Gas smell when start in cold weather - 2016 Prius Two
Discussion in 'Gen 4 Prius Main Forum' started by Jay J., Dec 11, 2017.
  1. Jay J.
    Jay J. Junior Member
    Ottawa, ON Canada
    Hi Guys,
    I notice that when I start my vehicle (2016 Prius Two) in very cold weather (eg. below -10C/15F), there is gasoline smell that lasts about 1 to 2 minutes and then dissipates.
    Is that something I should be concerned about, or is it normal?
    Thanks!
    Jay J.
    52,393
    i don't have a gen 4, but i have to think it is not normal. perhaps the emissions equipment isn't up to snuff, but i think it would be worth running it by the dealer, in case there is a safety issue.
    RCO likes this.
  3. krmcg
    2,592
    2,392
    Whittier, CA
    Doesn't seem normal to me. I would get it checked out!
    RCO and Prodigyplace like this.
  4. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I would agree also with the others, and the coldest temps my Gen 4 has been is in the 20's. Doesn't get below freezing too often here in Florida. The only reason I could think its possible is if the gas tank is very, very full. Other than that, a trip to the dealer seems to be in order.
    RCO, Prodigyplace and krmcg like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I think there was a previous discussion on this topic - could be worth searching. (The USA filler is different to that in Euro or Australia.)
    Has this only just started? Before you go to the dealer, as @robsnyder20 said, how full is the tank?
    Both USA and Euro Manual says:
    RCO likes this.
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    This isn't normal.
    The only reasons I know could be the cause, would be if the gas tank was filled above capacity, and if the fuel pump cover seal, has some cracks on it, you'd have vapour escaping from there to the cabin of your car, hence the smell of gasoline you perceived.
    Another option is to check the engine bay area, if any of the injectors are leaking gasoline.
    Here's a simple check:
    Start the car as you'd always do, and check underneath the car, if there are signs of gasoline spills, or you could remove the rear seat where the fuel pump is located, and check for spills there.
    Dxta
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Depends on the actual smell. The cat. isn't warmed up and you can smell the alcohol (burned) in the exhaust until it does warm up and starts working. I suspect it is "normal" and is caused by the cat not being warm.
    Tande and alanclarkeau like this.
  8. padroo
    padroo Senior Member
    2,763
    2,252
    If the car is under warranty take it back to the dealer. There may be some kind of service bulletin out there by now about it by now.
  9. Mendel Leisk
    41,909
    One clue: this is happening at start up in particular, not a general "I can smell gas" when approaching the car thing.
  10. bisco
    52,393
    clue 2: only in the cold.
    RCO and Mendel Leisk like this.
  11. Tande
    Tande Active Member
    550
    337
    Mich.
    My Gen. 4 does the same thing, although I would not necessarily call it a "Gasoline" smell.......definitely a chemical smell.....Ya, maybe alcohol??.......figured it was normal....:confused:
  12. bisco
    52,393
    open container law?
    krmcg likes this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Good to know, but your profile still shows as Gen 3. Do you have both in your garage now? ;)
  14. Prodigyplace
    12,678
    11,830
    Central Virginia
    If there is any doubt, I usually make sure the cat is not under the hood before starting the car. :LOL:
    mjoo, Mendel Leisk, RCO and 2 others like this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That's another way to keep the pesky mice out of the car! :ROFLMAO:
    Prodigyplace likes this.
  16. Tande
    Tande Active Member
    550
    337
    Mich.
    Oops! ........yup, got both.....wife & I both HAD a Gen. 3.......now only she has a Gen. 3 ......:D
  17. Mendel Leisk
    41,909
    Maybe be good if avatar info allowed multiple vehicles. Don't know who to address that to these days though.
  18. Prodigyplace
    12,678
    11,830
    Central Virginia
    Following Bob's lead, you could fit in 3 vehicles, likely.
    Tande, RCO and Mendel Leisk like this.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I guess it would be the Moderator of the North. @Tideland Prius is like a kind of Arch-Wizard on here. He's probably a stunt double for Gandalf the Grey!
    Tideland Prius and Prodigyplace like this.
  20. Prodigyplace
    12,678
    11,830
    Central Virginia
    I doubt he is old enough for Gandalf the White. :D;):cautious::oops:
    Tideland Prius and RCO like this.
