I can't believe I couldn't find this answer -- what is the amp hours rating of the OEM 12V battery?
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Dec 22, 2017.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,057
    785
    Virginia, USA
    This seems like it should be easily answered via a search in the forum or on Google. I have been trying for an hour and can not seem to find the answer.
    I know that the Prius battery is small and its very bad news to deplete it entirely. I have wired a constant 12v circuit to the battery (fuse protected, of course). I will be using this during times that the car is in the OFF mode.
    I would like to know the OEM battery amp-hour rating so that I manage the load and don't deplete the battery.
    Bonus points question
    -- I am also considering wiring in a low voltage disconnect module to my 12v circuit wired to the Prius 12v battery for complete insurance that I don't drain too much off the battery. It is my understanding that the 12v battery merely starts the car's electronics and the the traction battery starts the ICE. If so, what is the lowest cut-off would you suggest for disconnecting my circuit in order to let the aux battery still do its job? The choices are 12.1v, 11.4v, 10.7v, or 10.0v.
    Thanks!
    52,396
    12.1, but even then, it is not advisable. continuous draining to that level will likely cause irreversible harm. and the car is not designed to charge it back up.
    prius was designed to use the 12v very little, effectively not dropping the voltage, and the inverter keeps it charged when in ready.
    it takes a long time for the inverter to recharge a battery from 12. 1 to 12.whatever its current voltage is.
    scona likes this.
  3. CR94
    CR94 Senior Member
    2,752
    1,207
    Northwestern S.C.
    It is about 40 Ah, I believe.
  4. ChapmanF
    18,556
    I'd say you'd be fine with any of the first three cutoff voltages. In my experience, even 10.0 won't give you any trouble starting the car, but that would be well into deep cycle territory. Prius aux batteries are better suited to deep cycling than typical car start batteries, but still, the battery ought to last longer if you don't routinely take it that low.
    If you look at the battery, you'll probably see a label advising a 5 amp or lower charge rate. Clearly, with a 45 Ah capacity, you'd be looking at (ideally) 9 hours, (in practice) more like 13 hours, for a full charge at that rate. The car's converter isn't really a constant current charger, so it'll really recharge rather faster than that ... at the expense of stressing the battery more.
    -Chap
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    As I recall SE Toyota (or some of their dealers) have been installing such a cutoff device on Prius for several years. I wouldn't recommend using such a device, as they caused other problems for owners. They were posting on this site.
    Depending on year, the stock Prius 12V battery is 38, 40, and 45 A-Hr capacity. I won't discuss "cranking amps" because it isn't applicable.
    When Pearl S' OEM battery was about to fail it would put the car in "ready" at 10V consistently. I now know it was "about to fail" because, while it never actually failed completely, it quickly got flakier and flakier.
  6. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
  7. zebekias
    zebekias Member
    101
    35
    Greece
    The maintainer I use for my 12v is rated at 0.8 A. Considering the battery lasted 7 years I'd say 0.8
    Indeed my 7 year old 12v battery would put the car in "ready" but it didn't have enough juice to lock/unlock the doors or trunk. I hoped I didn't have issues with the locks, and sure enough after replacing it with a new one the locks worked just fine.
  8. Johnny Cakes
    1,057
    785
    Virginia, USA
    Maybe that's why I couldn't find the answer -- it depends!! I have a 2014 with the technology package. Any idea the Amp Hour for that year?
  9. Mendel Leisk
    41,912
    It'd be nice if they could put it on the label. Don't most after-market batteries? (n)
    I recall trying to find the cold-cranking-amps for our OEM Yuasa when I wanted to test it with a Solar BA5. Good luck wandering around in the Yuasa website. Finally elected to use 325, which I think is close.
  10. ChapmanF
    18,556
    That's a maintenance charging rate, intended to just hold a battery at full charge, staying just ahead of self-discharge and the small loads that continue when the car is off. When the battery's at less than full charge, you can charge it faster than that (and the car does), but there is a label on the top saying not to go above 4 or 5 amps (IIRC) if you can avoid it.
    Think how long it would take to recharge a discharged 45 Ah battery at 0.8 amps (keeping in mind it's only the part of that 0.8 in excess of the constant load and self discharge rate that gets you ahead, so 56 hours would be too optimistic, not to mention you usually need to stuff in something like 1.5 ✕ capacity before you can get 1 ✕ capacity out).
    -Chap
  11. Mendel Leisk
    41,912
    My 4 amp charger, with battery in good shape to begin with, typically takes 5~6 hours. IIRC, the last depleted battery I dealt with, it took close to 12 hours.
    That max amperage warning is in the Owner's Manual somewhere, maybe 4 amp for 3rd gen, and 5 amp for 4th gen??
  12. CR94
    CR94 Senior Member
    2,752
    1,207
    Northwestern S.C.
    CCA isn't relevant, at least not directly, because the battery never needs to supply a high current. However, a high-CCA battery should accept a higher charging current. That could be good for owners who scarcely drive enough to keep the battery charged.
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Don't.
    My advice is to never consume electrical power except when in Ready. Should you ignore this, I recommend a jump starter in the car all the time.
  14. Mendel Leisk
    41,912
    It was relevant for me purely because my Solar BA5 tester was asking for it. It works by electronically load testing, deciding an actual CCA, comparing to spec. It arrives at this value regardless, but I guess bases its verdict on the spec.
  15. bisco
    52,396
    if i was gonna do anything with the car off, i would install an optima or the like.
  16. Johnny Cakes
    1,057
    785
    Virginia, USA
    I definitely hear you and that is why I am so concerned and even thinking of a low voltage cut-off. But my application seems like a really minor load?
    I need to charge a Di2 bicycle battery (the bike is on a rack at the rear of the car, which is why I wired a 12v outlet to the battery there). The charger is USB (5v, 500mA) and max duration from dead Di2 to total charge is 90 minutes. So that seems like 1.5 amp hours off the 45 Ah Prius battery, although I could be way off since everything I know was learned in the last week from Google searching/reading.
    The ONLY other thing I would be looking to charge is the bicycle headlight battery, which is 7.2v 2.6Ah capacity. I charge that with 12v DC using a Buck step down converter that I wired to give 7.2v output.
    Should I still be concerned about depleting the Prius battery if this is the only use?
  17. bisco
    52,396
    johnny, you have been here for a year. we can't tell you what will happen in your particular situation. what we cantle you is that prius battery is garbage. i don't know how else to say it. it's barely good enough to start the car, never mind trying to run other things off of it.
    we are just trying to make you aware, so you don't get stranded with a dead battery in east overshoe.
    Raytheeagle likes this.
  18. Johnny Cakes
    1,057
    785
    Virginia, USA
    Sure, I don't think anyone can predict the future. And I've learned from being in the forum for a year that the Prius battery is tiny.
    To the extent that this is science, I was just seeking opinions from those more knowledgeable in electronics regarding the specific numerical load I am applying to the battery compared to its stated capacity. Ultimately I realize that it is just opinion and I promise I won't call for a ride if I take the risk it doesn't work out! :)
  19. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Your math and logic are correct. A fully charged, healthy Prius battery would have no problem doing what you are asking about. The potential problem comes when the Prius battery is not in a fully-charged state. For one thing, a battery that's several years old will not have the same capacity as it did when it was new. Then put yourself in situation where the car has been used for many consecutive short trips in a short period of time -- not allowing enough "on" time to recover. This scenario could put your Prius battery in a marginal state of charge. Now add the small additional demand your bike charger would put on it, and it might be enough to get you into trouble.
    My suggestion would be to get a lithium ion jump starter, and charge you bike, headlight, phone, etc. from that. (I'm not necessarily endorsing the one in the link, just that it seems like a good price on a unit with high mAh rating.) As a bonus, it would provide a safe jump start source for your Prius if it ever needed it, and it would give you a safe source to jump other people's cars without using your Prius. Keep in mind, for your purpose you don't need the Consumer Reports best buy unit. They're going to be testing them as jump starters -- which is way more of a power demand than you'll ever need for your charging or your Prius starting.
  20. Johnny Cakes
    1,057
    785
    Virginia, USA
    ORDERED!! This is what makes this forum so great -- thanks for the help!
    I do carry a huge jump starter at all times in every car I own and was using that to charge the bike battery, but it was a PITA to haul it out of the under floor storage (I have permanent stuff mounted on top of the floor that had to be moved) and it was heavy as ^%#$@@. It never occurred to me to get a mini battery pack to use instead.
    Many thanks!
