Prius 2011 check hybrid system error
Discussion in 'Gen 3 Prius Technical Discussion' started by Salah92, Dec 8, 2017.
  1. Salah92
    Salah92 New Member
    Pakistan
    after car service, my prius has shown the error of "check hybrid system" and the check engine light turns on after this error it won't be able to run on a battery until I reset .After getting reset, it worked fine for 2 or 3 days but then same error comes up. Please help me out
  2. Mendel Leisk
    42,208
    What was involved in the service? Dealership, or independent mechanic? How many kms on it? Might also have something to do with failing 12 volt battery, is it the original?
  3. bisco
    52,724
    welcome!
    i would go back, tell them the problem, and ask them to read the trouble codes.
  4. Salah92
    Salah92 New Member
    Pakistan
    Service means car wash, thats it. I've checked the battery and its absolutely fine
  5. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Any water get on any electrical connections or is there water in the back of the car near the batteries? Water in the fuse box? Was it raining a couple of days later?
  6. Salah92
    Salah92 New Member
    Pakistan
    Its been 3 weeks since I have washed my car and engine room was not touched during the service. And it wasn't raining.so there is no chance of water in fuse box.
  7. bisco
    52,724
    maybe water got under the hood somehow.
    Raytheeagle likes this.
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Or in the back;).
    Too much of a coincidence and needs investigation prior to additional troubleshooting (y).
