Prius Prime Fob Program
Discussion in 'Prime Main Forum (2017-2022)' started by sonofdob, Dec 24, 2017.
  1. sonofdob
    sonofdob Junior Member
    new york
    I would like to open all doors from the passenger side and rear hatch. Have pressed the 2 buttons and can toggle between driver door only or all doors but only from the drivers side.
    What is it I am missing?
    2008 Prius defaulted to 3 doors unlocking all 5, and the manual seems to suggest I can do this though in practice I am failing.
    Help.
    Thanks
    Danny d
  2. Elektroingenieur
    2,515
    3,282
    Three Touring
    Some models of the Prius Prime don’t have an electrical key antenna on the front passenger door. The sales brochure (PDF) says the Plus has “Smart Key System on driver’s door with Push Button Start,” while the Premium and Advanced have “Smart Key System on three doors with Push Button Start and remote illuminated entry” (page 22; emphasis added).
    breakfast and RCO like this.
  3. sonofdob
    new york
    Wow that info is buried. should have would have could have bought the premium, but Wth that’s stupid. I got heated seats but can’t unlock the door.
  4. Prodigyplace
    12,528
    11,748
    Central Virginia
    Incidentally, hoe were we to know you have the Plus? Your profile still lists the 2008 Prius.Since you referred to it in the past tense, I assume you traded it in.
    priuscatprimeguy likes this.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Everytime I mention about the profile page and what the latest car they have I get reamed out:rolleyes:
    Prodigyplace likes this.
  6. Prodigyplace
    12,528
    11,748
    Central Virginia
    Sorry.
    Sometimes people get creative when they own several cars pertinent to this site. Quite a few have three.
    There is another thread where, among other things, we are suggesting some modification on this.
  7. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    If you have a Prime, 2017 plus, upon grasping the door handle, the drivers door unlocks immediately. If you hold your hand on the door handle another 2 seconds, all doors and trunk will unlock. Otherwise one can always use it as a regular Fob, double click.
  8. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    You can also change your settings so one touch of the handle or fob button press unlocks all doors.
  9. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Yep can't recall off the top of my head but I think that's one of the settings you can do yourself. I have Carista, so some settings I adjusted with the app. That's one of the first things I changed. Touch the Drivers door and they all unlock at once.
  10. Prodigyplace
    12,528
    11,748
    Central Virginia
    I did it myself on the Gen 4.In the Settings menu on the MFD, I believe
    jaqueh and alexcue like this.
  11. jaqueh
    341
    199
    San Francisco
    Yep no Carista required. It’s just in the vehicle settings.
  12. Prodigyplace
    12,528
    11,748
    Central Virginia
    Unfortunately, the Gen 4 has 2 different Settings menus. One on the MID and one on the MFD. :mad:
  13. JKang
    JKang Junior Member
    Danny, did you find a solution or is the answer that the Prime Plus can only be unlocked from the driver's door handle?
  14. Andyprius1
    2,327
    859
    Cool CA
    Prime plus, which is what I have ( the basic model ) right? all doors can be opened at door handle, first signal is drivers door only, hold door handle for maybe one more second and all doors unlock, and trunk.
    breakfast likes this.
  15. Prodigyplace
    12,528
    11,748
    Central Virginia
    They appear to want 3 door SKS though. The Plus only has drivers door SKS. The answer is in post 2 but people here seem to post in a thread without reading all the posts.
