How to turn off spare fob?
Discussion in 'Prime Technical Discussion' started by mkwan723, Dec 2, 2017.
Tags:
  1. mkwan723
    mkwan723 Junior Member
    32
    Ottawa
    does anyone know how to turn off the spare fob in order to save the battery? Thanks in advance!!
  2. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Dang I just learned this. But I can’t think of it off the top of my head.
  3. bisco
    52,351
    take the battery out.
    priuscatprimeguy likes this.
  4. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Press and hold lock button while pressing unlock 2 times
  5. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
  6. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    If you an oldish am radio. You can set it on the handle of the door and hear the signals communicating if anyone gets really bored and try’s it. I thought it was cool to hear. Especially if you walk up with the wrong key, the car kind of “barks” at it.
  7. mkwan723
    32
    Ottawa
    It works. Thanks Dave!!
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Do you need to change the vehicle in your profile ?
    A '12 C is NOT a gen 4 vehicle.
  9. Mendel Leisk
    41,865
    I've gotta try this, thanks.
  10. bisco
    52,351
    did you try it? the o/p's two threads have me totally confused.
  11. Mendel Leisk
    41,865
    No, I've got an AM/FM radio in the garage though. Should get on it.
    dave3057 and bisco like this.
  12. Prodigyplace
    12,657
    11,827
    Central Virginia
  13. Mendel Leisk
    41,865
    Could hear a scritchy sound a split second after each button push on the fob, either lock or unlock. Tune to AM dial, between stations.
  14. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    You can also lock the doors and than wait a few seconds, and as you walk up to the car, watch the little red LEDon the fob, it will flash as you get close, and you will hear the communication.
  15. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    This is a low tech way of testing the door oscillators. It does the same for the rear hatch, with the exception that it doesn’t start trying to communicate with the key until the button is pushed on the hatch.
