Headlights went out while driving. Halogen lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mcsquid86, Dec 20, 2012.
  1. mcsquid86
    mcsquid86 Junior Member
    ky
    My wife was driving home tonight and the headlights went out. She was able to pull off the road to a parking lot. All the lights are working besides the headlights. Neither high or low beams are working. I can head clicking noise in fuse box when switching the headlights on and off. I pull the plug off one of the headlights and stuck a new bulb in it. It still did not work. Thanks in advanced for your help
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    If the headlamps are out on dip and beam the most likely problem is either 40 amp main headlamp fuse blown or relay H-LP both in the fuse box under the hood, this is assuming your car does not have DRL's.
    Hope this helps.
    John (Britprius)
  3. mcsquid86
    ky
    It does have daylight running lights. I'm going to recheck the fuse again, and thanks for the info on the relays
  4. Britprius
    5,194
    1,921
    Just checked the wiring diagram for headlamps with DRL and the circuit is basically the same. What sort of level of electrics are you happy working with as I can pass on more information but do not wish to overload with information a beginner.
  5. mcsquid86
    ky
    I'm above average with AC electric, so I'm thinking I can figure this out with some help.
  6. Britprius
    5,194
    1,921
    Ok check DRL fuse 7.5 amp. If ok, at one of the headlamps (does not matter which one) remove connector from bulb it will have 3 wires :- blue violet and brown, ground with a piece of wire the connector with the brown wire in it and try the lights in ready mode. Does the other headlamp work. If so check the DRL relay4 in the box under the hood near the center of the engine bay below the windscreen. If not check for 12v at pins 5 & 1 of the H-LP relay socket (relay removed) in the large fuse/relay box. Let me know how you get on.
    John (Britprius).
  7. mcsquid86
    ky
    John, I happen to have two prius, so I just swapped out the relays. And it still didn't work. I'm confused how to check the 40 amp fuse of the headlight, but I can't get the lid off of it without breaking the tab. I broke the first one then I stopped. If I get in there is there a way to pull it out and check it.
  8. Britprius
    5,194
    1,921
    Check at pin 6 (with the relay removed) of the H-LP relay socket with a volt meter for 12volts or a 12v bulb to ground if this is present the fuse is ok.
    I think the next step is grounding the brown wire to one of the headlamps as in post 6 ( the one you tested with a replacement bulb will be the best to get at), as the ground return on the car with DRL is more complicated.
    If you can read circuit diagrams there is one in the file library here on PC. The page you want is "Head lamps & fog lamps w DRL 2of2". Grounding this terminal misses out the whole of the DRL system grounding for the headlamps (runs the headlamps in the same way as the non DRL cars).
    This will basically cut the faultfinding in half. The alternative to this is to ground pin 3 of the DRL relay socket (with the relay removed) does the same thing.
    John (Britprius).
    HeadOfJarg likes this.
  9. mcsquid86
    ky
    I couldn't get it going so I took it to toyota taday. thanks a bunch for trying to help.
  10. Britprius
    5,194
    1,921
    At leased you had a go at fixing it.
    Hope the dealer does not rip you off. Please keep us informed with as much detail as you can as this may help others in the future. Good luck.
    John (Britprius).
  11. mcsquid86
    ky
    The garage said it was a coroaded ground plate. I'm glad they are working good. Thanks for your help
  12. Longinus876
    Longinus876 Member
    105
    Long Island
    John,,,new member here. Saw some of your recommendations. Need help w/ an '05 Prius halogen headlight. Bulb is good but will not go back on after being shut off unless I wiggle the socket in the housing or the actual bulb socket is touched to ground momentarily. I checked the connections by just moving things around and there does not seem to be anything loose. I'm stumped. Thanks in advance....alex (Longinus876)
  13. Britprius
    5,194
    1,921
    It is difficult for me to give precise instructions from a distance. Do you have a multimeter for testing? and the ability to use it.
    The most common cause of this problem with the Prius is the ground wire terminal in the bulb connector being corroded or burnt. Changing the complete connector plug is the most reliable way to repair it.
    John (Britprius)
    Longinus876 likes this.
  14. Longinus876
    Longinus876 Member
    105
    Long Island
    Yes, have a meter and can check the resistance on all the connections. Will try that next. Could the ECM be involved? And would a code go to the ECM or elsewhere? Thanks again.
  15. Britprius
    5,194
    1,921
    The ECM will not be involved. Fuses are also ruled out as the light can be made to work by moving the connector. If the fault appears on low, and high beam the only real suspect is the ground connection from the bulb to the body. Wiring diagram below.
    John.
  16. HeadOfJarg
    HeadOfJarg Junior Member
    (Sorry for the necro and off-topic.)
    @Britprius, did I understand your post correctly that either:
    1. Grounding the brown wire in the headlight connector, OR
    2. Grounding pin 3 of the DRL relay socket
    will disable the DRL system? If so, could you please help me with more details/diagrams?
    Also, are you referring to a US model with a DRL option added, or a Canadian model where DRL is required by law? (I have a Canadian 2004 Prius and I'm trying to use my fog lights as DRLs instead of the headlights to extend their life.)
    Thank you!
