Part dropped off of 2007 Prius... or not?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dtmm, Dec 13, 2017.
  1. dtmm
    dtmm New Member
    Fort Myers, FL
    I parked my 2007 Prius, turned it off, got out, and when I put my foot on the ground I heard a noise like something dropped out of my engine onto the pavement. When I looked I found this part on the ground under the front of the car near the driver's side wheel:
    It's black plastic, has "HMI" and "Made in USA" printed on it, and looks designed to allow fluid to flow through it. It contains a small ball held in place with a wire, with some orange-colored residue inside.
    After some fruitless Google searches, I decided to post here. Do you think this fell out of my Prius, or is it unrelated?
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Can you confirm if its kinda have some oil stained on em? I want to know if its something not related to the hydraulics of the car
  3. dtmm
    dtmm New Member
    Fort Myers, FL
    It doesn't look oily at all.
  4. Prodigyplace
    12,699
    11,841
    Central Virginia
    Approximately how long is it? Photos do not give much size perspective.
    It looks like it has an O ring or gasket on top and a spring loaded pin below.
    Since the Prius was made in Japan, I would be surprised to find US made parts in it unless something had been replaced.
    dtmm likes this.
  5. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Has it got something like a thread wind round it?
  6. dtmm
    dtmm New Member
    Fort Myers, FL
    It's 4 inches long and 3/4 of an inch wide.
    There are no springs; those are plastic threads.
    Prodigyplace likes this.
  7. dtmm
    dtmm New Member
    Fort Myers, FL
    It has outside plastic threads on both ends, and the bottom end has a plastic collar screwed onto the plastic threads. I don't see any inside threads.
  8. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    made in usa? on a car assembled in japan? its not from your prius imo...
    dtmm and Prodigyplace like this.
  9. dtmm
    dtmm New Member
    Fort Myers, FL
    Yeah, the "Made in the USA" aspect was giving me the same doubts. Thanks for the help, everyone.
  10. bisco
    52,526
    agreed, not from your car.
    dtmm likes this.
