  1. Putu Ariawan
    Putu Ariawan Active Member
    93
    450
    Glendale, CA
    Daigi_, ckam1989, m.wynn and 9 others like this.
  2. orenji
    orenji Senior Member
    5,884
    3,486
    You got the wheels! That was a great trade!
    m3pare likes this.
  3. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    Yep! I’m happy with the trade. :)
    orenji and Dylan Doxey like this.
  4. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
  5. m3pare
    679
    1,818
    SoCal (626)
    Finally got around to installing sound deadening after buying the material well over a year ago. :ROFLMAO: Started with the rear doors and will work on the fronts and hatch another day. Using Peel n’ Seal from Lowes & Ensolite from RAAMaudio. Left some untreated areas near the speakers for when they get upgraded. Now the doors shut with a nice satisfying thud. (y)
    E063EC74-4621-49EE-8CB8-F44128AC43BF.jpeg 24DE9138-CD0F-444E-B3A5-1191AB2576EE.jpeg 3F131434-BE35-4E37-B652-C445C2EAA9FD.jpeg 63367E56-FC40-409F-8F03-9DD918400BA4.jpeg 022B4A66-558B-4FFB-939F-B00A496F786B.jpeg D9F52FED-00DF-47BB-BECF-4C0F62BB3C03.jpeg 2D7F073B-2C47-4209-8CF4-E020297E3485.jpeg
    qettyz, m.wynn, Grit and 13 others like this.
  6. MagnusAG99
    MagnusAG99 Senior Member
    672
    519
    Norway
    finally got my DRL`s installed, they`re gonna temporarily gonna sit where they sit now til i either get the 2013 front bumper, Aimgan front bumper or G`s front bumper.
    [​IMG][​IMG]
  7. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Got a chance to swing by Hybrid Pit to add 5HP to ride and did engine coolant and invertor drain and flush. My bad, minus 5lbs of weight :) Saw a sick fully mod STI there. They not only work on Prius but other ride! Thanks guy.
    #15127 apt5020, Dec 18, 2017
  8. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    2009 Prius was watching from the front.
    IMG_0217f.jpg IMG_0219f.jpg IMG_0222f.jpg IMG_0225f.jpg IMG_0222f.jpg IMG_0226f.jpg
  9. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    Megaldon Fin Mod :eek:
    James Powers and Burna J like this.
  10. James Powers
    396
    555
    Bay Area
    Haven't gotten it yet but I ordered the Prius Plus rear sway bar from HybridPit! Merry Xmas to me!
    PutPutMobile, RMB, m3pare and 2 others like this.
  11. Civiceg94
    Civiceg94 Member
    58
    44
    Nyc
    Drove with the prius from nyc to niagara falls canada pretty disappointed got 42mpg and my oil level was half way
  12. Bingee
    Bingee Member
    210
    62
    Michigan
    Mpg down , my guess , due to COLD temps outside
    Burna J likes this.
  13. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Installed LED fog lamps from ijdmtoy.com and replaced the bumper grill since I had the non fog light version.
    iPhone ? Pro
  14. Civiceg94
    Civiceg94 Member
    58
    44
    Nyc
    I had the lower grilled blocked and saw it went to 198 the temp when i pushed it on the hills. And my tires were at 42 front and 40 rear. But that wasnt my biggest disappointment. Just knowing i had lost engine oil and i had to buy a quart to top off a little was annoying my 2008 toyota 4runner v6 has 170,000 miles on it and it never once needed to be topped of.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,483
    Bay Area, California
    2019 Prius Prime
    Got a smog check done yesterday (thanks @Joele3 );).
    Did the passenger front wheel bearing hub assembly on Friday. Much quieter now:).
    Then did the oil catch can install this morning:
    • Cut the stock hose in half and spliced in the hose connections DA1C9972-F7C3-4578-BC54-01E658840E16.jpeg
    • Found a can and zip tied it to the cross member 6A6C9CE2-20D2-4A97-B4CF-0B5950FE465B.jpeg 983A3E16-63EE-421C-9456-169BFD7405AB.jpeg
    Should be good for awhile (y).
    tri4all, m.wynn, sfv41901 and 5 others like this.
  16. SFO
    SFO Senior Member
    5,297
    4,238
    Northern California
    Is that a generic can?
    What kind of lid or cap was used, and where is the drain hiding?
    Raytheeagle likes this.
  17. Raytheeagle
    11,251
    15,483
    2019 Prius Prime
    Can inside a can;).
    I actually got an oil catch can off of amazon, then used the other can as a holder for the oil catch can. Up tied the spare can down and the oil catch can “floats” inside the tin can. Good snug fit and will ensure it doesn’t get loose:).
    Put it underneath the engine to ensure good drainage and no accumulation anywhere other than in the catch can;).
    Have a good holiday season(y).
    xliderider, m.wynn, RMB and 1 other person like this.
  18. MagnusAG99
    672
    519
    Norway
    Anyone who have tried this tail as turn module? seems pretty cool actually. The 3rd gen prius is supported
    Tail as Turn™ Module, DIY | Diode Dynamics
    I also really recomend the Smarttap flasher for people here, i installed it in my car yesterday (wasent a fun job to change it but yea...). it prevents hyperflash in LED bulbs. Tap to signal 3-6 times, arrival and depature lights for 10-90 sec when u unlock and lock the car (its a bug with the arrival lights tho.. on my prius atleast, so the indicators dont stay iluminated when u unlock. Ive contacted them and they r looking for a fix they say... lukcily its 3 yr warranty), different hazard patters and stuff
    SmartTap CF18 LED Flasher Module | Diode Dynamics
    #15138 MagnusAG99, Dec 26, 2017
    sfv41901 and Inza2 like this.
  19. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    #15139 Nopho4u, Dec 27, 2017
    sfv41901, m3pare and Johnsk93 like this.
  20. Gaspeed
    Gaspeed Senior Member
    286
    1,624
    San Diego CA
    I have that exact module on my Infiniti G37 coupe. Works great and I love it. I don't have it on my Prius though.
    sfv41901, m3pare and MagnusAG99 like this.
