Member
    107
    156
    Newcastle, U.K.
    If you get the app through the Apple Store you are licensed to us it on 5 different devices, I would be surprised if the software licence restricted you on the amount of cars you can use it on. I would of thought that if it did it would ask for the vin for the car you intend to use it on.
    krmcg and ssdesigner like this.
  9. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    Just a heads up, if they remove the old pro support that you paid for completely you WILL be able to submit a refund request to itunes for "app has significantly changed functionality since I paid for it". Android, I'm not sure what you could do.
    krmcg and HobbsNick like this.
  10. ssdesigner
    304
    241
    california
    2013 Aqua
    Awesome! Thanks!
    Actually there are different choices when you go here:
    Report a Problem
    The most appropriate looks to be "Item Opens But Doesn't Function As Expected"
  11. liquidtenmillion
    261
    194
    Easley, SC
    Yeah that's the right one. If you google around you see people who are getting refunds on pokemon go in app purchases since a recent update apparently removed some features.
  12. luiset83
    luiset83 Member
    141
    78
    2023 Prius Prime
    XSE
    Are there other alternatives to carista to customize the settings not based on a subscription model? Tried sideloading the old app but the fixed price feaure purchase is not available anymore on the app
  13. NeilPeart
    NeilPeart Hybrid & PiP Convert
    75
    69
    Bay Area, CA (USA)
    Yes. I use the following and I can change the reverse beep, the seatbelt beep and have a look at many realtime visual stats and other metrics (in addition to deciphering the P codes if the car has the check engine light). I used it to back up my hunch that the inverter failed on my wife's 2010 Prius.
    App (full version is $5 forever and it's updated regularly):
    Torque Pro (OBD 2 & Car) - Android Apps on Google Play
    I install the app on my Android phone and an old Nexus 7 2013 tablet I picked up for $50 - that tablet makes it easier to see the information on the fly when I am diagnosing.
    My preferred OBDII bluetooth device ($50):
    ScanTool 427201 OBDLink LX Bluetooth: Professional OBD-II Scan Tool for Android & Windows (won't let me link to Amazon)
    A cheaper ($20) OBDII that my friend uses that seems to work just as well (perhaps a bit slower communication to device):
    BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices (won't let me link to Amazon)
    #33 NeilPeart, Jul 21, 2017
    RCO likes this.
  14. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
  15. SFtroll
    SFtroll Junior Member
    Cedar Creek, Texas
  16. Fester
    Fester Active Member
    201
    198
    Ohio
    Do you happen have the scangauge code for the reverse beep? Thats the only really change I'd like to make for my 2017 Prius 2.
  17. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    You'll have to Google it, I printed it out but didn't keep it. IIRC you program it like an X Gauge, but it really only is used once.
