Receiving a warning symbol of like a POT with a exclamation sign
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, Dec 15, 2017.
  1. Sid786
    Sid786 Active Member
    262
    148
    Cherry Hill, NJ
    Receiving a warning symbol starting this morning, which is like a POT with a exclamation sign on my dashboard?
    Something like this:
    \__/
    Can someone please let me know, what is this indicating.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    low tire pressure?:confused:
    FuelMiser and Mark57 like this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    Check your tire pressures...
    priuscatprimeguy likes this.
  4. Mark57
    2,945
    2,740
    OK
    It's the cross section of a tire with an exclamation point in the middle.
    See page 190 and 656 of your owners manual, but DO check your air pressure. Every time you get a big temp drop, expect your tire pressure to be lower than normal. It may not be enough to make the light come on. Check them anyway after a big 10° - 20° or more drop.
  5. Sid786
    262
    148
    Cherry Hill, NJ
    Thank you guys. Yesterday I filled the Toyota survey and one question was 'do you see low oil' i.e., oil is burning which is a common problem in many of the new cars. The pot like symbol reminds me of that question and worried me.
    Yes, we had a drop in temp in the past few days. So that explains the low tire pressure.
  6. Prodigyplace
    12,542
    11,767
    Central Virginia
    Be sure to add air to the tires. Otherwise, you will experience lower mileage and increased tire wear.
  7. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Why would a new car burn oil?
    Prodigyplace likes this.
  8. bisco
    51,882
    odd question for a new purchase survey.
  9. Trollbait
    12,511
    Could the pot leaf have been a snowflake?
    Toyotas have such a warning light come on when the outside temps are at 37F or lower to warn you to look for ice.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Sid, I lost about 10psi Wednesday night. Inflating the tires back up to my pressure was the least of my problems.
