ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    make sure you order some double sided tape.
    HPrimeAdvanced likes this.
  2. bwilson4web
    16,197
    I'm more of a blue masking tape fan to avoid sticky residue.
  3. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    3M makes a double-sided "clear tape" that leaves no residue. I even use it to anchor Christmas lights to my stucco! It has red separator tape, and is somewhat expensive. It's gummy, and I think it may be silicone based. It's stretchy and about 1 inch wide, called 3M VHB.
  4. priuscatprimeguy
    2,730
    2,640
    to match the color of your car? or is your car not blue?:p
  5. priuscatprimeguy
    2,730
    2,640
    Whelp today I charged my car for 10 am departure no climate prep left at 12:15pm recorded the incident but turned off recording when after a few minutes ICE did not kick in, then I set cruise control and ICE kicked in slowed down for traffic light and ICE shut off and went back to EV resumed speed cruise control, ICE kicked in again this phenomenon kept repeating itself for several traffic lights, temperature is 48F Edit: turns out the recording did not stop when I thought I ended it. Uploading to youtube now.
    #745 priuscatprimeguy, Dec 2, 2017
    bwilson4web likes this.
  6. priuscatprimeguy
    2,730
    2,640
    Also, Climate was off during this trip
  7. bisco
    51,851
    is it only when you set cruise?
    priuscatprimeguy likes this.
  8. priuscatprimeguy
    2,730
    2,640
    seems to be the case, when I brake and cruise is off it goes back to EV mode, then when I resume cruise ICE comes back on, this is the first time I have noticed this
    bwilson4web and HPrimeAdvanced like this.
  9. priuscatprimeguy
    2,730
    2,640
  10. bisco
    51,851
    have you ever driven without cruise and had the ice come on, unexpectedly?
  11. priuscatprimeguy
    2,730
    2,640
    yes
  12. bisco
    51,851
    kinda takes it out of the equation then.
  13. priuscatprimeguy
    2,730
    2,640
    here we go, it's long because I thought I turned off recording when ICE did not kick in, then when I "turned" off recording ICE kicked in, but thanks to my friends ineptitude lol, it still kept on recording.
  14. priuscatprimeguy
    2,730
    2,640
    apparently it started recording after i returned from my trip, so no evidence, sorry I'll try to do better next time:cry: Edit, found the missing files (2) Uploading to YouTube now. please wait
    #754 priuscatprimeguy, Dec 2, 2017
  15. bwilson4web
    16,197
    We're still trying to figure out how to replicate the symptom at will. In this case, the cruise control seemed to have an effect and was part of the two times I've seen the symptom.
    Temperature?
    Good news, the dash cam showed up today. I've got to get a "TF" flash card; work on mounting, and; test operation. FYI, I typically use video editing to align, trim, and reduce the size.
  16. priuscatprimeguy
    2,730
    2,640
    yeah, still trying to figure out Pinnale 21.
  17. priuscatprimeguy
    2,730
    2,640
    here's the video of when I turned off the video because I thought ICE was not going to come on, lol when in fact ICE came on at the time I stopped the recording> disregard the audio, nothing to to hear there, lol
  18. priuscatprimeguy
    2,730
    2,640
    as shown on the dashboard 45 F
  19. priuscatprimeguy
    2,730
    2,640
    here's the video that I thought did not record
  20. The video that you thought that you did not record says: "This video is unavailable."
