Tire Pressure Monitor warning
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Lisa P, Dec 31, 2017.
  1. Lisa P
    Lisa P New Member
    Nashville TN
    2014 Prius c
    I hope someone is out there on New Year’s Eve! I’m at a hotel at the halfway mark of a 700-mile road trip. For about the last five miles of the drive today, my tire pressure monitor warning sign came on (this is a 2014 Prius C (2) with 47000 miles on it). When I got to the hotel, I parked the car to check in, then went back out to move the car. When I started the car, the warning light did not come on. Turned the car off again, then back on - no warning light. Drove a couple of miles to get dinner; restarted car after dinner — no warning sign. Tires are not visibly low, and the car doesn’t handle any differently.
    Normally I would go straight to a tire place and have them checked before hitting the road for the remaining 350 miles of my drive — but tomorrow is New Year’s Day. Do I chalk up the warning light to the unusually cold weather? Or do I try to find an open tire place on New Year’s Day?
  2. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    The cold has probably dropped the tire pressure below the warning point. Go to any gas station and add some air in the tires. There is a sticker on the driver's door jam that specifies the recommended pressure. These days tires only look low when they are really, really low. If the light comes ON, the pressure is at least 20% lower than it should be.
    Lisa P likes this.
  3. fuzzy1
    10,603
    What are the tire air pressures? Go measure them. We can't tell much of anything without those?
    My 2012 Liftback has had a few false alerts in two different wheel sets (summer and winter), with sensor batteries too young to likely be failing. I don't yet have a solution.
  4. X HCH2
    X HCH2 Member
    119
    Upstate SC
    Where are you? If you are driving on ice, sometimes the slippage will trigger an alarm.
    X
  5. bisco
    52,390
    happy new year!
    Raytheeagle likes this.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Yes probably.
    And finding a place that is open New Years might not be that hard.
    Auto parts stores like Auto Zone likely have limited hours.
    Maybe WalMart auto service too.
    You REALLY should have your own tire gauge. Really.
    You can get a decent one for around $5.
  7. Mendel Leisk
    41,903
    This is a good basic one, the simple pencil style:
    Milton Industries S-920 Tire Gage
    Ideally you should check the pressures when the tires are cold, say car driven less than a mile. In practice, if you're checking them at a gas station after prolonged driving, air the tires up to 4~5 pounds over what you're aiming for, then recheck later when the car's sat for multiple hours, ideally overnight.
    The specified tire pressures are in the door jamb, on a sticker. Toyota seems to typically show slightly higher pressures for the front, at least on the Prius. I set a uniform pressure, on all four, a few pounds higher. Works for me: I know they'll be ok for a while, and when rotating tires I don't have to raise some, lower some.
  8. Lisa P
    Lisa P New Member
    Nashville TN
    2014 Prius c
    Thanks for the responses. As it turned out, there was a Firestone just down the road from my hotel that was open on New Year’s. The tire pressures were normal when they checked. I will get a tire pressure gauge — I used to carry one; don’t know what happened to it.
  9. Sam Spade
    2,036
    1,023
    2017 Prius c
    I would not trust that analysis.
    But if it is true, you may need to reset the monitoring system.
    That needs to be done after each tire rotation.......because the "normal" pressure is different front and rear.
    How to do that is in your owners manual.
  10. Mendel Leisk
    41,903
    I'm not sure about that, I mean: the Prius system is not telling you which tire location is the one that's low. The one reason I can see to do the reset would be if you're doing a significant change, and really want the system to be aware of it. Considering it apparently takes a 25% drop below the "set" pressure to set off the warning, I've never bothered to reset ours, after one initial reset, maybe 7 years back.
    FWIW, I set all my tires to the same pressure, a few pounds higher than the spec for front, keeps it simple when rotating the tires.
  11. Sam Spade
    2,036
    1,023
    2017 Prius c
    IIRC, the difference is about 4 PSI. That alone will not trigger an alarm but it's well on the way.
    This is assuming, of course, that the "tire technician" actually adjusts the pressures front and rear after the rotation.
    The "book" says to do the recalibration.
  12. Mendel Leisk
    41,903
    Huh, you're right:
    And I can see why: even though there's only one dash indicator, the system IS tracking the pressures of four distinct ID sensors.
    Doing my own rotations, just playing around with front vs rear pressures got old, early on, so I opted to set them all the same pressure. I've not noticed any difference in the feel/handling; it seems somewhat overkill. With our 17's it's actually a whole one pound difference, front/rear lol.
    I might have actually done the equal pressure thing after the last TPMS reset (actually the one and only). It apparently takes a 25% drop for them to light the warning
    In practice, I've had the tpms warning twice. Once was valid, one tire was getting low (slow leak), and the other time there was no good reason. In the latter case I bumped them all about 5 lbs (light went out), then dropped them the same amount a few days later (light stayed off).
  13. Sam Spade
    2,036
    1,023
    2017 Prius c
    Well surprise, SURPRISE !!! :ROFLMAO:
