  1. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    seems like its the same maker then? like the ebay sellers sell someone else`s items... they got the exact same price and exact same ad... weird. Im pretty sure its just "re-sellers" then, they get the item from whichever company makes it and sells it for them. And they claim its real. If its not and buyers can prove it, the whole business will go right to h*ll... so yea. If i could i wouldve bought it and checked it out, Valenti lights should have alot of brandings showing the "ECE marking, SAE and DOT marks".
    Xterra72 likes this.
  2. MagnusAG99
    673
    521
    Norway
    Im installing DRL`s on my car... but ive stumbled on to a problem, the blue wire needs to be connected to "KL15 or ACC plus". Where the heck is that? I see on the first illustration it looks like the black is on negative and red is on positive as expected (lol), and the orange wire is connected on to the parking lights at front so the control box knows when the headlights is on. and blue is also on negative as the black on the battery. i would guess the blue is the wire that feels if the engine is running and charging the 12V battery or not? is the blue supposed to get connected to the negative pole on the battery with the balck or? anyone who got any experience with this...[​IMG][​IMG]
    ckam1989 likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Any power source/wire/fuse that's only on when in Ready mode. I tap the inverter coolant pump fuse (red, 10amp) in the engine fuse box.
    MagnusAG99 likes this.
  4. MagnusAG99
    673
    521
    Norway
    alrighty, thank u dude, ill get it wired up tomorrow and hopefully shwo the results.
    xliderider likes this.
  5. MagnusAG99
    673
    521
    Norway
    is that the IGCT NO.3 fuse that then?, it says "Cooling system" in the handbook (directly translated form norwegian) and its a 10A fuse on spot 34 in the engine room. its really the only fuse i could find about any cooling system... i would imagine that gets power in ready mode?
  6. xliderider
    8,140
    3,276
    Honolulu, HI
    I believe it's fuse #25 in your picture, what is that labelled?
  7. MagnusAG99
    673
    521
    Norway
    it Just says "PCU" 10A Inverter and converter. is that it?
  8. xliderider
    8,140
    3,276
    Honolulu, HI
    What's #35, 36, 37, the spare fuses? If not, then it may be #35 I tapped. I know it's the first fuse in a row of fuses on the right side of the fuse box, looking front to back.
  9. MagnusAG99
    673
    521
    Norway
    those r all spare, 35 is 30A spare, 36 is a 15A spare and 37 is a 7,5A spare.
  10. xliderider
    8,140
    3,276
    Honolulu, HI
    Ok, that's it. I know it was inverter related. Use a proper fuse tap.
  11. MagnusAG99
    673
    521
    Norway
    alrighty, ill do that and see if it works (hopefully it will lol)
  12. xliderider
    8,140
    3,276
    Honolulu, HI
    Make sure you put the original fuse in the lower position of the fuse tap, and an appropriately rated fuse for the DRLs sense wire. The lowest rated fuse, like 2.5 amp should be adequate, the blue wire is probably only carrying milliamps of current. It's just used to activate a relay or solid state switch in the DRL control module (black box).
  13. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    I believe this might be a direct fit. Prius G’s And 2nd gen Scion tC. The railing points are pretty much the same. Who’s wants to try first? Lol :cautious:
  14. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Nice find! Don’t you have a tc? You should try it first
    Putu Ariawan likes this.
  15. MPGRaja
    469
    1,680
    Corona
    I have 1st gen tc with FRS sears :p
    granTORRESmo and PutPutMobile like this.
  16. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
    It’s Tucking Tuesday ...
  17. Joe Schmo
    Joe Schmo Junior Member
    52
    Orlando
    Nice wheels! Can you please tell me the make and size? Thanks.
    Burna J likes this.
  18. Gaspeed
    Gaspeed Senior Member
    286
    1,624
    San Diego CA
    It's Wheel Wednesday
  19. MagnusAG99
    673
    521
    Norway
    Burna J likes this.
  20. Tony_uk
    Tony_uk New Member
    Uk
    ----UK----
    Just slowly modding my UK 10th anniversary edition prius only 1000 came out. Ive done some small stuff over time but it' pretty standard looking. I made a vinyl sticker for the interior which is vinyl wrapped and vinyl wrapped the toyota emblem. Ive owned it for about a year now and so far i I like it.
    20171029_131407.jpg 20171206_181154.jpg 20171206_181050.jpg . 20171206_141308.jpg 20171202_130346.jpg
