Prius C battery Issues
Discussion in 'Newbie Forum' started by Kalo, Dec 20, 2017.
  1. Kalo
    Kalo New Member
    Chicago, IL
    So My boss's 2013 Prius got the red triangle of death and a code to replace battery. He doesn't wanna spend $3500 bucks again so asked if I could check it out. So I pulled the hybrid battery out and opened it up. Tested with a meter and all modules measured at 8.3. I tried to load measure it and I do not know If I didn't do that right but they all measured 8.3 still. Am I doing something wrong or Is there another reason the hybrid battery code came up? Could the Battery be ok and something else is the issue? Dealer said replace battery because that's the code that cameup. Is It a smarter to choice to just buy a new battery an just install it so he still saves a couple thousand?
  2. Prodigyplace
    12,533
    11,755
    Central Virginia
    Paging @TMR-JWAP , @2k1Toaster , @ericbecky , @Raytheeagle
    Battery troubleshooting assistance please.
    I know @2k1Toaster has a DIY battery kit with new cells for Gen 2 & Gen 3. for $1600 shipped. I do not know if he has developed a version for Prius c.
    EDIT: What is the condition of the 12 volt auxiliary battery? I doubt it is the case here, but a failing auxiliary battery can cause the computers to generate strange trouble codes.
    RCO and Raytheeagle like this.
  3. bisco
    51,851
    you can hopefully find the part close to around $2,000. and diy it. how are the bus bars, any corrosion? have you cleaned the cooling fan yet?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Can you post a copy of the readout the dealer supplies with the codes?
    How many miles on your bosses Prius?
    How did you load test and did you look at the hv battery cooling fan to see if it was clogged?
    Keep us posted (y).
    RCO and Prodigyplace like this.
