Wiper blade placement
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Txmama2, Dec 8, 2017.
  1. Txmama2
    Txmama2 New Member
    Hallsville Texas
    I got new blades but the new ones hit each other I moved them so they still work but they are on each other & I don't remember the other ones doing that.. anyone else have this happen or know how to fix it??? I got the passenger side smaller bc the set I got that was recommended was way to long & really hit each other worse than these do
  2. milkman44
    milkman44 Active Member
    591
    386
    Ky
    That's an easy fix, the post for the driver side wiper arm is serrated, take the nut off and pull the arm off the post, rotate the arm up one notch and reinstall.
    Txmama2 likes this.
  3. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    there are dots printed on the windshield for alignment/
    Txmama2 likes this.
  4. Txmama2
    Txmama2 New Member
    Hallsville Texas
    @StarCaller I saw those both are way off I'm going to have my fiance adjust them this weekend if he gets a chance to
  5. Mendel Leisk
    41,822
    For reference, here's what ours looks like. Whenever I've had the wipers off, beforehand I put a little bit of masking tap at the tip, for reference when reinstalling.
    Looks like your driver's side is ok, but passenger side is off by a notch.
    Txmama2 likes this.
