energy draw of heater vs seat warmer
Discussion in 'Prime Main Forum (2017-2022)' started by Nic Steussy, Dec 8, 2017.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    While plugged in I also press Remote A/C before leaving for work for 10 minutes.
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I do that too. That helps if you know you don't have to run the engine and can only run in EV mode and want to preserve your EV range. I have been successful in running in EV mode 98% of the time since my last fill up on February 26th. I still have 430 miles until empty. Here is my tripometer reading as of yesterday.
    #1 in Easley,SC
  3. 4rpr15
    1,056
    375
    WI
    So tell me the times you leave it in EV mode vs HV mode though. I understand the engine running part now. What about highway driving. See it’s easier for you as it doesn’t get too cold in your neck of the woods.
    dalcon95 likes this.
  4. dalcon95
    512
    653
    With your distance you drive, you should be able to drive in EV only on any road or highway. EV is more efficient than HV mode.
    #1 in Easley,SC
    HPrimeAdvanced likes this.
  5. 4rpr15
    1,056
    375
    WI
    I usually go in HV while on the highway. Otherwise I use Remote A/C while plugged in for 10 minutes before and off I go. I was just missing a few things there. Thanks man! Are you considering changing out your wheels. Here’s what I’m looking at. Velox metallic Gray/Black 15”. I’m gonna stock with the stock Dunlop’s for now until after this winter once I see how they do.
  6. dalcon95
    512
    653
    Not right now. I just went with no hubcaps and new center caps. 20170523_110552.jpg
    #1 in Easley,SC
  7. 4rpr15
    1,056
    375
    WI
    I gotta get rid of the hubcaps for sure. I always like the Anthracite/Gunmetal look of rims I guess. At the same time I don’t want to make mine look too ghetto either. I don’t think I’ll do a roof wrap.
  8. dalcon95
    512
    653
    The wheels you have shown look nice. I am not into the black wheels myself. From a distance, the wheels remind me of steel stamped wheels without hubcaps. A cheap look. But some like it though. I am a polished alloy or chrome wheel kind of person.
    #1 in Easley,SC
    HPrimeAdvanced and milkman44 like this.
  9. 4rpr15
    1,056
    375
    WI
    That was exactly my concern. I almost need to look at something like these.
    https://www.tirerack.com/upgrade_garage/BigPic.jsp?wheelMake=Enkei+Performance&wheelModel=EDR9&wheelFinish=Bright+Silver+Paint
  10. dalcon95
    512
    653
    HPrimeAdvanced and 4rpr15 like this.
  11. 4rpr15
    1,056
    375
    WI
    I agree. They are just a cleaner look. Not too silver and somewhat polished.
  12. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Note that the hubcaps likely do improve wheel aerodynamics, and therefore efficiency.
  13. dalcon95
    512
    653
    If they do, I haven't see a difference.
    #1 in Easley,SC
  14. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    0.1% difference probably (but still a gain)
    iPhone ?
  15. 4rpr15
    1,056
    375
    WI
    I almost forgot that I manually have to turn on the setting in climate control that stops the cold air from coming inside each time.
    milkman44 and dalcon95 like this.
  16. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    There's a reason why that automatically comes on during heating - in cold weather, you want fresh, dry air coming in, because the car's cabin is far more likely to be humid as it warms up, with things like snow melt, in winter.
  17. 4rpr15
    1,056
    375
    WI
    I manually turn it on since I use the seat heaters now.
  18. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    Dang, I feel like I need a PHD just to drive to the store.
    jtv, dalcon95 and 4rpr15 like this.
  19. dalcon95
    512
    653
    LOL. You can be as nerdy as you want to be!
    #1 in Easley,SC
  20. 4rpr15
    1,056
    375
    WI
    Hey I forgot to ask if I do not turn my heat on when it is very cold and I just have my seat heater active what do I do when my back window starts fogging up? I still plan on using remote AC 10 minutes prior to departure.
