Prime v. 2014 Plug-in. Also rebates in 2018?
Discussion in 'Prime Main Forum (2017-2022)' started by Windhorse23, Jan 2, 2018.
  1. Windhorse23
    Windhorse23 Junior Member
    25
    Felton, CA.
    Dear Prime and Plug-in enthusiasts,
    [Posted in Prius Plug-in 2012-2015 too, and Gen. 4 by accident. Forgive multiples.]
    Tomorrow, I have to trade in my 2014 PiP Advanced with 55K mi. (which I loved) because of mildew from water intrusion followed by dealer's chemical spray that made it worse. Dealership is working with me to take the car back for $14,200, which is probably more than it's worth, though I paid $18,500 for it last Feb.). With paying taxes twice, it's a big loss, but I need to move on, and this is the only dealership that will take such a malodorous car. The decision I need to make by tomorrow, the end of the Toyotathon deals:
    1) Trade for 2014 Advanced PiP with 49K but not certified b/c already recalled for E/V fuse which, they say, will be no problem. It's the same car as my 2012 but lighter gray. I'm tired of gray, but $/warranty more important.
    Cost: $4000 (inclusive) + my trade-in.
    2) Trade for 2017 Prime Plus. Better drive, more $. Nice red exterior with moonstone interior.
    Cost: $14,000 (inclusive) + my trade-in.
    After buying a "new" car in Feb., it sucks to have another $ outlay so soon. Prefer not to go in debt, but am thinking of it this way: the Prime = better investment in long run; longer warranty; + hopeful rebates.
    But I'd like to be more confident about rebates and benefits of a Prime.
    Questions:
    A) Does anyone know about status of Federal tax rebates for 2017 Primes bought in 2018? Or CA. rebates?
    If the House Tax bill doesn't eliminate them (grrrr) and if CA. still has funding, the Prime could end up costing close to what the 2015 PiP does. But these are big ifs!
    B) I don't have a home charging station and may never have one. I rent. They're pricey. Hoping to charge at work etc. Does the EV battery charge when you drive downhill or tap the breaks? Salesperson who sold me 2012 PiP said no need to charge for that reason. A new salesman just said that's incorrect. Another one said it's nuanced. Anyone know the answer? Nutshell: is it worth buying a Prime if you don't have your own charging station, or can you still get better mileage than normal Prius?
    C) Aside from Prime being a 4-seater and less room in back (both are bummers but not deal killers), any reason not to go with the Prime (other than the cost) and to stick with older Gen for a bit?
    Thanks!
    HPrimeAdvanced likes this.
  2. Tideland Prius
    16,547
    For other members, I've already closed the Gen 4 but I've left this one and the PiP one open so no need to report it :)
    bisco and Windhorse23 like this.
  3. Windhorse23
    25
    Felton, CA.
    bisco and Tideland Prius like this.
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Yes:D
    Windhorse23 likes this.
  5. Rmay635703
    Rmay635703 Senior Member
    2,668
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    The only reason to PIP would be because they just about give them away (PIP is the only Gen III I would buy personally)
    Prime is better in most every way that counts but obviously gotta pay to play.
    I guess if the extra seat and 3” of floor space don’t matter, it’s a TCO question.
    Will the primes extra range let you do daily driver activities fully EV?
    What’s the extra warranty worth to you?
    Only you can answer , depends on your priorities,
    but typically it’s hard to financially justify a new car but the new tech these days is fun isn’t it?
  6. Tideland Prius
    16,547
    Np!
  7. bisco
    51,840
    if the question is; does prime regen enough to make it different from pip and you don't have to plug it in, the answer is no. while you don't have to plug it in, there's no free lunch. it will behave like a normal hybrid, just as the pip does without the wall charge.
    it does however, have a new feature called 'force charge'. you can burn gasoline to charge the battery, but why you would want to in most instances, nobody knows.
    i would get the prime, since the tax bill includes the $4,500. rebate, and cali still has rebate money.
    all the best!(y)
  8. Washingtonian
    Washingtonian Senior Member
    726
    621
    I think the OP may be confused about the need for a "charging station". The car comes with a long cord that plugs into a normal 120V outlet. So just because he rents, unless he lives in an upper apartment and has to park on the street, he should be able to charge at home.
  9. bisco
    51,840
    he has a pip, he should understand.
  10. Windhorse23
    25
    Felton, CA.
    Thanks, @bisco and @Washingtonian. Yeah, driveway is further than 25' from home outlet. We live in a forest in crispy CA., so wouldn't want to risk an extension cord. I'll probably bite the bullet and have another dedicated outlet installed by driveway when I can afford. Given the rebates ($4502 Federal and $1500 CA.), the HOV sticker, and probable gas savings from charging when I can, I agree with @bisco that the Prime is probably a better deal in the long run. I normally go for used cars for environmental/economic reasons (not mining more ore for new car, etc.), it's a good idea to take advantage of the rebates before they get phased out.
    One other consideration: I want to install an electric bike rack that will require a hitch assembly. Anyone know whether the installation will be problematic in terms of location close to the Prime's battery? Toyota told me I couldn't do it with the PiP. Some metal that would need to be bent might heat up and cause problems with the battery. I found someone in town who rebuilds e-bikes and installs racks, and he says he could do it (with the PiP). Oddly, Toyota service & sales don't seem to know things like this. And sales was hopeless about rebate knowledge, so again, appreciate all the support from the smart folks in PriusChat!
  11. Windhorse23
    25
    Felton, CA.
    Good points. If they were giving away the PiP, I'd probably go for that, but the sticker is $19,750 for a 2014 with 49K which is pretty steep IMHO.
  12. bisco
    51,840
    toyota and its affiliated dealerships will never approve any aftermarket tinkering with the car. if you hang around here long enough, you will find that most of it is a load of rubbish.
    every decision toyota makes has been approved by a battery of lawyers, especially in the good ol' usa.
  13. Windhorse23
    25
    Felton, CA.
    Yep, you were right--as usual--@bisco. The guy in parts was super serious about *never ever ever* attaching a hitch to a Prime or my battery warranty would be voided. No place to attach, he said, other than the battery casing or thereabouts. I'm going to look into this further... I got the Prime. You're thinking about getting one too, right? Or are you holding out for a later model with 5 seats and more room in the back? I'll keep you posted about issues.
    wjtracy and bisco like this.
  14. bisco
    51,840
    i'm still toying with the idea, but may wait for the next model hopefully with full hatch. 4 seats don't bother me.
    there are lots of hitch threads here for towing, bikes and etc. toyota has never encouraged it, but no one has ever reported a problem,
  15. outoftown
    outoftown Member
    125
    66
    Cary, NC
    I would think the 2017 safety improvements, not just with the Prius, but the whole lineup, including the Yaris, would also
    be a huge lean toward the Prime. The McPherson struts and double wishbone suspension, better seats and seat material also are not highly visible, but make the ride soooo much smoother. I am a former 2012 PIP owner and switched to the 2017 Prime.
    Windhorse23 and Mark57 like this.
  16. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    The Prime in Ca. may have the HOV sticker advantage....I am not sure how the new HOV bill works for the older PiP ...
  17. Windhorse23
    25
    Felton, CA.
    Like you, I traded my 2012 PiP for 2017 Prime. So far, so good! It's a great ride. @bisco is right that decreased hatch space is not a plus. Looking forward to discovering all the exciting features.
