How much do stock wheels weigh?
Discussion in 'Prime Accessories and Modifications' started by EarthPIG_0311, Nov 27, 2017.
  1. EarthPIG_0311
    EarthPIG_0311 Junior Member
    The 951
    Hello Everyone,
    I'm looking to upgrade my wheels for my Advanced Prime, however I don't want to purchase a heavier wheel. That being said, does anyone have any info on how much the stock wheels weigh? I've researched and haven't found any info but do apologize in advance if this has been discussed before. Thanks in advance to all.
  2. Mendel Leisk
    41,911
    I recently weighed a 3rd gen 15" pip rim, it came in at 18.28 lbs. Would be roughly comparable?
    Chimi1, DickyDck and acceleraptor like this.
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,045
    Keystone State
  4. PavelTune
    PavelTune Member
    65
    Los Angles
    Stock Prime and Gen 4 Rim weights at 16.5lb , combo with toyo nano enrgy 195/65/15 weights at right around 33.5lb
    DickyDck, EarthPIG_0311 and idleuser like this.
  5. CyberDyneSystems
    CyberDyneSystems Junior Member
    Providence RI
    Have you removed the ugly hubcaps yet to reveal the wonderful full alloy rims that reside underneath? Could save you a lot of $$$.
  6. Mendel Leisk
    41,911
    Wonderful? :confused:
    Honda888 likes this.
  7. EarthPIG_0311
    The 951
    Yes, I have. Definitely a temporary solution but I think after some time, I'd want to go with something different.
    Speaking of removing the hubcaps, salesman stated they are designed to produce airflow to keep the regenerative brakes cool and removing could cause over heating. I don't necessarily believe him but wondering if anyone else heard the same?
  8. Tideland Prius
    16,621
    Well considering regenerative braking is done by the electric motors and not the brake pads, I'd say hogwash lol. Logically it doesn't make sense (removing a cover and exposing more of the brake disc and brake pads worsen the cooling availability?!?!).
    The wheel covers are for aerodynamic purposes. More of the space between the spokes that are covered = less turbulent air flow around the face of the wheel. There *could* be some design factor that sucks in the air from the face as some performance cars do but I doubt the Prime's wheel covers do that.
  9. Rashid K
    Rashid K Junior Member
    Costco had Velox rims
    15 apex weighs 14lbs
    16incg apex weighs 16lbs
  10. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Decent thread, I use my 06 wheels for winter wheels and was thinking of getting lighter wheels for the summer wheels and using the origional wheels for the winter tires, then I read this thread a week ago and saw the weight, 16lbs, and decided not to, but these costco suckers are two pounds lighter, the 06 wheels are oxidizing and the tpms are shot, so now, back to new summer wheels. ;)
  11. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    I’m looking at the apex Velox SLGLXX, weighs in 13 lbs. Not a Costco member but will wait a lucrative coupon or discount promo before buying at a big chain tire shop.
    DickyDck likes this.
  12. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Guys,
    Wheel weight is important...
    BUT
    Tire weight is Very Important !
    Rob43
    DickyDck and Mark57 like this.
  13. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    If you're using a salesman as a source of knowledge you're in trouble
    Honda888 and jb in NE like this.
