Bottom heat shield loose
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mjoo, Dec 31, 2017.
  1. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    This week, driving through the piles of snow in the streets, a bottom heat shield partially fell off of the car. It's the one that protects the underside of the exhaust heat exchanger. It probably happened as I dipped into a pile of frozen slush at the end of a driveway. I can now hear it drag everywhere.
    I'm planning on tying the heatshield back onto the car but it would be good to have a picture of the undercarriage of a Prius Gen 3. Anyone know of a picture? Also any advice for what fasteners to use? Thanks.
  2. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    If you already got a hold of the fallen one, I sure bet it would be easy you find out the position it fell off from, and fix em. I think would save you more cost.
    But if you don't know where it came from, that'd be another ball game entirely
  3. Mendel Leisk
    41,318
    Can you snap a picture of the location on yours, where the part has come off?
  4. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    It didn't fall off. It's held on by one corner. I also don't have a heated garage and it's 5* outside so I'm wanting to get it right the first time.
    Does anyone know what fastens the heatshields to the car?
    Pixel XL ?
  5. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Ok sure
    Pixel XL ?
  6. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Pixel XL ?
    Raytheeagle likes this.
  7. Mendel Leisk
    41,318
    I'm thinking 10 mm (socket size) bolts into weld-nuts on the body. If you can find some spare bolts, or borrow from elsewhere on the car, you can look for holes and check if they'll screw in.
    mjoo likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    privilege, bisco and mjoo like this.
  9. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
  10. Mendel Leisk
    41,318
    You can see plastic fastener in that pic. I'd wager that's what they all (4) are. Bring in the one you have to compare.
    mjoo likes this.
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I would just get that shield off and work inside in the warmth bending it back into good condition ;).
    You won’t need that til summer anyway:whistle:.
    Stay warm(y).
    mjoo and Mendel Leisk like this.
  12. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Ok that was too easy. The heatshield is off the car and the car's off the jack stands. Thanks.
    Happy New Year!
    Pixel XL ?
    Mendel Leisk and Raytheeagle like this.
  13. Mendel Leisk
    41,318
    Yeah it looked you were there from the pic. (y)
    You guys NEED snow tires, btw.
  14. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
  15. privilege
    privilege Active Member
    659
    169
    Birmingham
    thanks to you guys I know where this shield belongs...
    mine fell off in a water puddle and was dragging on the road lol
    thanks !
