  1. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    I’m sure you can find them on eBay buts it’s gonna be buying a few of them and trial and error fitting them
    iPhone ? Pro
  2. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Relube front tire caliper pins, no lube left after 89k. Now no more pad(s) making loud squealing noises. Won't miss smashing the brake pedal for pads to disengage from rotor.
    Many thanks to Raytheeagle and SFO for their expertise and helping me resolving this matter. Got the invite to drop by at Raytheeagle's beautiful home, and SFO was there to assist. Always appreciate the contribution and knowledge they continue to bring onto this forum.
    RMB and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I guess that leaf may have been contributing a bit to the noise:whistle:.
    Glad it worked out:).
    Until next time (y).
    Grit likes this.
  4. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    Made my own plug and play harness. Just waiting on the last ballast which hopefully arrives this week and have these babies installed by next week inshallah. Going to clear wrap them ASAP! :love:
    #15164 MPGRaja, Jan 1, 2018
  5. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    this is my next project, chaning my 2011 LED to these facelift LED lights. Wouldve been awesome if someone started making these face lift headlights with a lightstrip underneath the projectors as the Prius G`s got. Just as DRL`s
    Dylan Doxey and MPGRaja like this.
  6. MagnusAG99
    673
    521
    Norway
  7. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    I've been shopping around for this myself, where did you get the harness? Or did you already have fogs installed?
  8. riceroni87
    360
    598
    Oxnard, CA
    The harness I just made myself. It’s wired to a generic switch that fits in the same spot an OEM switch would go. They do have a halogen one on eBay that’s all plug n play that comes with everything but I wanted the led ones.
    iPhone ? Pro
    James Powers likes this.
  9. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
  10. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Follow up:
    It was really cold the night I curbed the tire, I left the car on ready to keep the heater going and noticed that the engine was misfiring, when I got back into the car, of course the TPM light was on and the CEL right beside it was on also. I drove the car again today and several times I noticed the misfiring when cruising, not noticed when under load. I had never had any of this before the jolt from the tire curbing, been too cold here to check anything but anyone got any ideas what this might be and why it started with the bump from the curb? I'll see if I can pull the CEL code.
    Raytheeagle likes this.
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Pull the code and let us know ;).
    If misfiring I would bet it is the P0301 through P0304:(.
    Done the egr circuit cleaning yet :whistle:?
    m.wynn likes this.
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Ended up changing out the 12 volt battery today:).
    Bought the replacement from Autozone for $181, but got it down to $141 after discounts and in store gift card;).
    Charged it up prior to introducing to the Prius:
    26E481C1-B5C9-468C-9B01-B638178A437B.jpeg 4B1F95BD-840F-45B9-99A5-0567273B8AFD.jpeg D9FDBF94-9612-487D-802D-6F1AEF37DD85.jpeg
    The old one served us well since August 2009 (manufactured 6/17/09):
    D5BAEFF2-502B-49FD-89D0-59EE873DC9BB.jpeg B28F447F-CBF2-4FD5-9381-2838F976000E.jpeg
    Hoping for another 8.5 years out of the new one (y).
  13. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Solid run with the old battery, 8 half years. Now on to 510 crankin amps!
    RightOnTime and Raytheeagle like this.
  14. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    What was your tire pressure on the bust tire (best estimate) when the curb took it?
  15. milkman44
    591
    386
    Ky
    Running 40psi in front, could have been down a couple of pounds due to the cold.
  16. Prodigyplace
    12,521
    11,742
    Central Virginia
    Now on to a wasted 510 crankin amps!
    FTFY
    The Prius does not need the high cranking amps of a traditional 2 volt starter based car.
    milkman44 likes this.
  17. milkman44
    591
    386
    Ky
    P0301 and P0303, still baffling that it just started with the jolt from hitting the curb. Codes cleared, but I'm sure they'll be back.
  18. MagnusAG99
    673
    521
    Norway
    wait... do u feel like the car suddenly starts vibrating and stuff to? like... it feels like the engine is about to turn off or struggle to stay on at low RPM`s? if so i would believe its the EGR circuit thats blocked or some... my dads 2013 Auris Touring sports hybrid did that when we just bought it to. The EGR circuit was blocked aswell as the crankhouse ventilation.
    #15178 MagnusAG99, Jan 3, 2018
  19. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Hopefully it hasn’t started eating coolant yet:(.
  20. milkman44
    591
    386
    Ky
    Magnus, I'm sure the EGR system along with the intake needs a good cleaning, just waiting for warmer weather.
    Ray, no sign of coolant loss yet, but will keep a close watch, sure hope that doesn't show up.
    MagnusAG99 and Raytheeagle like this.
