Check engine light
Discussion in 'Gen 4 Prius Technical Discussion' started by Frederickdawg, Dec 25, 2017.
  1. Frederickdawg
    Frederickdawg Active Member
    596
    336
    Florida Unfortunately
    Wife just called me saying her check engine light is on , on her 2016 Prius with 18k miles on it.
    Sorry for being rusty, but does the Carista have the capability to read and tell me what the code is?
    SM-N950U ?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Not sure but did she just get gas and leave the gas cap off?
    SFO likes this.
  3. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Get it to auto zone,and have it scanned if you can
  4. Mendel Leisk
    41,889
    It might be something benign: do nothing for 5-6 starts, it may go out on it's own.
    I had a check engine light recently, after removing and cleaning intake manifold. I was in a sweat, but about 5 start ups later it went out, without intervention. Momentary lack of signal from a reconnected sensor, who knows.
    Again, could be gas cap.
  5. Frederickdawg
    596
    336
    She pumped gas Saturday, two days ago.
    SM-N950U ?
    Raytheeagle likes this.
  6. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    How many drive cycles and miles since the last fill up?
    Since you were asking about Carista, were you able to read the codes?
    Was the check engine light flashing or was it solid?
  7. Frederickdawg
    596
    336
    I've got a Carista but wasnt sure if it can read codes or not. Hence the question. I had bought the Carista ages ago and used it once to disable reverse beep.
    I think she drove the vehicle two oe three times before the check engine light came on since pumping gas. But then again, she said she noticed it today, light could have been on earlier.
    SM-N950U ?
  8. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    If the Gen4 is like the Gen3, the check engine light is at the far end of the display:(.
    Ours has come on a couple of times over the years, but I don’t notice it right away as it is out of my normal field of vision ;).
    But on a newer Prius I would look into the simple things (y).
  9. Mendel Leisk
    41,889
    Just for giggles, pop the filler lid and check if there's a gas cap?
    Raytheeagle and alanclarkeau like this.
  10. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    They don’t tether them anymore like on the Gen3(n)?
  11. Mendel Leisk
    41,889
    Ahh, good point.... Oh, it could be on but loose.
  12. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    First of all, it's perfectly safe to drive with Check Engine ON. There is no harm to the engine, actual or potential. This light is primarily (entirely?) for emissions related "faults". Most commonly, suspect the gas cap, especially if recently refueled. Reseat the gas cap. When she fills with gas, does she try to "top it off"? This could result in fuel getting into the vapor containment apparatus (Probably not the Official terminology). Of course, try and get the codes read, just to make sure. Doesn't removing the negative battery terminal briefly reset this light?
    RCO and Raytheeagle like this.
  13. Frederickdawg
    596
    336
    The gas filler cap wasn't screwed down at all. LOL
    SM-N950U ?
  14. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Thanks for circling back;).
    Glad it was an easy fix(y).
    Frederickdawg, scona and Mendel Leisk like this.
  15. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    "The 'check engine' light is reserved only for powertrain problems that could have an impact on the emissions systems," says John Van Gilder, General Motors' lead OBD development engineer.
    But that doesn't mean that no harm can come to your car. For example, if your car is running rich enough for a long enough period, the catalytic converter can be severely damaged and may even lead to a fire under the car.
    That said, it is USUALLY okay to continue driving while diagnosing the situation.
  16. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    When I got my last car, I commented that it didn't have a Temperature Gauge. The service department advised that the Check Engine Light would come on should there be an overheating situation or other major defect - but I think he said it would FLASH - indicating "turn it off now!!" (that was 6 yrs ago).
    RCO likes this.
  17. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    #15. Was he a Toyota engineer designer?
    Prodigyplace likes this.
  18. bbald123
    386
    275
    Harrisburg, PA
    Here is the official Toyota stance on the warning lights in the 2016 Prius:
    pjm877, RCO, alanclarkeau and 2 others like this.
  19. Prodigyplace
    12,669
    11,828
    Central Virginia
    I am sure a GM engineer may have good knowledge of GM vehicles. We cannot necessarily assume their comments apply to the Prius & HSD.
    RCO likes this.
  20. alanclarkeau
    7,045
    7,593
    Thanks - I wonder about temperature - though cars overheating seems more a thing of the past (until they get old).
