It happened. Flat tire. No spare.
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Dec 21, 2017.
  1. Mendel Leisk
    41,743
    That's a puzzler. Two different sources, near-identical rims?? I would email them, maybe they'll shed light.
    HPrimeAdvanced likes this.
  2. bwilson4web
    16,299
    I agree the Prime reveals a lack of long term, goal oriented design:
    The first generation, plug-in Prius was a 'bolt in.' The second generation, Prime has that clever, one-way clutch that allows MG1 and MG2 to work together as a single motor. But the body is the problem.
    The best battery location is under the floor, not in the cabin. It will take a new, standard unibody design and that takes awhile. But as concerns the spare, if they could have reversed or revised the stamping mill dies, under car access for the spare would make sense with no loss of body strength and stiffness. Clearance might be a problem.
  3. Mendel Leisk
    41,743
    Yeah, they have practically enough space under the Prime battery as is. If the bottom sheet metal was revised upward, I think an under-slung spare would be doable, maybe. It would be a feather in their cap: a plug-in with a spare. If they could manage to level the hatch floor too, double feather.
    Geo Dude and HPrimeAdvanced like this.
  4. padroo
    padroo Senior Member
    2,763
    2,252
    I'm new in this discussion but if I were making any changes to the floor under the batteries on a Prius Prime it would be to hold more batteries and not a spare time. Has there ever been any talk in using the Prius for an all electric EV?
  5. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Gas tank is under the rear seat, so it's not in the way either. (I actually think that the gas tank should've been mounted where the spare tire goes, and the battery mounted under the seat, as some other PHEVs with similar battery and fuel capacity do, but that's another thing entirely.)
    fotomoto and HPrimeAdvanced like this.
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The gas tank is also behind the rear seat.
  7. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Spare tire well is behind the rear suspension, though, whereas the gas tank is in front of it.
    The only thing I can think that would interfere with an underbody spare tire well, below the Prime, would be the muffler - this is the Liftback, but I believe the Prime is the same idea:
  8. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    UPDATE: I ordered two tires and a rim yesterday from Tirerack. I got them today. They were supposed to get here on Friday. That's service. I'll swap the tire tomorrow and get the other new tire mounted on the rim with the flat. Go Tirerack!!
    If anyone needs tires/wheel, order from these people. I used to use them all the time for my other cars (track tires, etc). Costco has been my main place to go for "normal" tires, but Costco didn't have the tire for the Prime.
    #188 JMalmsteen, Dec 27, 2017
    Geo Dude and bisco like this.
  9. JMalmsteen
    287
    266
    I'm going to put it wherever it fits, that could be the trunk or the rear seat. We'll figure out how to secure it.
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,814
    So. Texas
    I got one of these tire covers to help keep things a little more tidy when storing inside the car.
    http://a.co/gaIKBC4
    JMalmsteen likes this.
  11. Lee Jay
    5,850
    4,036
    Securing it might be harder than it sounds. The only points in the entire Prime designed for securing loads are the baby seat latches.
  12. fuzzy1
    10,553
    After fatal fires following crashes, don't a number of makers prefer putting that tank of combustible fluid in front of the rear axle for crash safety reasons?
  13. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    It's generally preferred, sure, but there's plenty of designs that put it further back:
    Geo Dude likes this.
  14. JMalmsteen
    287
    266
    I'll let you know. If we can't get it safely secured, I'll go to Toyota and give them whatever they want for the replacement deck, it is what it is. I'm not going to get killed over a thousand dollars. Do you think we could use the baby seat latches??
  15. bisco
    52,185
    i don't secure mine. how many things do people put back there unsecured? just because it is there all the time doesn't make it different.
    Raytheeagle and stuyguy like this.
  16. bisco
    52,185
    only around here.:)
  17. JMalmsteen
    287
    266
    Right now, I have a case of water, a case of Premier Protein shakes, a box of Quest bars....not as heavy as a tire, but still.
  18. bisco
    52,185
    i've seen lawn mowers back there.
    Raytheeagle likes this.
  19. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I've had Costco order tires for me from Michelin many times over the years for my previous cars. Usually took a couple of days to a week, but the Costco guys have been very helpful. Don't know about rims, however.
  20. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    A frozen 20 pound turkey could become a nasty missile hazard!
