PRIME TRUNK SPACE
Discussion in 'Prime Main Forum (2017-2022)' started by Andyprius1, Feb 8, 2017.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I also had a 05, everything you’re saying is true. I miss the heated side mirrors, 2 large glove compartments, 2 trunk spaces. As for the spare.......I took the doughnut from the 05 and tried it on the prime, took a test ride and it seems to be OK.
    52,244
    wow, 200 posts on prime trunk space? must be a sensitive subject.:cool:
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    people have bodies to move, trunk space is important.. people are a lot fatter then they used to be..
  4. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    The roof box is the solution for the once a year time I need more space. The other 50 weeks of the year it works great
    iPhone ?
  5. farmecologist
    farmecologist Senior Member
    1,959
    1,799
    Southern MN
    Finally someone is being realistic about the trunk space instead of rationalizing it...like I have seen MANY folks do here. Every time I have tried to bring it up in the past I was always shot down..but could not defend myself because I don't own one. :) Not to bring up the Hyundai Ioniq Plugin discussion again...but it does look like Hyundai did a good job on battery packaging ( look further up in the thread for discussion on this...not worth reposting ).
  6. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Not sure what you mean. Prime is a hatchback. That shape is a strength, offering the ability to lower seats for more cargo room. Not doing that, instead cramming everything behind them, completely defeats the design's purpose.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,814
    So. Texas
    You've been a member for a couple of years, so you may not have seen the numerous discussions of the past (starting around 2010) about the "poor" design/layout of other PHEV manufacturers. Battery intrusion into the hatch area, uneven floor with rear seats folded, only 4 seats, no spare, mass charging would lead to local brownouts (still my personal fav), etc., etc., etc., were HUGE talking points here against those pioneering models. Now? ;)
    Tideland Prius and bisco like this.
  8. Mendel Leisk
    41,792
    Seriously John?
  9. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Yes I do estimate Prime "true" cargo space is less than Gen2. Good thing you are coming from Gen2 and not Gen3 (the king of small car cargo space).
    My Gen2 replaced a mini-van, and until we got a new mini-van, we often used a Thule roof top box on the Prius. In those days Saris had a wonderful roof rack making it so easy. Unfort Saris stopped making those racks, but I think you might be able to duplicate now with Thule or Yakima.
    The day I get a plug-in is the day I can get a plug-in with cargo space...which could be a used PiP, which retains the Gen3 space for the most part. I was like only person who liked PiP concept.
  10. john1701a
    12,818
    5,303
    58
    Why must Prius fit an absolute of the past? With all the other body choices available and becoming available, no opportunity for market adaptation makes no sense.
    Remember, there's a Prius CUV being tested. There's a Corolla plug-in hybrid in the works. Camry, RAV4, and C-HR could all undergo the "Prime" upgrade.
    What's the problem with Prius changing?
  11. bisco
    52,244
    au contraire.:cool:
    Tideland Prius likes this.
  12. bisco
    52,244
    no problems changing for the better. otoh...
  13. john1701a
    12,818
    5,303
    58
    Remember what Toyota said about their audience changing... Prius owners who shopped for a growing family back then, now handing the car down to a child and looking to Prime as a vehicle for their new found freedom?
    KrPtNk and HPrimeAdvanced like this.
  14. bisco
    52,244
    that's me, but i would still like a full hatch.
  15. ct89
    ct89 Active Member
    323
    266
    New England
    My guess (and it's only a guess) is that Toyota had a few choices.
    1) delay releasing the vehicle until the battery could be better integrated into the body
    2) Use a smaller battery
    3) Get they thing out and continue to improve it over time.
    I'm happy they picked #3 vs. either of those other two options.
    This is something like the third thread today around choices...I work in an industry where we're always making trade-offs and with every choice, some people will feel you went the wrong way. I see cases that with hindsight it is clear we made the wrong choice but I know we did the best we could with the data and constraints we had at the time. I'm willing to assume the same is true at Toyota.
    HPrimeAdvanced and john1701a like this.
  16. john1701a
    12,818
    5,303
    58
    Continuous improvement is our approach in my profession... software design.
    HPrimeAdvanced likes this.
  17. Mendel Leisk
    41,792
    I was on one job, drafting in a consulting engineering office, and one of my coworkers one day, said "we're moving backwards". That stuck in my head, scary/heady stuff, and I suspect he was right.
  18. john1701a
    12,818
    5,303
    58
    That's the older generation. That isn't necessarily what the newer generation deems a priority. Toyota is trying to avoid falling into the same "generation" trap that GM did, finding their formerly-popular product now something only appealing to a rapidly shrinking audience. Keeping an offering aligned to match up with middle-market, where high-volume sales are dependable, requires adaptation... changes over time... the kind some former buyers may not be interested in.
    Regular Prius clearly focuses on the younger crowd, those seeking to have a standout look. Remember, there is no longer Scion choices available to serve that purpose anymore.
    Plug-In Prius has moved up, where the unlikely-to-be-needed middle seat was abandoned in favor of taking on the layout found in higher end vehicles. In fact, that's exactly the reason why such a large display is offered. That is why also having lots of height in the cargo area isn't a priority. Dropping the seats for hauling lots of cargo is no big deal for this audience.
    Don't forget how many other "Prime" hybrid upgrades could be offered in the not-too-distant future. They have their own audience too. A full hatch would be a priority in that larger new model of Prius.
  19. bisco
    52,244
    agreed. i'll be looking around for something a bit more old fashioned when the time comes, if there are any manufacturers still interested in us old farts. perhaps hunday hasn't caught on to the pepsi generation yet.:)
    Mendel Leisk and john1701a like this.
  20. ct89
    ct89 Active Member
    323
    266
    New England
    I still expect that Toyota will build the next generation frame to better accommodate the battery but then the question will still be do they put in a bigger battery, a spare tire, more trunk space? I bet a poll would find passionate arguments for why each of those choices was the right one and plenty of people will criticize whatever they choose. We need less criticism in the world.
