Reliability information
Discussion in 'Gen 2 Prius Main Forum' started by mkaresh, Jun 7, 2006.
  1. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Wonderful! And the car still runs fine?
    Great news
  2. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    After the new battery, the car has been fine. My husband commutes with it.
    SFO and Chodronish like this.
  3. offib
    offib Member
    162
    95
    Dublin
    Four Touring
    I should've done this a while ago.
    Have an '07 that spent less than half its life in the UK and the other in Ireland - so favourable conditions for the battery. There were learning curves. A nasty 12v battery that was kept alive longer than it should. A clogged HV fan that threw a code, and when fixed was left unplugged for months (with a rare limp mode now and then) until I got fed up and found all the car's problems left dangling in the boot.
    Now, it's gone over 157,400 miles, it recently did a long drip (600 miles in 48 hours) at sustained high speeds full of passengers and it runs magnificently. Rear shocks are begging to be replaced. OBDII moniter shows a delta voltage of <0.1V to <0.2V depending on temperature.
    nssdiver, Rph74 and Aaron Vitolins like this.
  4. Aaron Nutter
    Aaron Nutter New Member
    2012 Aqua
    Thanks for letting us known buddy.
  5. Graeme1949
    Graeme1949 Member
    51
    47
    Atlanta, GA
    Just for information:
    2004 Prius, I'm the ORIGINAL owner. At 193,426 miles just had a quick check at a dealer.
    * ORIGINAL hybrid (traction, main, high-voltage) battery is still going fine.
    * Replaced the 12 Volt auxiliary battery for the second time.
    I had a concern about the hybrid battery because of getting a warning while being dragged through a carwash. Because of it's age I thought it was prudent to have it tested. No problem with it, so I'm continuing to drive ... headed for 200 k miles.
    Just to show that the doom-and-gloom folks aren't always right.
    Location: Maryland, USA Difuminator_8-5-2019-3-49-13.jpg hdr_00223_0-02.jpg
    -Graeme-
    2004 Prius with >190,000 miles.
    Sent ?.
    Sanchan, offib, Kaptainkid1 and 2 others like this.
  6. homiejoe2
    homiejoe2 Junior Member
    new york
    gen 2 gets er done yo. +EV tank
    offib likes this.
  7. Beowulf9879
    Beowulf9879 Junior Member
    Omaha, NE
    Lucky. 2007 owner here. So many dead cells in the original battery and replacements. Am I doing something wrong, lol!
  8. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    Yes.
  9. GreenApp
    GreenApp Junior Member
    43
    Bought '07 prius in '14. Ran perfectly for the entire time. Changed tires from the [discontinued] Summer radials to all-season. MPG went down a hair. Replaced Inverter Coolant Pump 4 years ago. Went through a tough time, lived in prius for a year 2019-2020ish. HV battery giving me troubles now, removed, process of refurbishing. I stand by this car as being one of the most effective tools for one to have. Everything is pretty well engineered. 130k miles today, bought @60k. Looking forward to another 60k.
    USMC1968 and Jdz67 like this.
