Official (OEM) Toyota Prius 2016 (Gen 4) oil-change instructions
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Mar 4, 2016.
  1. ETP
    ETP 2021 Prime(Limit),Highlander HYB Plat,B52-D,G,F,H
    2,799
    1,170
    Auburdale FL
    It will start. Wait for it.
  2. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    If you turn the heater on, the engine will start.
  3. WilliamP
    WilliamP Junior Member
    33
    MN
    Are there really regular Phillips head screws holding on the panel? I live in the rust belt, and those things go bad fast.
  4. Mendel Leisk
    38,241
    Take a look?
    The screws employed on 3rd gen are coarse thread, screw into nylon block inserts, can be driven either with 10 mm hex socket or a medium cross-head screw driver.
    Their rust resistance is next to nil. :(
  5. ETP
    2,799
    1,170
    Auburdale FL
    So did anyone do the on a Gen 4??????
    I see the gen 3 instructions.
  6. Mendel Leisk
    38,241
    First post is 4th Gen instruction is it not?
    Valiant V likes this.
  7. ETP
    2,799
    1,170
    Auburdale FL
    Must be blind. I do not see it in the first post.
  8. ETP
    2,799
    1,170
    Auburdale FL
  9. Estela13
    Estela13 Member
    New 2017 owner here :)
    5K mike oil change I have a question
    Previous car 2013 Prius v
    So husband changed oil today and the oil filter on was different than my replacement I’m confused.
    Searched the web the filter on car looked like the Prius c filter
    Thanks for your help in advance
    ~Estela
    UltraJetRefill likes this.
  10. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
  11. Estela13
    Estela13 Member
    That is what I had on hand to change but when taken off it did not match what the car had
    ~Estela
  12. Mendel Leisk
    38,241
    If you must have the car, say to get to the dealership for the right filter, just reinstall the old one, get to the dealership and back, unscrewing the housing once more (you'll lose only about a cup), replace the filter, top up for that lost cup.
    What interval are you using? if say only 5000 miles, then I'd be inclined to just leave the old filter in till the next oil change.
  13. Estela13
    Estela13 Member
    5K I drive 10K a month, that’s what the husband suggested he put the filter back on , I’m just puzzled I looked up part on Toyota website
  14. Mendel Leisk
    38,241
    In that picture, 04152, the actual filter with replacement O-ring, is what you want. Hands-down the best approach to getting the right parts is to go to a dealership parts department, and just tell them you need oil filter for such-and-such model.
    RCO and Prodigyplace like this.
  15. Prodigyplace
    11,696
    11,317
    Central Virginia
    I ordered mine online from a dealer
    Toyota Parts and Accessories | MetroToyotaPartsNow.com.
    You select your vehicle and then search for the part. Ordering several parts distributes the shipping expense.
    GaryD1 and RCO like this.
  16. Mendel Leisk
    38,241
    I'm at dealership twice yearly anyway, getting bulk oil, maybe washer fluid, casting sideways glances at the new car's. :whistle:
    RCO likes this.
  17. Prodigyplace
    11,696
    11,317
    Central Virginia
    No wonder you do not like the look of the Gen 4!
    You're looking at it wrong!
    Steve Jobs, is that you?
    RCO likes this.
  18. Mendel Leisk
    38,241
    There's never a gen 4 in the show room. Last time I was in there they did have one demo on the lot. My understanding, from local dealerships, you have to pre-order.
  19. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I just did oil change in 2016 Gen 4 Prius, I just used one of my oil filters that I had been using for my 2015 Gen 3 Prius. I didn't notice any difference in them. The Gen 3 oil filter wrench worked also.
    Mendel Leisk and Prodigyplace like this.
  20. GaryD1
    302
    138
    Seagrove, NC
    I was looking for the inside cabin filter, didn't see it on lists but sure it is?
