Fix Up or Trade In
Discussion in 'Gen 2 Prius Main Forum' started by draedie, Dec 17, 2017.
  1. draedie
    draedie Junior Member
    22
    DC Metro
    Three Touring
    My combination meter is failing and when I took it in to diagnose the problem they gave me a list of other problems. Mostly relatively minor other than potentially replacing the tires soon but my muffler also has a hole, apparently. So now I'm looking at approximately $1400 worth of work on a 2008. On the one hand, I love my car and it's been paid off for years which is awesome. On the other hand, it's 9 years old, past even the extended warranty, and around 114,000 miles. I was not prepared to be considering a new car right now, but circumstances being what they are I'm left wondering how much money I want to put into an older car. We have two small children so I'm really out of the loop of what's going on in the Prius world, as opposed to when we purchased the car and I had much more time to devote to research. I do know that one of the new versions of the Prius only has four seats and there are plug in options. I'd love to hear your thoughts on this and any suggestions you want to throw my way!
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    The only thing I'd do if were you, is to replace the fluids recommended on that service Info.
    If the components on the car hasn't broken off, I won't replace them either.
    Dxta
    pilotgrrl likes this.
  3. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    You might find a good used combo meter on ebay. If your a DIYer, it might be worth keeping. I replaced the mfd and it looked like a nightmare. It's actually easy to remove dash components. Not sure how easy the combo meter is.
  4. Mendel Leisk
    41,821
    Just a few comments, things that jumped out at me:
    If it's similar to third gen, those "marker light" bulbs are 00234-00192. I've replaced them a couple times, not too difficult, and the bulbs cost me $2.40 apiece.
    Skip the $263 headlight housing restore. IIRC someone here got a pro restore done at some US auto retailers (maybe Pep Boys??) for under $50, the results were excellent, and you couldn't do it much cheaper yourself. Or just leave it be.
    Skip the alignment if you're not noticing any issues.
    They're warning you to check your oil more often, car was very low when they did the oil change.
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Well the combination meter is a given, but for $950 I would certainly explore any options.
    The right time for an alignment is when you get new tires.
    They are a little high on the plugs and out of this galaxy on lightbulbs, never mind the headlamp reconditioning!!!!!
    pilotgrrl and Mendel Leisk like this.
  6. Mendel Leisk
    41,821
    2nd gen plugs are easy access, what is it 5/8" socket size (3rd gen is 9/16")?
    You should have 3" and 6" extensions, spark plug type socket (with rubber inside), ratchet wrench and torque wrench.
    If per 3rd gen: 15 ft/lb with clean thread, and I'd suggest a very slight/thin coat of anti-seize. Reduce torque to 13~.
    bshef likes this.
  7. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    $170 for spark plugs. Wow. On Amazon, the best Prius plugs are under $40 for the set.
    A drunk monkey could change Prius spark plugs in under an hour.
    A sober human who can grasp the concept of "lefty loosey, righty tighty" could change Prius spark plugs in 20 minutes.
    I understand that businesses have overhead and exist to make a profit, but $130 for labor to change spark plugs is criminal.
    bshef and pilotgrrl like this.
  8. Mendel Leisk
    41,821
    Yeah, I think these replace NGK IFR5A11 spec'd in Owner's Manual? $28 for a set of 4 on Amazon, and you should be able to wangle free shipping, if you also get a book or something:
    Also, just phone local automotive specialty stores, I've always found them to undercut dealerships.
    pilotgrrl and draedie like this.
  9. bisco
    52,274
    careful attention to your cars maintenance and service providers will provide you with a reasonable option for keeping it.
    otoh, if you don't have the time, but do have the money, a new prius at $20-30,000. will provide you with another 9-10 years of cost free driving.
  10. Fredsimm
    188
    117
    Tupelo MS
    I'm probably going to start a debate, but oh well. You can buy copper, platinum, or iridium plugs and they all will work well. Since I change my own plugs, I've always used Autolite copper in all my vehicles. They are inexpensive and durable. The only difference is the expected life of the plug. I don't care that an iridium plug can last 100,000 miles. I'm going to do tune ups more frequently than that. Also, leaving a threaded device in aluminium for extended periods can cause seizing and ruin the threads in the head.
    #10 Fredsimm, Dec 18, 2017
  11. egg_salad
    545
    426
    Las Vegas, NV
    Won't get any guff from me on that. It's your car; change plugs as often as you'd like.
  12. 05PreeUs
    1,097
    565
    MSP
    Only if they do not have coated threads as any quality plug will have.
  13. Fredsimm
    188
    117
    Tupelo MS
    In my younger days 15-20 years ago, when I was a mechanic, maybe that was an issue. I assume things got better. Years ago, we had thread issues on aluminium heads occasionally. Repairs were a pain. I also use a thin film of anti seize.
    #13 Fredsimm, Dec 18, 2017
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    (y) I'm with you Fred. Although I haven't yet had an opportunity to change the plugs in any of my Prii, the Autolite coppers were my "go-to" plug in my racing days. Always looking for that extra tenth of a second, I tried many things. At under a buck each, they still performed better than any other plug I ever used during that timeframe. I still insist on them when changing plugs on my other vehicles that have relatively easy access to the spark plugs. The wife's Santa Fe has one of those crazy PITA sideways mounted V6 engines that requires the top of the engine to be removed to access the back plugs. THAT CAR gets long life plugs...........
    Disclaimer: Of course, every situation is different and your individual results may vary.
  15. Mendel Leisk
    41,821
    $7 apiece for long-life plugs is too much for you guys?
    pilotgrrl and 05PreeUs like this.
  16. 05PreeUs
    1,097
    565
    MSP
    Apparently $140 every 120k is too much for some ;)
    For me, time is money and degrading the engineering is not worth the effort. If I'm going in to change plugs (or worse, paying someone else to do so), I am using what the engineers specified.
  17. eman08
    eman08 Active Member
    360
    192
    US
    The car is approaching 10 years old before you know it the hybrid battery going to need replaced soon. I personally wouldn't keep a hybrid car very long that's out of warranty. They do become money pits as they age as that's for all hybrid electric vehicles. You can get virtually all other parts used but the battery pack would have to be brand new if you want to drive these cars another 10 plus years trouble free. Installing used battery modules is not a permanent fix as you will be repeating the process all back over again which can be a pain rendering the car very unreliable.
    draedie likes this.
  18. 05PreeUs
    1,097
    565
    MSP
    IMO, that is a little too much on the "Sky is Falling" side of the thinking.....
    Our Gen2 went 12 years without so much as a water pump belt replacement, just tires and a couple alignments added to regular oil changes. Then the HV pack shot craps.... one module and it has gone another 5k without a hint of trouble, so that's like $0.013/mile or $21.67/month in battery costs just in parts. Expanding that to a HV pack replacement, you can get even lower costs....
    $2400 for a "new" pack from Toyota (less if you use the new cells available from a member), gives us:
    $2400/144 = $16.67/mo over 12 years and 2400/185k = $0.013/mile.
    At the end of the day, two things remain true: 1) The cost per mile or month is less than 10% of a new vehicle payment and 2) You save more in gas costs than the repairs cost - IF you keep driving it.
    Lastly, there is hardly a less costly vehicle to keep on the road, from oil changes to suspension and tune-ups, these things are CHEAP TO OWN!
    bshef, pilotgrrl and valde3 like this.
  19. eman08
    360
    192
    US
    It's a big job replacing battery modules all the time as i would get tired of doing that. It's very time consuming and not very effective compared to just getting a brand new pack from the get go. Not everyone are Mechanics or DIYer. That's the problem with EV and a hybrid cars as they solely rely on the high voltage traction battery pack as they are planned obsolescence components designed to last a certain length time while the chemistry degrades. Used battery modules aren't going to last very long as they can be old as 10 years old. Telsas are much worse as the entire car is full of planned obsolescence complicated on board computers and electronics that will bankrupt you when all that stuff breaks down. They are Iphones on wheels with too much unnecessary electronic complexity, the more things to go wrong. Electronic door handels is not needed as a core function of the car as its a luxury gimmick. Tesla has a history of those going bad as you won't be able to get in which is a horrible design. Nothing will be more reliable than a mechanical door handel.
    edthefox5 likes this.
  20. 05PreeUs
    1,097
    565
    MSP
    Ever done it??? Does not sound like it, it is NOT that hard nor complex. If you know how to use a 10mm wrench and a multimeter you are mostly set.
    Data please! I am unaware of any chemical technology that would extend battery life. Toyota is the industry LEADER in hybrids, rather disingenuous for anyone to suggest they are deliberately sand-bagging their products.
    Correct, BUT there are a number of cars that are well over 10 YO and have over 300k with perfectly fine packs. The truth is that one module in the HV pack takes it out, the remaining modules might last another 3-5 years. Do people replace all 4 tires because one gets a flat? Hell no.
    I would bet you have ZERO facts or documents to back that up. I don't really like Tesla, simply because they could not care less about supplying parts for repairs or wrecks, just use your favorite search engine to verify.
