Smart key not recognized
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bentle, Dec 29, 2017.
  1. bentle
    bentle New Member
    KY
    2010 Prius: The "key battery low" message popped up. I replaced the battery. The fob is blinking and will lock/unlock doors. The interior/dash lights are lighting correctly. I hear the vacuum pump kick on when I hit the brakes, but the power button doesn't turn green.
    Brand new Optima battery, checked smart key fuses. Any advice?
    51,895
    check the voltage of the brand new optima battery, and the connections for cleanliness and tightness. don't forget the neg to ground.
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,045
    780
    Virginia, USA
    Have you tried placing the key next to the START button? How sure are you that the battery that you replaced in the key FOB was good? Sometimes a "new" battery purchased has been sitting around for years.
  4. bentle
    bentle New Member
    KY
    Well, the battery is about two months old and measuring 12.5V. The connections all look clean and tight.
    I’ve tried holding the fob up to the start button. Two new batteries—and the fob is flashing, the remote buttons working, so I feel the batteries are good.
  5. bentle
    bentle New Member
    KY
    And it won’t jump start...I would think that would bypass the 12V battery entirely?
  6. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    This just began happening to me, intermittently. I’ve replaced both fob batteries and I hope that does it. On last failure, car would not start until I used remote to lock/unlock doors, then all was good.
  7. bisco
    51,895
    how did you measure the 12v?
